Question about Sennheiser PXC 250 Consumer Headphones
One side of the headphones does not give sound consistently... if I jiggle the connector to the ipod and hold it at a certain angel I can get sound to both headphones, but I'd like to find a real solution
  • 670 Answers
Well the good news is, it's not your ipod.. It's the wiring inside of the headphones. I suggest that you either return them for a new pair, or buy a new pair.
Posted on May 20, 2011
My ipod nano has songs but no sounds
Step 1:
Since entering the marketplace and revolutionizing the way people experienced personal audio, Apple's iPod has become the unquestioned leader in MP3 players. Available in several different models and versions including the original iPod, iPhone, iPod Nano and iPod Touch the iPod allows people to listen to any number of songs with just the click of the button. However, as is the case with numerous electronics, certain iPod users encounter issues with their device, particularly sound issues. These issues range from buzzing sounds through the headphones to low volume quality to no sound at all. Fortunately, there are ways to attempt to remedy these sound issues.
Volume and Song Selection Oftentimes, those iPod users listening to heavier music (such as rock or hip-hop) will encounter a buzzing noise when playing their device at maximum or near-maximum volume. Try lowering the volume a bit, as this will most likely remedy your buzzing issues. Also, try playing a different song from a different artist at the same volume to ensure sound quality is optimal across the board. Check the Headphones Before attempting to diagnose an iPod's sound issues, ensure the iPod itself (and not the headphones) are the culprit for these sound issues. Do so by disconnecting headphones from the iPod and playing them on another device, such as another iPod, a PC or laptop. If the quality is still not optimal, the headphones (not the iPod) are likely the reason for low sound quality. Also try connecting an iPod to an iPod listening dock. If the sound quality is optimal, but not so when connected to headphones, that would also indicate headphones as the cause of low sound quality. b> Reset the iPod Sometimes, simply resetting an electronic device such as an iPod, digital cable box or video game system will remedy the solution, as it gives the device a chance to reboot. Try resetting the iPod to remedy whatever sound problem you may be encountering, whether it's no sound or less-than-optimal sound. Not all iPods are reset the same way, so consult the user manual (either paper form or through Apple.com support) to learn how to reset a particular type of iPod. Adjust Sound Settings If sound quality is less than optimal, including too much bass, not enough bass, poor acoustics or any number of other issues, try altering an iPod's system settings to correct the issue. Do so by going to the "Settings" key on the main iPod menu, then going to "EQ." From there, test certain settings to see if they may correct the iPod's issue. EQ settings allow users to set their music to a certain type of genre (in terms of how the music is delivered), as well as lowering bass, increasing bass and altering acoustics. b> Make Sure Headphones Are Fully Connected As simple as it sounds, sometimes the reason iPods have no sound at all is because their headphones become somewhat detached from the device. Such is the case with physical activities such as exercising or doing yard work. If no sound comes through the iPod, make sure the headphones are plugged in all the way to ensure the lack of sound is not a simple oversight. Consult Apple Support Whatever the sound issue, if iPod users have tried everything possible to remedy the problem with no results, they can call Apple support or visit an Apple retailer to help further diagnose the issue. The issue could be a simple fix or might be so severe that purchasing a new iPod is the best course to travel.
Feb 09, 2013 | Apple iPod nano 3rd Generation
IRiver E100 headphone jack
The connector is defective - probably just wear and tear
Aug 15, 2017 | iRiver E100 Digital Media Player
When I plug my headphones into my iPod, there is no sound, unless I jiggle the cord around and do not plug them all the way in. They worked fine at the beginning, but do not work now.
I'm not certain it's not the I-Pod socket or the headphone jack that is playing up? If you can get another pair of headphones (a friends etc) and put them in the socket of the I-Pod, to test it that should clear it up. For if they don't work you know it's the I-Pod socket that's faulty.
If it's the Bose jack that's gone, you better see my tip on dodgy cable/plugs on headphones. You should be able to replace it with the 3.5mm type shown, but I think you can get the thinner type jacks.
Jul 09, 2010 | Bose in-ear headphones - Black with...
Head phone jack
Flip the Sansa face down with the headphone jack to the left. Take the cover off the battery then remove the 2 screws by the sync port. This frees up the plastic that covers the last screw. But before you can remove this piece you need to lift the 2 black tabs in the middle and slide your nail between the seam between the black and silver areas near the hold button. The rest comes apart easy or the couple I have fixed the headphone jack have.
Jan 05, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
IPod MA146LL/A no sound
You should check and see if the headphone jack is broke or not. That sometimes accounts for the reason why sound won't come out.
Go here to see about replacing/fixing a broken headphone jack:
http://store.ifixipodsfast.com/ipod-parts-/-installation/ipod-video/ipod-video-headphone-jack-/-hold-switch/prod_69.html
May 10, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod nano audio hear only one side
I tried many good headphones but the problem is still there. Actualy I openned the ipod cover and fixed the connector. This is required handy person to do this task. I am not recommend for those who doesn't have patient and handy to do this fix.
Dec 24, 2007 | Apple iPod nano
Bad connection
It sounds like you have two problems. One is your ipod earphone plug ( phono plug ) needs replacing, and # two is your headphone plug needs replacing.
Nov 30, 2007 | Bose on-ear TriPort Headphones
Sound out of one speaker only
I think it's probably a damaged audio jack. If you're still in warranty, get it off to Apple. If not, you've got 3 choices;
1. Attempt to fix it yourself. I managed to get stereo again by opening the ipod up and inserting a staple in the bottom of the jack, to fit between the headphone and the ipod's audio input. This took some fiddling around, using tweezers, and will probably not last long if I take it out somewhere. I might attempt removing the audio jack and seeing if I can bend the metal connects for the right audio channel so they touch the headphone cable again. An alternative to this method would be to put some cardboard in the audio jack socket and adjusting it so that it brings the hardphones back into contact. Someone did this and posted the results on their blog, but I forgot the URL...
2. Buy a new audio jack and replace it yourself. There's an ipod repair wiki out there, and several of the replacement jack suppliers have detailed instructions. It's about 40 UK pounds for the replacement though....
3. Get someone to repair it. Expensive, about 60 quid, but perhaps worth it if you're scared of further damaging your precious beast.
Note though that there have also been issues with software updates and audio output, search the apple discussion boards for more details...
Nov 08, 2007 | Apple iPod MA446LL/A MP3 Player
Sennheiser PXC 250 Consumer Headphones Logo
303 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
