Question about 3Com AP 9552 DUAL RADIO 11N WX 30005000 SERIES MANAGED AP (3CRWE9552A75)
Hi, I have a AP 3com 9552, but this is reset every 5 minutes and it appears for console, that this resetting. how I can restore factory settings? Thanks
samrat
  • 10 Answers
SOURCE: 3crgpoe10075 status led blinking with no stop
hi ,,, i got yor problem. as ya said its not allowing ya to log nto it with security enabled. Ya can try to log into it with the ethernet cable as their wil be an ethernet LAN port onthe access point. I f ya know the default or the present ip of AP then ya can assign a static ip of the same range to yor computer like eg. ap is 192.168 .1.1 then your comp can have 192.168.1.10 and ya can log into it thru the ethernet cable and disable the security. i hope ya know how to assign a staic ip add to yor compuetr. or check the screen shots on brivers.com n select the "network connections" screen shots to assign a static ip address to yor' comp. feel free to chat with me on samrat101 thru yahoo or msn messenger or drop a mail on samrat101@yahoo.com for ny wless n ipphone issues -- take care ,, samrat
Posted on Mar 08, 2007
SOURCE: DWL-2100 AP will not reset to factory defaults with reset push. Ideas?
Reset, hold for 10/15 secs, do it again 3 times total. Then it works.
Posted on Feb 27, 2008
mhusa68
  • 10 Answers
SOURCE: Factory Default Motorolla Canopy 900mhz. AP
all you need is a phone cord (that you dont want to use anymore) just ground the number 4 and 6 wire together and leave the rest alone. plug it in the canopy and then power it on. It should then be at the default ip. I think its 169.254.1.1 or 192.168.100.1.
Posted on Dec 13, 2008
rahul26485
  • 611 Answers
SOURCE: I have 2 3COM 3CRWE454G75 -> AP, it does work in AP repeater mode
find the ip address problem or the firewall of there or proxy servr is there and re-configure it then you get the it and check the region if not same that also creating problem sir,
Posted on Mar 06, 2009
SOURCE: Default IP address for symbol spectrum24 ap-4131
Try 10.1.1.1
Posted on Apr 23, 2009
How to RESET Motorola AP 6532 Access Point to Factory Default?
This is the reset username Username : reset Password:
MAC address XX XX XX XX 10 20 = IP address of 169.254.16.32 *10 in Hex = 16 in Dec *20 in Hex = 32 in Dec
Apr 29, 2012 | Motorola AP 6532 Access Point
3com AP 7250 - how do i reset it to factory defaults if i don't have the admin password ?
It will have a reset button on it, hold it down for ten seconds and it should reset the router to factory.
Mar 12, 2012 | 3Com Wireless LAN Access Point 7250...
I want to reset the user name and password for router 3com 5012 model No. : 3C13701
there is a reset button on the back of the router you must press it for about 30 seconds plugged in or not plugged in i cant recall so try both and that will bring it back to stock settings for password and all. please let me know if that was helpful
Mar 14, 2011 | Computers & Internet
How to reset to factory default a Cisco Aironet 340 (AIR-BRI342)
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal; other programs are similar.
  3. In the Connection Description window, enter a name and select an icon for the connection and click OK.
  4. In the Connect To window, select the port to which the cable is connected and click OK.
    1. In the Port Settings window, enter the following settings:
    2. 9600 baud
    • 8 data bits
    • No parity
    • 1 stop bit, and
    • Xon/Xoff flow control
    1. Click OK and press Enter.
    2. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    3. When the bridge or AP reboots and the Main Menu screen reappears, typ
    4. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
    5. Open a terminal-emulation program on your computer.
    6. In the Connection Description window, enter a name and select an icon for the connection and click OK.
    7. In the Connect To window, select the port to which the cable is connected and click OK.
    8. In the Port Settings window, enter the following settings:
      • 9600 baud
      • 8 data bits
      • No parity
      • 1 stop bit, and
    9. Click OK and press Enter.
    10. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    11. When the bridge or AP reboots and the Main Menu screen reappears, type 2 to select Reset and press Enter.
    12. Type yes and press Enter to confirm the command.
      Note: The Reset command is valid for only two minutes immediately after the bridge or AP reboots. If you do not enter and confirm the Reset command during that two minutes, reboot the bridge or AP again.
    13. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.e 2 to select Reset and press Enter.
    14. Type yes and press Enter to confirm the command.
    15. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.
    Apr 17, 2009 | Aironet BR500
    Here are the steps to reset the access point from D-Link's website:
    Please visit http://support.dlink.com/faq/view.asp?prod_id=1600 for complete FAQ and screen shot.
    The following reset procedure will completely restore the default settings on the access point including your password.
    Step 1 Locate the reset pinhole on the back of the unit.
    Step 2 With the access point powered on, press and hold the Reset button.
    Step 3 Hold the Reset button for about 10 seconds.
    Step 4 Release the Reset button.
    Step 5 The device is now at factory defaults.
    You can find the complete manual for your wireless access point here:
    http://support.dlink.com/products/view.asp?productid=DWL-2100AP
    Mar 15, 2009 | D-Link Computers & Internet
    Mar 04, 2009 | 3Com OfficeConnect (3CRWE454G75)...
    How to probe the configuration or reset the 2700AP?
    Restore it to default, with these things, if it wont work on automatic, then something is worng.
    Feb 27, 2008 | D-Link AirPremier DWL-2700AP 802.11g/b...
    Nov 23, 2006 | 3Com OfficeConnect 802.11g/b Wireless...
    3Com AP 9552 DUAL RADIO 11N WX 30005000 SERIES MANAGED AP (3CRWE9552A75) Logo
    134 people viewed this question
    Top 3Com Computers & Internet Experts
    steve morris
    steve morris
    micky dee
    Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
