Question about Lenovo ThinkPad T410 Core i5540M 253GHz4GB320GBDVD+RWabgnBTGNICFR141" WXGA+W7P (252225U) PC Notebook
External speakers not playing - Lenovo ThinkPad T410 Core i5540M 253GHz4GB320GBDVD+RWabgnBTGNICFR141" WXGA+W7P (252225U) PC Notebook
Why is sound coming from monitor not external speakers
Have you installed the software for the external speakers? I f so, the software often contains settings for which speakers play.
www.bostonacoustics.com/.../support/.../onlinesupport.a...
Jun 30, 2014 | Boston Acoustics MicroMedia Computer...
I have a Sony Bravia KDL52S5100 , I connected my PS3 through HDMI and connected external speakers through the 3mm audio out on the side. It used to work fine but now the audio is not playing through my...
This information comes from the online reference book: Using the Sound Menu
Use the remote to open the TV menu. Select the Sound menu, and the "speakers" decision. From the two choices, "TV Speakers" tells the tv to use its built-in speakers. "Audio System" tells the TV to use an external audio system, and disables the internal speakers. Select "Audio System," and check to see if it works. If it still hasn't recognized that there is an external audio system plugged in, you may need to clean the stereo mini jack (3mm audio jack) with a small wooden toothpick or similar small diameter non-conducting device.
Feb 27, 2014 | Televison & Video
Hooking external speakers tv
If you use your headphone socket for an output, you will have to use an external mixer to access a split signal.
Nov 12, 2013 | Lenovo Computers & Internet
How to listen though the external speakers?
if you have music on it simply unplug the earphones and play your music and it will play through the external speakers. since this is a free answer,please take the time to rate my video,thanks.
Dec 22, 2010 | Toymax Impecca MP-1825 MP3 Player
No sound when I play back using an external micropohone however when I play back on the TV full sound. Any solution?
Microphones are input devices; they don't double as speakers. If you mean that a stand-alone set of speakers do not work, but the internal speakers of the tv do let you hear the audio track from the camera. Then I have a couple of different suggestions: 1) make sure the stand-alone speakers work with other input sources, 2) try a different cable (make sure it is connected properly).
Also how are you connecting to the different devices? The video camera has an HDMI port which will send audio and video to the TV on one cable. If you are using the RCA audio in both cases, then I suspect a problem with the external speakers.
If you mean that the audio track is clear on play-back when you use the built-in microphone during the recording and not heard if the external microphone, check the external mic for problems. Try it on another recording device. I can't rule out a jack failure without more information.
I hope this helps.
Jun 03, 2010 | JVC Everio GZ-HD7 Camcorder
No sound does it need an external speaker
hi, it does need a set of external speakers , if you intend playing music it will sound better if you buy a 2.1 setup ( 2 small speakers and a subwoofer) you can purchase reasonable ones for around £25 , if not playing music or games with sound effects then opt for a simple 2 speaker setup , plug the mini 3.5mm jack plug from the speakers into the green jack socket .
hope this helps
Feb 22, 2010 | E-Machines eMachines Desktop PC
Cannot play external speakers
Try firmly pressing the iPod into the dock connector. If it works, good. If it doesn't, then your iPod may not have support for the speakers.
Aug 03, 2009 | Apple iPod touch Second Gen (8 GB,...
External speakers; subwoofer won't play
try to check if your audio device installed in your laptop can support the channels of your external speakers whom you want to install and make it work in your laptop
Jun 16, 2009 | Acer Aspire 4315 Notebook
External speakers do not play
It is not an issue with the speakers or the sound card as you get sound in media player and also while playing cd's.
It could be the volume settings on the player tht the websites use to play the audio or the video,
Jan 30, 2008 | Neovo E-19A 19" LCD Monitor
Lenovo ThinkPad T410 Core i5540M 253GHz4GB320GBDVD+RWabgnBTGNICFR141" WXGA+W7P (252225U) PC Notebook Logo
51 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
