Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Sony 60 inch M.N. KDF -E60A20
There is no picture only lines of all the colors: red, green and blue.
When turned on it takes about a minute for the picture tube to turn on.
  • 505 Answers
The DIC board has gone bad. this is the exact symptom. it is expensive (200-400) and could be replaced by an technically apt person.
Posted on Dec 09, 2008
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
After lamp replacement, why is picture still green?
it seems like the green was not defective before you replaced the green. remove the red =no change in the screen color, that could be bad. put back red, then remove blue=screen color changed, blue is good, hope you got the idea.
Oct 08, 2015 | Sony Televison & Video
Screen and sound problem?
sony 2005 kdf e60a20 tv---turns on and off every 2-3mins...green power lite stays on no blinking
Mar 27, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
I have a sony 60 in rear proj. lcd that has no red in the picture other than faint red vertical lines all the way across about an inch apart. any ideas ?
It sounds like you do not have the red component cable firmly inserted. I had this problem on my first HD TV, when the green component cable popped out when I moved the TV back in place, and the picture was desaturated of any green, causing my wife to remark, "That sure doesn't look like HD..." I reinserted the green component cable, and the picture was excellent. Check those component cables.
Feb 06, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Picture and sound goes out?
does it do it on dvd. if not ists the signal from your cable provider
Jun 02, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony kdf-e60a20 problems
Replace the main lamp( sony XL-220). Step by step instructions in owners manual, takes about 10 minutes and is very simple.
Dec 19, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Multi colored vertical lines
Probably you need an optical block, but it would take a tech looking at it to be sure
Oct 04, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
61 inch sony LCD projection
Optical block or LVDS cable You need a tech to tell you for sure, have a tech look at it
Sep 30, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
KDF-E60A20 Going on and off by itself..no blinking lights
it works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I nothiced a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
Dec 05, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
