Question about Dryers
Belt replacement How do I replace the belt for my electric dryer and can I purchase the belt at any Home Depot ...
  • 594 Answers
You can get a belt at most home depot. i would call ahead and ask to be sure. or you can call an appliance store. changing the belt it fairly easy. you will need to take the top off the dryer. you can do this by taking a flat head screwdriver and inserting it into the crack at the front of it. you will need to pry up on it. there are 2 metal clasps that lock down the top this is what you are trying to pry away from the dryer so the lid will come off. once you have done this on one side you will need to do it again on the other side. once this is complete you should be able to flip the top of the dryer back out of your way. please open the door of the dryer and look up where the door meets the frame. there might be 2 screws holding the top on as well.
once this is done you will need to locate your tensiner. find that and release it so the belt will come off. than you will need to slightly elevate the drum of the dryer to take the belt off and put the new one on. you dryer may be one you can the front off as well. if so than i would suggest you do so. it would make it alot easier to replace the belt.
after everything is done install the new belt. and put your dryer back together......
Posted on Aug 14, 2008
I am looking for a drive belt for a mastercraft 3x21 beltsander. the belt says 120xL031. cant seem to find one anywhere.
The belt you can replace with a is simply any generic 3x21 belt. You can find them at your local hardware store or order them from a website like Home Depot, etc and have them shipped to your home. Here is a link to take you to Home Depot specifically for an 80 grit, but you can look for other grits as well. 3" is your width and 21" is the diameter of the belt you need.
Gyros 3 in 21 in 80 Grit Aluminum Oxide Sanding Belt 5 Pack 12 32180 5 The...
Feb 14, 2015 | Tools & Hardware - Others
BROKEN BELT Let7848aqo Whirlpool
The belt is a 341241. You can get one on Ebay
How to tuneup and belt replacement
My home movie shows row to replace it:
Sep 05, 2012 | Whirlpool LER5636P Electric Dryer
Model # DBSR453EB2WW; sounds as if belt needs lubrication when operation dryer, high pitch sqeeking. Please advise.
The belt is attach only to the motor pulley and a tensioner pulley one of which is most likely in need of replacement...you could oil or grease them but that probably wouldn't last very long or work at all...??
Apr 19, 2010 | GE DBSR453EBWW Electric Dryer
Dryer will heat up but drum will not turn. Unable
Good day,
Sounds like a broken belt, Excellent tutorial on changing the belt on the link below.
Caution: Some models used a very poorly designed belt tensioner. If the tensioner is that style, replace it while purchasing the belt.
Appliance parts house counter men are well aware of the problem. The Roper line is made by whirlpool.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 04, 2009 | Roper REX4634KQ Electric Dryer
I Need to change the belt on a hotpoint TDC62 dryer, but I cannot see how to remove the front panel
first take off the top then remove the back most tumble dryers dont have a removable front pannel
Nov 27, 2009 | Hotpoint TDC32 Electric Dryer
Admiral Dryer: 5 cycle 3 temperature electric
Unplug Dryer
Remove back (many screws)
Clean lint from interior & Vent Chute
check for breakage & parts on dryer floor
check for burn damage (wires burned off or char)
if no burn or char:
could be the "Dryer Coil" itself broke or
a "Snap Disc" usually mounted on the coil housing.
Very Serious!!!! Replace only!!!! Do not ever bypass!!!!
Stay clear of dryer for test start
Be ready to shut it down fast in case of problems
Always replace back & vent chute
Good luck,
Vinnie
Jun 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Will not heat and belt is off
you can purchase a new belt from Sears on-line, or the brand you own. typically 20 dollars range. they come with directions to install the new belt, typically you remove the front panel of the dryer and replace the belt. it is not hard to do and really is best with 2 people. good luck!
May 10, 2009 | Estate EED4300TQ Electric Dryer
Whirlpool dryer does not turn
Your dryer drum drive belt has broken and requires replacement. You can purchase a belt online for $10.00 plus shipping.
Feb 22, 2009 | Maytag HYE3658AY Electric Dryer
Need to replace dryer belt.
screw on bracket of motor for tentsion release
Jan 24, 2009 | Whirlpool LEW0050P Electric Dryer
Broken drum belt
Some large hardware stores like Home Depot stock them. Most appliance parts stores sell to the general public. Marcone appliance parts in St. Louis will sell mail order. Have the model and serial Number available. I always replace belt , idler pulley and back support wheels together. They usually go bad about the same time. I'll bet that the dryer is pretty loud isn't it. The support rollers usually cause the belt to break or a stiff pully. Total parts cost is under 50 dollars
Jun 26, 2008 | Whirlpool LEB6200 Electric Dryer
Dryers Logo
219 people viewed this question
Top Dryers Experts
