Question about Samsung HT-TX72 Theater System
Regarding HT-TX75 Whenever a DVD is played I have to go in menu I.e. Sound and turn hdmi "on". But this does not "stick". Have to do again when new DVD Thanks
    Brigadier General:
  • 8,546 Answers
HDMI audio is going where in your scenario? By default, the audio is assumed to be handled by the HT, not some external device. Does your TV have better speakers?
Posted on May 20, 2011
I want to use my TV's speakers with Samsung ht320z not surround sound.How?
You have to hook up the audio cables to the TV from the DVD stand alone player. Red and White is audio and Yellow is Video. The player will play movies and the sound should go to your TV speakers. If not you will need to set it on the TV in the audio source to play from your speakers on the TV. John
Apr 15, 2012 | Samsung HT-Z310T Theater System
I have a sky+ hd box connected to an lg 42LH300 tv through hdmi and an LG HT805SH home cinema through optical cable. Whenever i turn sky over i lose sound and have to turn cinema on/off to sound returns ...
One of the way to connect the whole system is using only HDMI cable version 1.3a. There is audio return channel built into the cable.So you do not have to connect the optic cable.
Sky box to TV using HDMI
LG HT805 to TV using HDMI. Even the Sky box audio will come back to the LG-HT through the audio return path.
Mar 08, 2011 | LG Televison & Video
My HT-TX75 DVD flashes a message
First thing to do is disconnect all your speakers at the back of the receiver, then turn it back on. If it does not go into protection, post a comment and I can walk you thru troubleshooting. If it still goes into protection, your unit needs to be serviced. Hope this helps
Jun 24, 2009 | Electronics - Others
My dvd home theatre system ht tx75 keeps shutting down
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 28, 2009 | Samsung HT-TX72 Theater System
I didn't solve the problem,however i called sam sung and I will be sending it in for repairs under warranty.
thank you
Jan 27, 2009 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Connecting TV and DVD for surround sound
HDMI is fantastic in that's the only thing you need to plug in to get what you want.
You'll need two of them however. Plug one end of the HDMI cord into the HDMI "OUT" on the dvd player and the other end of it to the receiver..labeled HDMI 'IN' Then, take the second cord and do that step with the receiver back to your big screen...HDMI OUT to IN.
Surround sound from TV sources only needs a L&R audio cable connected to the receiver input labled TV or MONITOR audio IN. Unless you'd like 5.1 dolby digital or DTS from the television that requires devices that you haven't mentioned owning. In that case you will be able to get Dolby ProLogic and Pro Logic II from stereo broad casted sources on your TV.
Jan 21, 2009 | Onkyo HTR500 Receiver
Samsung Series 6 TV - cannot get TV to go through Home cinema speakes
Ok, the Audio can only be transfered to the HT if it is connected via something other than the HDMI, (the HDMI is just 1 way accept for the Anynet function (which is great with the 6 series. I have the LE52-A656))
The audio can be transfered via component cables but you will get the best out of your system using an optical cable. The main reason for optical is it ability to transfer 5.1. Only problem is the Samsung does not output 5.1!! bugger!! one you have connected it via the optical too. just set the HT to D-IN and you should be goo to go! :) There maybe something i have missed but Im at work at the mo but let me know how you get on :)
Jun 15, 2008 | Audio Players & Recorders
My home theatre system (sAmsung DVD home theatre system HT-Tx75)shuts down automatically after 10 minutes of listening to the radio...it says 'protection', then shuts off. i checked to see if it was on...
Protection mode on a Samsung player most likely means that the unit is overheating due to a non or low functioning fan. Before taking it somewhere to be serviced turn the unit on and see if the fan in the back is functioning (it should be on whenever the unit is on). If it is not you can try gently blowing it out with a can of compressed air.
I am sure that you can have it serviced but it might be cheaper to purchase a new player.
Good luck and take Care,
-WN
May 06, 2008 | Televison & Video
Samsung HT-XQ100
Does it happen with all discs? Maybe clean the discs because I notice the player is pretty sensitive
Jan 14, 2008 | Samsung HT-HDP40 - 800 Watts 5 Disc HDMI...
Samsung HT-TX72 Theater System Logo
97 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
