I bought a new printhead for my Canon Multipass 730 printer, and would like to know where it is located in the machine, so that I can replace it with the new one.
  • 8,197 Answers
The print head is the part that holds all the ink in the printer. To replace it remove all the ink cartridges them once they are out lift the print head out. When the print head is out put the new one in then reinstall the ink and do a print head aliment. Manual on the link below if you do not have it. Under maintenance will tell you how to align the print head.
wss
.com/gds/9/0900002529/01/MultiPASS_MP730_700_Users_Guide_EN.pdf">http://gdlp01.c-wss.com/gds/9/0900002529/01/MultiPASS_MP730_700_Users_Guide_EN.pdf
Posted on May 19, 2011
Cannon multipass 730
Try reseating the printhead. Remove the ink cartridges, lift up the lock lever and then pull the printhead out at an angle (IIRC). Then reinsert the printhead and lower the lever. Then reinsert the ink tanks one by one; Press down until you hear the click. Close the scanning unit and hit Set to print the alignment page. Tell the printer which line in each column has the best print quality (most solid); this is the horizontal alignment. Then repeat for the vertical alignment.
Try resetting the printer (on/off cycling). If this doesn't work, you may need a new printhead. Unfortunately, this may not solve the problem and you may need to have the unit serviced. Printheads are not returnable once you install them (so if replacing it doesn't help, you are stuck with the spare.)
Good luck. I hope this helps.
Jul 22, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
My canon mp 730 has an alarm lit and says wrong cartridge. I tried removing print head and cleaning with alcohol...no luck...put in a different cartridge...no luck. What else can I do
On Canon that error means the printhead is bad, nothing to do with the inks. The translation from Japanese to English made the error confusing. You need to buy a new printhead, the part number is on the side of the printhead and starts with QY6-
Jan 31, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Alarm on screen says wrong cartridge, so I replaced the after market ones with canon and still wont work
On Canon machines that error means you need a new printhead, the cartridge is the printhead and not the inks. I believe that printhead is QY6-0049-000 but the part number is stamped on the side of the printhead.
Dec 15, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
I have a canon multipass 730. It will not work and
Wrong cartridge means that the printhead is bad. Don't take it apart yet, you need a printhead.
QY6-0064-000 about $60.00
Sep 24, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Canon mp 730 prints colours BUT NO BLACK
Sounds like you need a printhead, QY6-0064-000 around $40.00. The only other thing that could do that is the purge assembly if it's not cleaning the black part of the printhead properly.
Jul 21, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Mp 730 "Wrong Cartridge" have been using same cartridge w/o any problems
the cartrige has become faulty or the wire strip that connects to the cartrige holder is comming out or a wire in the strip is broke , a new cartrige would then do the same thing
Oct 18, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MP 730 no black
You can get the MP 730 for Data Bazaar for 120.00 with no shipping charges. Hard to pay 160.00 for a repair when a new one is so much less. Just FYI.
Gina
Apr 24, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Replaced Black Ink Cartridge reading empty
Do a printhead alignment. This will let the printer know your cartridges are full. Here is a link for your manual if you want one. If this doesn't fix the problem just add a coment and I'll be glad to come back and help you out. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=8000
Mar 23, 2008 | Canon MultiPASS C555 InkJet Printer
Canon MultiPASS MP700
I had the same problem. My 4 year old MultiPASS MP700 started banding magenta stripes across everything I printed.
I suspected the cyan printhead was clogged because the printhead tests showed two of the cyan columns as half missing.
Canon was less than helpful. I went off of my suspicion that I needed a new printhead. I found one from an online supplier for 50 bucks...better price than a new printer! I put the new print head in and it works like new.
http://www.precisionroller.com/print-heads-for-canon-multipass-mp700/products.html
Jan 14, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
MultiPASS F50
check the Canon Knowledge base at www.canontechsupport.com, it may be the printhead or unit itself.
Oct 23, 2007 | Canon MultiPASS F50 All-In-One InkJet...
15 people viewed this question
k24674
jasbo
jasbo
