Question about Vacuums
Where can I get a manual for a Fantom Thunder vaccuum model # F12052 00?
  • 5,127 Answers
The manual for the Fantom Thunder is available here: http://www.heparrest.net/Fantom_Thunder.pdf . If this direct link doesn't work, start here: http://www.heparrest.net/SuggestedMaintenance.html and scroll down to the Fantom Thunder.
I hope this helps.
Posted on May 20, 2011
  • tlyon61 Aug 14, 2011
    When you scroll down for the Thunder, it only gives you some of the manual. How to deal with blockage is on page 10 which never comes up.
  • Cindy Wells Aug 14, 2011
    Tryhttp://www.heparrest.net/Thunder-Mainten... (copy and paste the URL into your browser address bar). This has the section on replacing the HEPA filter and clearing blockages. Does that help? (Ehow has an article on changing the belt.)
I have a Fantom Thunder TH469KA and it shuts off after 5-10 min of running How do I fix this?
on all vacuum cleaners the air flow cools the motor. If the filter is sufficiently clogged there would not have enough air flow to cool the motor and trips out from over heat. Clean out the filter thoroughly and try again.
Jan 01, 2015 | Fantom Vacums Vacuums
Fantom thunder vacuum owners manual
Heparrest has the manual to the Fantom Thunder here: http://www.heparrest.net/Fantom_Thunder.pdf . You will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Nov 17, 2011 | Vacuums
I have an old fantom thunder upright and need to take the bottom off it to see what is stuck in it. I don't know how to do this.
moz-screenshot.jpgI found a manual for the Fantom Stick Vac, model FS801 (your model may be different).
For "Cleaning Air Driven Turbo Brush", it says:
  1. Remove the turbo brush from the hose or extension tube.
  2. Slide locking latch forward, then tilt the top housing of the brush upwards. The top housing is hinged and will tilt up approximately 45 degrees only.
  3. There may be some dust, lint, hair, etc. on the turbine wheel. Remove as much of this as possible.
  4. You may also use the unit's hose with the crevice tool attached, and use the vacuum to remove any additional debris from the turbine.
  5. Ensure that the turbine wheel moves freely by rotating it with your finger. If the turbine does not rotate, call Customer Service for help.
  6. Once clean, close the top cover of the turbo brush and slide the locking latch towards the rear of the brush to lock.
There is also an image in the manual that might help. You can download the manual for free here.
Hope this helps!
Mar 03, 2011 | Vacuums
I have a Fantom Thunder Vacuum. Missed placed my book. How do you replace the belt on the brush?
depending on your model, and I am going from memory on this one. I have not seen this model in a while.
1 headlight on the unit:
there are 2 screws on the back of the cover for the brush. Just above the wheels. Remove those two screws and the cover will come off.
2 headlights on the unit:
use a small screwdriver to remove the headlight lens covers, remove both of the light bulbs, and then the two screws are under the lights. there MAY be 2 more screws again at the back of the unit above the 2 rear wheels to remove as well. again the cover should come off and you will have full access to the belt/brush under there.
Nov 04, 2010 | Fantom Vacums Cyclone XT Upright Vacuum
Eureka Fantom Thunder 12V/older model Need instructions on how to change belt and headlights.I could only find 1 screw on the bottom plate none on top plate. Thanks N J
there are two screws on the Fantom Thunder (It was not made by Eureka though) on the back of the unit just above the rear wheels. Remove these two screws and the top cover can be removed to get to the brushroll, belt and headlights. I believe the light bulbs in this unit are 12 Volt, not 110 volt.
Jul 18, 2010 | Vacuums
Model Fantom Thunder (quite old) still runs,no suction from wand, very poor from bottom
sounds like you have something stuck in the air way you can flip the vac over and they had trap door you open to clean it you may have to use coat hanger straigten out with a small hook on the end
Feb 22, 2010 | Vacuums
Burning belt, I also ned to get in to where brush is.
The manual for your Fantom Thunder can be found by clicking this link on my business web site: http://www.sewvac1.com/Fantom_Thunder.pdf
May 07, 2009 | Vacuums
Sweeper belt
Greetings from GoVacuum.com,
Have you replaced the belt with a new one yet? You may want to try replacing the belt, as with flat belts like the Fantom Thunder, they do stretch out 4 -5 inches after time. We in fact recommended replacing a flat belt every year, even if the belt doesn't break, because of the stretching. I think what may have happened, is that your belt is stretched to the point where it will not stay on the pulley as soon as there is any tension (putting the brushes on carpeting), which will cause the belt just to slip off.
You should be able to replace the belt (very inexpensive, we sell Fantom belt for $2) and this should take care of the problem. When you replace the belt, you should also take the roller brush apart and remove any hair, or thread that may be wrapped around the bearings. You should be able to remove the bearing cap by pulling them, or holding one end, and unscrewing the other.
I'd even be willing to send you a free Fantom Thunder belt, if you'd be so kind to vote Fixya for this answer :-) Just send me an email with your name, address, and the exact model number (located on the back of the machine, or the bottom of it) of your vacuum, and vote Fixya, I'll immediately ship you the belt for free!
Please let me know if you have any other questions I can help you with.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
1-866-468-2288
Oct 13, 2008 | Fantom Vacums XT450K Upright Vacuum
Instruction manual
Go to www.fantom.com. In Support Wizard, type in your model number. You'll see a file called Product Manual. click it to open and print.
May 22, 2008 | Fantom Vacums FM741 Twister Bagless...
How do i open my cleaner to put a belt on
Thank you for your fast reply, I took off the screws on the lid and replaced the belt with no problem
Mar 14, 2008 | Fantom Vacums CW600 Upright Vacuum
Vacuums Logo
573 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
