Question about Whirlpool WED7500V Electric Dryer
I need to replace the door switch on a Whirlpool model WED7500VW. How do I go about doing this. Is there a step by step instruction manual for this repair. Thank you Keith Gillespie
2 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: I need to replace a door switch on my Whirlpool Duet dryer. How?!
look toward the bottom the screws are recessed upward to hide them then it should open up like a car hood and there are spring clips at the top
Posted on Nov 01, 2009
Michael Pryor I got a dryer model number.WED7500VW, is not turning on door switch onewire Was burn....
The door switch activates when the dryer door is closed. On most dryers, the door switch makes an audible clicking sound when it activates. To determine if the door switch is working, try starting your dryer and then listen for the "click." If the door switch makes a clicking sound, it is probably not defective. If you don't hear a click, use a multimeter to use the door switch for continuity. If the switch does not have continuity, replace it.
Aug 30, 2016 | Dryers
Need Manual or instruction sheet for Whirlpool Gold Conquest Model # GS5SHAXNQ
Manuals and Troubleshooting ' Whirlpool
www.whirlpool.com/manuals/
Whirlpool Home AppliancesFind your Whirlpool appliance manual and any other appliance related literature such as use and care guides or model specific information.
[PDF]REFRIGERATOR USER INSTRUCTIONS - Whirlpool
www.whirlpool.com/.../Use%20and%20Car...
Whirlpool Home AppliancesPERFORMANCE DATA SHEET. ... your old refrigerator, please follow theseinstructions to help ... If door removal is necessary, see the instructions below
Nov 28, 2015 | Whirlpool Refrigerators
Power button doesn't work
Could be other things, like no 220 volts just 110, door switch, control board, thermostat, thermal fuse, motor broken belt.
Jan 21, 2014 | Whirlpool WED7500VW Laundry : Dryers
I have a Whirlpool Gold Ultimate II dryer. When the door is opened on the dryer, the light does not come on and the clothes do not stop spinning. I think there is something wrong w/ the swich inside the...
This video will show you step by step how to replace the door switch It does indeed sound to me as well that your stop on and the door switch is the problem
GENE
Sep 05, 2011 | Dryers
I was cleaning my self cleaning whirlpool accubake oven and a F1 and E7 code appeared. I have just bought my house and the prior owner did not leave any manuals. Help please
Most Whirlpool appliance manuals are available from Whirlpool: http://www.whirlpool.com/owners-center/owners-center-homepage.content.html . You will need the model number from the oven. This should be located behind the oven storage drawer on the rim. It will usually be on the left for a range and on the right for a wall oven. On rare models the plaque with the model number will be behind the door. If you add a comment with the model number, I'll try to post a direct link to the manual.
Are you sure about the error code? F1 and E7 aren't in my code books. I have an F7 and E1 code that indicates a short between the door switch or latch switch and the chassis or ground. (For double ovens, there are two of the switches for each door. The code doesn't specify which oven has a bad switch.) The F5 E7 error is a door latch that will not unlock. An F3 E7 error indicates that the warming drawer sensor has shorted out.
For the F3 E7 error, simply replace the sensor. For the other two errors, the solution depends on the door lock state. You start by unplugging the oven and checking all the wires and their connectors. See http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool%20Range%20/%20Stove%20/%20Oven%20Fault%20Codes for the complete set of steps. If the wires/connectors are okay, you probably need to replace one of the door switches if the oven door was locked when the error occurred. If it wasn't locked, then you can check the voltage to the various switches and replace any that are bad. If it isn't a switch, then it is the control that has failed and must be replaced.
I hope this helps.
Jul 02, 2011 | Ovens
Need urgently Door handle for whirlpool refrigator model GNF 220X
Check with Repair.Clinic.com. They have replacement parts for a large number of appliances. Step by step replacement instructions are also available. You'll need the approximate year of manufacture, model #, and serial # of the refrigerator.
Mar 06, 2011 | Whirlpool GS6SHAXMB Side by Side...
I have a whirlpool duet model gwp9400plo and I need to replace the door lock switch. How do I do it?
Hi
This is quite simple you take your door seal off the front portion of your panel take two screws off holding the door switch , i beleive the tool you need is a torx20. Once you have it unplug quick connect wires and reverse procedure for installation.
TY
Luigi
Feb 23, 2011 | Whirlpool GHW9400 Duet Washer
LHW0050P Whirlpool washer?
As I understand, when you order the door boot, an instruction paper comes with it. I have done it but each model and make is different. I would research the net also.
Feb 07, 2010 | Whirlpool LHW0050PQ Front Load Washer
Leaky Door Seal
You can follow this link for step-by-step instructions on how to replace the door bellow:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
I hope this is the information you needed. If you have questions, please post back and let me know.
May 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WED7500V Electric Dryer Logo
108 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
