Question about Garmin nuvi 1450 GPS Receiver
Just bought a nuvi 1450. missed setting the country as USA. now it is in a foreign language (Uraguay, I think) and I cannot figure out how to reset it
  • 343 Answers
Go into tools setting to language and set to American English and hit restore. Then I would go to the Garmin site and update your 1450. Make sure it is fully charged first, I will attach the like to Garmin.
Thanks for using FixYa
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
Posted on May 20, 2011
Tip
Garmin Nuvi 1450 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1450 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1450 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1450 Manual Download
Garmin Nuvi 1450 QuickStart Download
Garmin Nuvi 1450 Webupdate
Garmin Nuvi 1450 Favorites Backup
on May 27, 2010 | GPS
Tip
Garmin Nuvi 1450 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1450 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
How do i restore my garmin nuvi 205 to its original factory settings? i have selected a foreign country by accident as default
With the satnav turned off press the bottom right corner of the screen and turn it on. This brings up an option to reset it. There may be an easier solution however that will not lose you your favourites etc. I presume the problem is that it's in a different language and you want it back to English. Resetting it will not do this. To get back to English;
  • Press TOOLS (The spanner symbol on the bottom right corner of the screen which shows WHERE TO and VIEW MAP) This may take some trial and error if it's in a foreign language but should be possible)
  • Press SETTINGS (The spanner icon) or LOCALE (the blue icon) on some models that don't have a settings menu)
  • Press LANGUAGE (the lips icon)
This brings you to a screen with 3 items; VOICE, TEXT LANGUAGE and KEYBOARD. Press each one in turn and select English or American English if you're in the USA. With the VOICE setting you may have to select a name rather than English. If so select the name of a person from an English speaking country.
I hope this solves your problem.
Jun 02, 2011 | Garmin nuvi 205W GPS Receiver
I have the nuvi 205W series in a foreign language and can't get it back to english
  • Press TOOLS (The spanner symbol in the right bottom corner of the screen that shows WHERE TO and VIEW MAP)
  • Press SETTINGS (The spanner symbol) or LOCALE (the blue symbol) on models that don't have a SETTINGS symbol.
  • Press LANGUAGE (The lips symbol)
This takes you to a screen with 3 items; VOICE, TEXT LANGUAGE and KEYBOARD
Press each in turn. The VOICE will give you the option to select a voice by name and country. Select one that's from an English speaking country to get the voice prompts in English.
Press TEXT LANGUAGE and select English or American English if you're in the USA.
Press KEYBOARD and Select English. This should solve your problem.
Apr 12, 2011 | Garmin nuvi 205W GPS Receiver
Tip
Garmin Nuvi 1450 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 27, 2010 | Garmin nuvi 1450 GPS Receiver
Tip
Garmin Nuvi 1450 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
How do I change the country on my Garmin nuvi 255W?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Stuff happens. Try this:
This may be a result of a previous software version on a device or possibly some one changing the settings. If a device does power on with a foreign language that you can not understand it can be corrected by going through the settings to change the text language.
To change the text language:
  1. Touch Wrench icon on the screen with the Magnifying Glass and Map icon
  2. Touch the Gears icon
  3. Touch the down arrow
  4. Touch the second option from the top1
  5. Touch the middle blue box on right
  6. Touch the up arrow until American English appears2
  7. Touch American English
  8. Touch OK
  9. Touch Back
The device should be in selected text language.
Note 1 - In some cases, if there are Custom POIs loaded to the device then it may be the first option at the top.
Note 2 - If American English is not the language needed, please selected the desired language
Jan 29, 2010 | Garmin nuvi 255W GPS Receiver
Foreign language
Go into the wrench menu, find the locales menu (red lips) in that menu you are able to select the language/measurement/time settings
Mar 29, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 1450 GPS Receiver Logo
444 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
