Question about Mackie TH-15A Active DJ Powered THUMP Speaker Stand and Cable Set TH-15ASET1
Just wondering if I plugged into the thru side instead of the in side will there be a differance in clareity
  • 670 Answers
There shouldnt be an issue, you can try it if it sounds like **** then go back to the other way. Trial an error is always an option :-)
Posted on May 20, 2011
Can not get it to work. Im pretty tech savvy..it makes feedback noise constantly, regardless of mode.
A bad ground connection?. Try tightening the nut on the phono plug first. You can pull out that section where the cable hooks into and visually check the solder connections.
Feb 15, 2016 | Fender Music
Is the headphone jack mono or stereo?
Stereo or mono headjack should not make a difference in the quality of the sound. The issue you have is with your head phones.
Bet that if you plug them into another apparatus they will sound lousy also. If they sound good, then the problem lies with the output stages of what ever you were plugging them into initially.
Nov 23, 2015 | Music
I have a yamaha psr s900 keyboard, the adapter is on and the green light is on but the keyboard is not turning on.
Have you measured the voltage and confirmed the polarity is correct? If yes to both of these then the problem is in the keyboard.
Can you get it to flicker / on off if you insert the adaptor plug and wiggle from side to side ( wiggle the plug - not you wiggle side to side ! )
If this makes an intermittent connection then you need to replace / refit the power socket. These have a habit of breaking the solder joint to the pcb.
Report back if this is not clear or you need further advice.
Feb 17, 2015 | Yamaha Music
My fender fm 65 dsp amplifier squeals and feeds back every time i turn it on
Is it plugged into a guitar at the time? If so, it sounds like you're using a speaker cable instead of an instrument cable. There is a big difference. Look on the cable to make sure. If guitar is not plugged in would be a completely different diagnosis.
Mar 05, 2013 | Fender Musical Instruments Corporation...
Korg triton extreme synth. L/r outputs work fine by themselves put plug in both right side cuts out using headphone jack instead if you pull the right slightly out of input you get both sides working
I need more info to correctly troubleshoot this. However my best guess from what your telling me is that its either the Audio jack on the Korg or the headphones. If everything else is working properly replace the headphones and the Audio outputs. Post again with more details if that does not work
Jan 05, 2013 | Music
Have a fender squier 4 and wondering if you plug one side can you get full mano output?
What do you mean by "Plug one side"? Your guitar is mono....you plug into the channel with a mono signal cable....as long as you're panned to center on your channel strip, you would have full mono sound out...ie sound equally from both speakers. Usually you would be running your board in mono anyway.
Aug 17, 2012 | Fender Squier 4-channel Travel PA...
I brought a akai mpk mini and when i plug it into my laptop, the sony vaio ns-series VGN-NS30E says i need driver software to use it. the keyboard works on my computer though (dell volstrom 220 mini...
Your machines are different and likely have different interface chipsets. Some newer machines have more built in plug-n-play than others. There is so much incompatibility that it is a wonder that any of the stuff works together. You need to install the needed driver... NOTE: there is a lot of incompatibility between OS versions... so if for instance you are using XP on one machine and Vista or Windows 7 on the other there are a LOT of incompatibilities. ALWAYS check the requirements for the computer with the specs of the device to be connected. MOST of the problems are due to OS variations. Check for driver updates on the Sony site
Jan 29, 2011 | Akai MPK mini MIDI Controller Keyboard,...
I have a behringer xynyx 1204,and a protools personal studio,with mbox2 mini,and im just wondering if its possible to plug the mic into the mixer,instead of the mbox,and still be able to record vocals into...
It is possible, you can simply put a Y-cable for Mic or a splitter for the mbox and the Mic. You can plug the mic directly to the mixer then the other jack on the splitter connected to the mbox.
Jul 25, 2009 | Behringer Music
Mackie TH-15A Active DJ Powered THUMP Speaker Stand and Cable Set TH-15ASET1 Logo
122 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
 Grubhead
Grubhead
Are you a Mackie Music Expert? Answer questions, earn points and help others
