Question about GE Profile DPSB620GCWW Gas Dryer
I need to replace the door switch on my GE Profile Gas Dryer DPSB620GC4ww and don't know how to get behind the panel on the front of the dryer. Can you give me detailed instructions on how to do this?
  • GE Master
  • 2,295 Answers
Unplug it,open the door and look up,you'll see two phillips screws,take them out and remove the top panel,if you want to remove the front panel just remove the two phillips screws one on each side of the panel around 4 inches down from the top.
Posted on May 20, 2011
  • Sal DeAngelo May 21, 2011
    how did you make out with your door switch
Guys is there a way to bypass the switch? mine broke in half, and i don't know how the wires connected.
Posted on Oct 11, 2011
How do I Disassemble a GE Profile Dryer to replace Drum Bearings? Model: DPSQ475ETOWW?
remove 4 torx screws from the top of control panel,then slide control panel sideways till you can lift it up off the top cover,then open the dryer door on the upper door land area there are 2 screws going up into the top cover remove them then you can remove the top cover,then on each side at the top there is a screw holding the front panel in place,remove these then you can remove door switch wires from the door switch and lift up on this panel to remove it off the gussets on the bottom of the door,then you can install the top door bearing and 4 drum slides
Nov 29, 2012 | Dryers
Admiral dryer super capacity dryer won't heat up and light doesn't stay on. It happened when we first brought it home years ago and the repair may said to reset some button but I don't kn
see this causes and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
GE profile gas dryer wont turn on. There is power to the unit.
The service manual is here:
http://www.affordableappliance.com/Download%20Folder/GE_Harmony_Dryer.pdf
Things to check
1. Belt switch and belt on page 26
2. Door Switch on page 25
3. The inlet manual; (reset) safety switch on page 30
4. The outlet thermistor on page 31
These 4 switches and thermistors control power to the control panel. Find out which one has failed.
Kelly
Kelly
Sep 26, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
My GE gas Dryer does not iginite and get hot. It turns or tumbles but does not get hot. Checked gas line everything ok with gas line. please provde step by step instraiuctions to replace the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 18, 2011 | Dryers
My ge profile dryer won't start.I checked the breakers and they were ok. Any other suggestions?
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 08, 2010 | GE Profile Harmony DPGT750EC Electric...
My dryer is making a scratching noise like something is stuck behind the drum toward the front of the dryer. Any help?
The drum has a seal between the drum and the front panel of the dryer. You would need to remove the top then the front panel to gain access to replace or maybe clean the seal
Mar 30, 2010 | GE Profile Prodigy DPSR513GA Dryer
I have a GE profile harmony gas dryer that says "a problem has been detected call 1-800-GE-Cares' on the display. I just finished putting in the new dryer drum that fell apart. Any suggestions? Reset...
If there were no problems before replacing drum I would go back and make sure all 3 wiring connections are made behind the door panel. From there this machine is too complex to diagnose over the phone.
Mar 03, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Ge profile 7.5 dryer front loading how to vent on the right (gas)
You should be able to vent in any direction.U might have to buy right part.
Oct 02, 2009 | GE Dryers
How do you convert back from propane to natural gas, I already have the orifice but don't know how to put it on?
If you have the rear control dryer you posted under:
1. Unplug power to dryer.
2. remove two phillips head screws behind door, just in front of lint filter.
3. Use putty knife to push in dryer top release clips at seam with dryer front, about a inch in from each side.
4. Swing top up and remove two phillips screws holding front onto frame at very top of front panel.
5. pull front panel forward a bit and remove plug to drum light and door switch.
6. lift front panel off dryer.
7. Turn off gas shut off and remove burner / valve assembly.
8. Replace orifice and change out brass pressure regulator screw.
9. reassemble and test.
Aug 06, 2009 | LG DLG5988 Gas Dryer
How to get the front panel off GE Profile Harmony
Here's a simple overview of what you have to do:
You actually don't remove the back sir, but that's okay, that's a common misconception for this model dryer. The proper way to disassemble this particular dryer is you start with the top. You have to start with the removal of the control panel, then the top of the dryer. What I would consider the top cover. Then you'll have to remove two plastic brackets. Then you have to remove the front. There's two aluminum brackets in each corner, remove those. Open the door and there'll be two more screws to remove on each side. You have to lift the front just a little and then pull towards you. I forgot to mention, before that part, you'll need to ensure you are disconnecting the electrical wiring. There's almost no chance of connecting the wrong ones even if you forget. GE made this part novice proof. Once you get the front removed, you'll see the lint/trap. There's a couple of screws on either side of the aluminum housing. Not much to it. Let me know if there's anything I can clarify further. Have fun!
Mar 31, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
GE Profile DPSB620GCWW Gas Dryer Logo
196 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
