Home | Philips | 30PF9946 30 in. HDTV-Ready Plasma Television | Philips FlatTV Black Scr...
Philips 30PF9946 30 in. HDTV-Ready Plasma Television
Problem for Philips 30PF9946 30 in. HDTV-Ready Plasma Television
Philips FlatTV Black Screen 30PF9946D/37
By smackywentz on Aug 14, 2008
I have a Philips flat screen, model number 30PF9946D/37. After being on for a few minutes the screen goes blank. I still have audio and the green light stays on. I've narrowed it down to two possible problems. It is either a bad temperature sensor (most likely), or it is the power supply causing it to short. I put the power supply board with all the heatsinks in the freezer over night and hooked it up today and it worked for a really long time. Then I turned it on after the screen inevitably went black and it lasted for a few seconds. This leads me to believe it is a bad temperature sensor, but I don't know where the temperature sensor is or where to get a new one. It also could be the power supply, as I have seen others with this issue. Any ideas? I see a lot of these questions on these boards with no answers, so I'm crossing my fingers. Also it is out of warranty and don't tell me, "Don't buy a Philips," or "Get a CRT." Thanks very much but this is what I bought and I would like it to work.
Same Problem
Feb 17, 2009
-   Out of nowhere I came home, turned the TV on, it flicked a little light for a second, and then total black. Green light is on. -   thev2istrix
Nov 05, 2008
-   black screen, quick flash, no sound, green led-   Guest
Nov 04, 2008
-   black screen with a quick flash of light while turning on. I also need help!!!!-   Guest
Sep 16, 2008
-   I have a Philips 47PFL5422D/37 I'm not sure exactly what happened. I went out for about 30mins. and left the television on and when I got back the screen was black. Everything else was fine. -   niya_35
Solution #1
posted on Nov 24, 2008
Not Rated)
acepayday
Rank: Apprentice
Rating: 0%, 0 votes
I have the same problem and was told by my local TV repair shop I needed a new LCD panel (at $2000!!!) which I don't believe for a moment since the panels themselves rarely fail. After digging around on the net, I came across a posting from "Arfa Daily" on the sci.tech-archive.com website which points to either the backlight inverter board or the power supply. So far, it is the only intelligent thing I've found that makes any sense. If anyone follows this up and sucessfuly repairs your set, please let me know! ....Acepayday
I will re-post his/her answer here but to read it yourself goto:
http://sci.tech-archive.net/Archive/sci.electronics.repair/2008-05/msg00508.html
  • Date: Wed, 14 May 2008 10:07:05 +0100
"Max" <maxg70@xxxxxxxxxxxx> wrote in message
news:hb6dnebEeZuhqrfVnZ2dnUVZ_sDinZ2d@xxxxxxxxxxxxxxxxxx
sstepanov@xxxxxxxxx wrote:
Hello! I have a Philips 30PF9946D/37 30" LCD that no longer turns on.
Upon pressing the power button, the status LED goes from green to
amber then to red.
Is this a common problem with these?
Thank you!
Could be ps board.
It's a common problem with all LCD TV sets. First, try unplugging the
display panel's backlight inverter board. It is very common for these to
fail and cause the set to revert to standby. Otherwise, it's most likely
that the PSU itself is faulty - also very common.
Examine it *very* carefully for bulged electrolytics on the secondary side.
Note that these may be 'hiding' under bits of heatsink, so look carefully.
Also, check all large and heatsink-mounted devices, for bad (lead-free !!)
joints, which is another common cause of your described symptoms. Other than
this, you're a bit 'on your own' with LCD sets. There are other possible
causes, such as bad sound output chips, but if you really do have a power
supply problem that's not one of the things described, then you will
struggle to get to the bottom of it without schematics, and an intimate
knowledge of switchmode power supplies. These LCD ones are infested with
monitoring circuitry for output voltages and over-current conditions, and
they all work on the standby supply, so if *any* unexpected condition is
detected either at startup, or during use, the standby supply is momentarily
stopped, which causes the system control micro to reset back to its 'sleep'
condition, removing the 'power on' signal to the power supply. Depending on
the set, that may then be an end to it until you try to bring it out of
standby again, or it may just keep trying on its own, causing a flashing
power light.
If you can prove which board is causing the trouble, you might want to
consider just replacing that board. PSUs and inverters for many sets, can be
found astonishlingly cheap on the 'net and e-bay sometimes.
Arfa
Was this helpful?
Yes
No
Popular Solutions for Philips 30PF9946 30 in.
Questions and Unsolved Problems for Philips 30PF9946 30 in.
Do you recommend Philips 30PF9946 30 in. HDTV-Ready Plasma Television?
Answer
Answer
Hi My Samsung LE40B650 starts on Ext2. I want it to start on HDMI1. Is this possible? I know how to... (More)
Answer
my philips 50 inch flat tv wont turn on,the green light comes on but there's no picture or... (More)
Answer
Non vesa - can you suggest suitable bolts thank you
Answer
Have you fixed it or gotten rid of it yet? Because if not, I have a solution for you. I had the... (More)
Answer
I use this tv for a PC monitor, HD satellite viewing, and XBOX 360. I was having intermittent... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips 30PF9946 30 in....:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
