Question about Mavic Ksyrium Elite Wheelset
The red spoke on my Ksyrium ES wheel broke. I got a replacement and removed the freehub, how do I get the spoke out -- can that be done without removing other spokes?
    Brigadier General:
  • 8,546 Answers
I want to buy 1 of MAVIC KSYRIUM SSC SL SPOKE KIT REAR, DRIVE-SIDE, 272MM and MAVIC KSYRIUM SSC SL SPOKE KIT FRONT, 281,5MM SILVER, I want to know if you have in stock this kits and help to me to find road...
Hi, Edurado for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
http://roguemechanic.typepad.com/roguemechanic/2012/07/mavic-spokes-and-parts-in-stock.html
Mavic Ksyrium SL SLS Replacement Spokes 4 81
http://www.tech-mavic.com/tech-mavic/uk/sources/Produits/ROUTE/Roues/KsyriumElite/KsyEliteSpokeReplacement.pdf
Where to get older Mavic Ksyrium SSC SL Spokes The Paceline Forum
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 16, 2015 | Road Motorcycles
How do I replace a Tracomp spoke on a Mavis Ksyrium SLR rear wheel? Can't work out how to release the hub end.
I believe you'll have to undo the spoke at the rim end (Mavic uses a torx style head on the nipple). With the hub end of the spoke, looks like a ball but with two flat sides. When the spoke is tensioned it seats the ball end into the straight pull flange. This style is used in pretty much all of Mavic's high end wheel sets (Road or Mountain). Some have a plastic clip-on type cover. This can be removed with a flat head screwdriver. Good Luck!
Oct 13, 2013 | Mavic Ksyrium SLR Rear Wheel/Tire
Broke spoke on mavic kyserium sl can't ride bike, miles from home
being a french bike I don't know who can get you a replacement , but if its just a spoke or two,, wind the broken ones around so they don't rub on the fork or frame, and I'll keep looking , so check back, wow those are expensive,, heres a link
http://www.amazon.com/Mavic-Ksyrium-SL-Bicycle-Rim/dp/B0034L0872 Is it the front or rear ? heres a rebuilt one for less http://www.competitivecyclist.com/product-components/2011-mavic-ksyrium-sl3espremium-wheel-rebuild-4051.1849.1.html
Jul 15, 2011 | Mavic Cycling
I got a wobble on the back wheel jacked the bike up wobbled the back wheele so expecting wheel bearings. took it to garage and they vtold me one spoke had broke and the rest were loose. i was then told all...
This is very unusual for the spokes to get loose on a wheel. Without seeing the wheel, I'm betting that the wheel has been relaced at some time or another with chrome or custom spokes. If they used the wrong spokes, they will not stay tight. Since the spokes came loose this time, they'll do it again. I've seen wheels laced like this before and the "knobs" on the hub end of the spoke does not lay in the holes like they should. You cannot keep the spokes tight nor the wheel trued. It's best to have it either relaced the proper way or simply replace the entire wheel.
Good Luck
Steve
Mar 19, 2011 | 2003 Harley Davidson FXDL Dyna Low Rider
My back wheel is making a ticking noise when i stand up and pedal. I lubricated the cross points of the spokes and it is still making the noise. I took the tire and tube off but i'm wondering how to get to...
You may have a loose spoke or two. A rubber liner usually covers the spoke heads. If you do your own repairs, invest in a spoke tension gauge and the tool to adjust the spokes.
Jul 28, 2017 | Mavic Ksyrium Elite Wheelset
Wheel does not stay true
Check if your spoke are tight enought, sometimes if the spokes are loosen the wheels will bent really easy.
May 18, 2010 | Mavic Ksyrium Elite Wheelset
Cant put my mavic back together properly
It sounds like you lost the washer that sits between the bearing in the nose and the freehub bearing. If you lose that washer, when you re-tighten the axle, the two bearings will bind and prevent the freewheel from spinning easily.
Take your freehub off again and see if that washer is there. If it isn't, you'll have to get a new one and replace it. It's easy to lose that thing if you don't know it's there when you take the wheel apart, because it'll just fall out.
When I reassemble those wheels. I thread the drive-side axle through the freehub body, then place the washer over the axle on the inside of the bearing, then thread the axle through the nose.
Also note that if your freehub seemed loose, it probably needs to be replaced. The FTS-L freehub body used on the Ksyrium wheels uses a nylon bushing as the friction interface to the nose, and this bushing wears down over time even with good lubrication.
Feb 10, 2010 | Mavic Ksyrium Elite Wheelset
Need to replace the cassette body on my Ksyrium SL wheel. Is there a tech sheet on this procedure?
You need two tools: a cassette wrench or socket (it's a splined socket that fits into the cassette through the axle)and a chain whip wrench. You use the chain whip by wrapping it around one of the cogs of the cassette to immobilize it and then loosen the lock nut of the cassette with the cassette wrench. It is just like a screw or bolt. The Cassette needs to be lined up with the splines on the freehub. Find the thin spline and use it as your "key" because it is the only one that width. Then drop the new cassette on to the freehub and re-torque the cassette's lock ring. If the cassette is disassembled rather than one piece, from the largest cog first on the bottom, alternate between cogs and spacers until you are out of spacers. The smallest cogs have these cast in. As you take the old one off, the installation technique is the same in reverse.
Regards,
matt
Sep 14, 2009 | Mavic Cycling
HELLO, I HAVE A DURA ACE 7900 MODEL CASSETTE AND WOULD LIKE TO PUT IT ON A KSYRIUM SL RIM, DO I HAVE TO PUT THE SPACER ON IT BEFORE THE WHOLE CASSETTE GOES ON? THE CASSETTE IS A 12-25 GEAR.
In my experience with Shimano cassettes on Mavic wheels, the answer is "yes" but i had a mountain wheel and cassette. The only way to know is to put it on and see if there is slop in the fitment. If there is, then you have your answer. i also had this problem with Mavic: i had to adjust the high and low settings on my rear derailleur because of the awkward spacing of the Mavic freehub. Just something you should be aware of in case you have difficulty with shifting after the install. By the way - although they are inferior cassettes, SRAM cassettes seem to fit Mavic freehubs better.
Regards,
matt
Sep 14, 2009 | Cannondale Cycling
Noisy Rear Mavic Ksyrium Hub
Sounds like a road wheel with a worn FTS-L freehub body. You'll need to have it replaced.
What happens is that the nylon bushing wears, causing there to be play between the freehub and the nose of the wheel. Once there is enough play, the freehub can actually vibrate against the nose, causing noise and friction - which is why you see the chain slacken. This is commonly called the "squeal of death," meaning it is an indication that the freehub body is "dead."
A new FTS-L freehub body should be about $50-60 and shop shouldn't charge more than about $20 to change it out. Just be sure to tell the shop one very important thing:
"Do not lose the metal washer that sits on the axle between the outer bearing of the freehub body and the outer bearing of the nose of the wheel!"
This is so incredibly important - but time and time again, shop mechanics will lose this washer before they reassemble the wheel, causing a series of nightmares with the wheel.
Jun 09, 2009 | Mavic Ksyrium Elite Wheelset
Mavic Ksyrium Elite Wheelset Logo
301 people viewed this question
Top Mavic Cycling Experts
Michial Gueffroy
vidiot1961
Level 1 Expert
Paul Bade
Are you a Mavic Cycling Expert? Answer questions, earn points and help others
