Question about Kenmore Washing Machines
Washing machine leaves lent on cloths - Kenmore Washing Machines
    Genius:
  • 1,140 Answers
Find and clean your lint filter
Posted on May 20, 2011
Where is the lent trap on the estate washer
If it is like my Kenmore washer, you need to remove the front panel at the base of the machine. You should see the trap front and center, caution when you open the trap there will be water coming out. good luck
Sep 06, 2014 | Estate Washing Machines
My Kenmore washer does not have a lent trap ,so where does the lent go ?
The lint goes out with the drain water, most of it. The rest of the lint gets attached to your clothes. If you have a much older machine, you will see gray streaks of stuff sticking to your clothes, sheets, etc...and that's the lint.
Sep 21, 2012 | Refrigerators
After every wash the lent stays on the clothes
here are a few suggestions Two things that come to mind...1) Your wash time is too long. Unlike front loaders, top loaders clean quickly. No need to use the longest wash setting unless the item is really dirty.
2) You are overloading the machine. Items should move freely and circulate from top-to-bottom several times during the wash.
3) try using more detergent, One of the things good detergent does is keep lint (and dirt) suspended in the water and off your clothes. 4)http://www.ehow.com/how_2083872_clean-washing-machine-lint-trap.html
check that link for lint traps in washers
Jul 21, 2011 | Washing Machines
My washer has a little water left in the bottom of the drum and the washer has a smell of mildew. The pump is pumping great but isn't finishing the job. What would be the problem?
Hiya,
sometimes you can get a buildup of lint in the drainige system try checking the waist pipe & drainige pipes if you have a build up of lent in them or if the waist pipe is pushed to far down a drainige this can reduce the amount of water escaping & leave it in your machine or cloths the smell would be a sign of old water so those would be my surgestions to try & soilve this problem.
Hope this helps
Apr 23, 2010 | Washing Machines
Dryer turns on and rotates. However, does not dry clothes completely. Cycle signals wet,then damp,cool down and finally dry,but clothes are still wet. Sometimes the dryer works fine and completely dries...
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
Mar 21, 2010 | Kenmore Dryers
Lent in waterhose
Lint is nothing more than broken fibers in the fabric. To minimize lint, make sure you don't overload the machine. Loosely load items to the top row of holes in the tub. With a full oad, select the highest water level and use the proper amount of detergant. If you have a two piece agitator, verify the upper section turns one way like a ratchet. This action keeps the load circulating so the same items are not at the lower section of the agitator thoughout the wash and rinse cycles.
Apr 27, 2009 | Washing Machines
Lent on clothes
Not familiar with this model but it sounds like too little water is being used (small, medium, large load) or a rinse cycle is being skipped.
With enough water and normal rinse cycles, the lint should be suspended and pumped down the drain. If this is happening with every load, then it isn't working properly.
Dec 15, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine Kenmore 110
is the clothes coming out of the washer with lint on them or after they come out of the dryer ,,,, the washer doesn't take all the lent off ... the dryer does so i would make sure the vent duct is open all the way out of your house and the dryer filter is clean.
Nov 07, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
65 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
