I have a Sanyo TV model DS19390 chassis # 19390-00 and the F connector was pulled out of the back. That is the easy part. The hard part is there was a isolation cap on the in put from the F connector that was destroyed and I do not know the value of that cap.
3 Suggested Answers
SOURCE:
Benimur
  • 6966 Answers
SOURCE: How can you reset a
Hi again,
Please see your latest post.
Just a start, do postback how things turned up orshould you need additional information. Good luck and Thank you forusing FixYa.
Additionally,pls be informed that you would be lowering my ranking/rating if yougive me a rating if less than a FixYa. Doing so would prevent my beingable to provide further assistance.
Posted on Nov 18, 2008
SOURCE: blinking green timer light
i did the manual switch on the orange power wire on the fmt module,it still works so far... thanks
Posted on Feb 02, 2012
Tv shuts off
You may want to check the below article for a wide list of Sanyo models exhibiting "random turn off" problem along with repair options for them.
http://blog.coppelltvrepair.com/2012/07/sanyo-dp47460-dp42840-dp46819-and.html
All in all the first thing you need in order to get meaningful help is providing information about which particular model and chassis is your TV.
Both are on the label at the back.
Mar 19, 2014 | Sanyo Dp32640
I got the Sanyo tv model dp42746 September 2006. Serial number B6360911152128 chassis number 42746-00. It wont turn on the green light does 12 blinks on the back. What can i do to fix this
These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 13, 2013 | Televison & Video
Sanyo DP46840 won't stay on. Turns off after 2-3 seconds
Look up the chassis version of your Sanyo (it's on the label on the back where the model is) and check in the list below to see if there is a repair service offerred for it:
http://www.coppelltvrepair.com/search?Q=DP46840+&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
Hope this helps!
P.S. There's no quick and easy solution that I can offer based on the information you give and what I know about those boards. This is why I am at least sending you somewhere where you can read what is being treated and under what conditions.
Mar 31, 2013 | Sanyo 42 in. LCD TV
Power Issues with Sanyo DP50749
Main board is most likely but that is an educated guess--problem with all these is you can only check so many things and then have to guess and try a board.
Apr 22, 2012 | Sanyo DP50749 50 in. Plasma TV
Does the Sanyo DS19390 have an audio jack??
yes check at the back of your tv you will see their the small holes colored yellow.white and red theirs a printing av in or out insert it their.
Oct 19, 2010 | Sanyo AVM-2758S 27" TV
Hello my Sanyo dp42849 42 inch has no picture and no sound. when i turn on the tv a green light in the bottom right hand corner comes on and occasionally flashes off and then back on.
First, you need to know the sub-model of your TV.
It is called "chassis" and is shown on the back of the TV on the label where the model number is shown.
For example it can be "P42849-00" or "P42849-01".
Then search at www.coppelltvrepair.com/search or just go to www.coppelltvrepair.com and enter the link for SANYO DP SERIES to search for that.
Here's an example of a repair service (note it may NOT be the one for your exact model though!):
http://www.coppelltvrepair.com/p/41/sanyo-dp42849-p42849-00-does-not-power-on-repair-service
Hope this helps!
Jul 16, 2010 | Sanyo 42 in. LCD TV
I have a older sanyo ds19390 tv that is buzzing inside, not thru speakers please help
In older tvs the buzzing sound usualy comes from the HT lead plugged into the tube .open the back and switch the tv on (do not touch anyware near the set the HT lead carries avery high voltage even when the set is off)if u do see arching then u need to clean around the rubber of the ht lead )u can leave the set unplugged for a couple of days to allow the tube to discharge before attempting to clean around it.
Apr 13, 2010 | Televison & Video
How can you reset a model ds19390 Sanyo tv back to factory settings without original remote? It is an older analog set.
Hi again,
Nov 10, 2008 | Sanyo Televison & Video
Television problems
Have the speakers ever been played loudly? They may have been pushed passed their capacity, in which case, it may be time for a new tv.
Dec 16, 2007 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Ekse
