Question about Kenmore Washing Machines
Kenmore series 90 is there some kind of lent trap or filter?
  • Kenmore Master
  • 2,510 Answers
No,everything gets pumped out into the drain.
Posted on May 20, 2011
  • Anonymous May 20, 2011
    Thanks
  • Sal DeAngelo May 20, 2011
    no problem,if i can help you with anything else just let me know.
Where is the lent trap on the estate washer
If it is like my Kenmore washer, you need to remove the front panel at the base of the machine. You should see the trap front and center, caution when you open the trap there will be water coming out. good luck
Sep 06, 2014 | Estate Washing Machines
Kenmore 90 series washer won't drain and go to spin cycle
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
If helped pl say so.
Apr 02, 2013 | Kenmore 15864/15862 Top Load Washer
Dropped something down my kenmore dryer 90 series model 110.60922990. I can see it at the bottom of lint trap but cannot reach it.
You will have to take the back off the mach then remove the lint trap cover I think there are 5 screws slide the cover the side and you should be able to remove whatever it is make sure to unplug the mach.
Jan 06, 2011 | Kenmore 64902 Electric Dryer
I have a Kenmore 90 series dryer. I want to clean the lent that has accumulated. I want to remove the lower front panel to do this. How do I remove that panel
Get a putty knife or flathead screwdriver. There are two clips between the top panel and bottom panel about 3 inches from the corner. Push your screwdriver/putty knife straight in and it will release from the top. Give a little pull. There you go!
Aug 19, 2010 | Kenmore Dryers
I HAVE A KENMORE 400 SERIES DRYER. THE LENT NO LONGER STICKS TO THE FILTER. WHEN I PULL THE FILTER OUT TO CLEAN IT, THE LENT SLIDES OFF THE FILTER CONTINUALLY CLOGGING THE VENT IN THE BACK OF THE DRYER....
Try cleaning the filter to remove any residue from dryer sheets (a dish detergent solution should cut the softener build-up). Be as gentle as possible. An old toothbrush is useful for this.
Also, a weak exhaust flow may be the culprit. Check the dryer vent line all the way outside for excess lint.
Your fan impeller (inside the dryer) may be loaded with lint, too.
Apr 29, 2010 | Kenmore 400 6943 Dryer
We have a Kenmore 110 6092299 90 Series dryer. The motor still runs - but no hot air, at all. I've tried timed and heat dry. Nothing. It just tumbles and it takes 4-5 rounds to dry. At first we were told...
Sounds like the heating element or the thermo-cut off. A vent being clogged for some time, can cause too much heat to build up and make the element or cut off fail. These are the 2 most common things.
May 05, 2009 | Kenmore 63942 Dryer
Kenmore 90 Series: Clothes very wet after spin cycle
I do not have this kind of washer, but I had same problem with my washer and I found the drain trap was full not allowing washer to completely drain. Hope this helps, Good Luck!
Feb 13, 2009 | Kenmore 23822 Top Load Washer
Washer Kenmore 90 Series
yes it has a lint trapped ..its on the bottom of wash basket,,its part of the wash basket..when the unit washes it traps the lint when the unit goes in to spin it shoots it down the drain,,i dont advice taking that out unless your a tech..now what you can do is fill unit with hot water and about a pint of bleach and let that do the work its also good for pipes,,this technic should have been a process 1 amonth ..
Dec 22, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore Heavy Duty 60 Series Soft Heat Large Capacity Dryer
i need to take the bottom lent door off. I have replaced the board and it still say's says to clean the lent door. i have with the one in the dryer, but need to clean the bootm .
Feb 23, 2008 | Kenmore 63942 Dryer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
