Question about Ariens 34 In 344 CC Briggs Stratton Hydrostatic Zero Turn Mower
As running great and just started back firing and quit checked spark plug it getting spark can the timing slip on these engines?
  • 927 Answers
The timing may change if the flywheel rotates on the shaft. See if you can get to that part and ensure it is tight to the engine shaft.
Gary
Posted on May 20, 2011
95 buick wont start
Got fuel? Sounds crazy but you'd be surprised how many times I have poured a gallon of gasoline into someones car to get it to start.
No start condition is the most frustrating problem. More information on what happens when you turn the key would help......but basicaly you need 4 things to make a car start. Fuel. Air. Spark. Timing. Fuel, Air, Spark and Timing are needed to start/run. Asked about fuel, but is the fuel getting to the cylinder? Do you have fuel pressure at the fuel rail(s)? When you turn the key to the "On" or "Run" position, do you hear a whining sound coming from the rear (fuel tank area)? That is your fuel pump priming the system. No sound? Check fuses and relays associated with the fuel system. Air. You need air to the cylinder to make it start and run. Check your air intake and filter. Really clogged and dirty filter? Pull it out and try to start. No go? Put it back (change ASAP) and look for Spark. Spark includes battery. Are there any loose connections to/from your battery? Really corroded terminals? Clean and tighten the connections. Try to start. No go? Pull the spark plug wire off an easily accessible spark plug (grasp the "boot" as close to the plug as possible and wiggle back and forth easily while pulling - these boots and wire connectors are fairly delicate). Remove the spark plug (be careful and dont break it or cross thread it when putting back in) and pop the wire back on it and set the plug on top of your engine (away from the spark plug hole). Have someone try to start the engine. You should see the spark plug fire its tiny bright blue spark. If not, you have found your problem. The problem is likely a bad coil, bad coil wire, distributor cap, rotor or a combination of these. If you have spark, then it has come down to timing. There are lots of things that affect timing in modern cars. There are a couple of sensors that jump out - Crankshaft and Camshaft position sensors. These will generally quit working while driving and you will likely notice the problem beforehand with it running really rough and getting crappy mileage, and the check engine light will come on and give you all kinds of hints. IF you turn the key and nothing happens, it might be a broken timing belt, but again, those usually fail under working conditions. It is possible (rare) the timing belt slipped/broke when you last shut off the engine, but I would point at the other 3 things first (Fuel, Air & Spark). Hope this helps. Good luck.
Apr 22, 2014 | 1995 Buick LeSabre
Dodge caravan was running good turn it off and it wont start back ,engine turns over but no spark
No start condition is the most frustrating problem. More information on what happens when you turn the key would help......but basicaly you need 4 things to make a car start. Fuel. Air. Spark. Timing. - Fuel, Air, Spark and Timing are needed to start/run. Asked about fuel, but is the fuel getting to the cylinder? Do you have fuel pressure at the fuel rail(s)? When you turn the key to the "On" or "Run" position, do you hear a whining sound coming from the rear (fuel tank area)? That is your fuel pump priming the system. No sound? Check fuses and relays associated with the fuel system. Air. You need air to the cylinder to make it start and run. Check your air intake and filter. Really clogged and dirty filter? Pull it out and try to start. No go? Put it back (change ASAP) and look for Spark. Spark includes battery. Are there any loose connections to/from your battery? Really corroded terminals? Clean and tighten the connections. Try to start. No go? Pull the spark plug wire off an easily accessible spark plug (grasp the "boot" as close to the plug as possible and wiggle back and forth easily while pulling - these boots and wire connectors are fairly delicate). Remove the spark plug (be careful and dont break it or cross thread it when putting back in) and pop the wire back on it and set the plug on top of your engine (away from the spark plug hole). Have someone try to start the engine. You should see the spark plug fire its tiny bright blue spark. If not, you have found your problem. The problem is likely a bad coil, bad coil wire, distributor cap, rotor or a combination of these. If you have spark, then it has come down to timing. There are lots of things that affect timing in modern cars. There are a couple of sensors that jump out - Crankshaft and Camshaft position sensors. These will generally quit working while driving and you will likely notice the problem beforehand with it running really rough and getting crappy mileage, and the check engine light will come on and give you all kinds of hints. IF you turn the key and nothing happens, it might be a broken timing belt, but again, those usually fail under working conditions. It is possible (rare) the timing belt slipped/broke when you last shut off the engine, but I would point at the other 3 things first (Fuel, Air & Spark). Hope this helps. Good luck.
Apr 21, 2014 | 1994 Dodge Caravan
Willnot start unless you pull start it
Feb 06, 2014 | 1999 Ford F350 Regular Cab
Cold weather starting
Jan 22, 2014 | Mazda B-Series Cars & Trucks
No spark after car gets warm
You need to hook up a scanner or code reader and see what code is stored.
Jun 12, 2013 | 2001 Daewoo Nubira
I have spark from my coil but I have no spark from my distributer cap on my dodge dakota 1992 v8 5.2 liter
at the distbutor itself there is a part that is called the picup coil most of the times that is what goes bad.
Jan 24, 2013 | Cars & Trucks
Toro snowthrower model # HSK 635 won't restart, stated first time, ran about ten minutes, then died, put brand new spark plug in, getting good spark, just won't fire up, even when I tried a li
check and make sure its getting fuel. when trying to start, spray some engine starting fluid in spark plug hole. just a little bit. replace the plug then try to start it. if it starts then quits then its a fuel problem. fuel not reaching engine. good-day !
Jan 30, 2012 | Garden
Engine is back fireing
Backfiring can be caused if the timing has changed.
Judging from the age of your truck, it's quite possible that the timing gears have slipped. This will throw the timing of the spark off even if you set the timing according to the marks. The way to tell is to remove the #1 spark plug and crank the engine over in taps... until you get it up on compression in the #1 cylinder...you can tell if you put your finger over the spark plug hole as you tap it thru..
Then check the timing marks...if the marks aren't near the proper lcoation, it's probably the timing gear/chain...
This is a common occurence when after tuning up an older motor... the timing gets adjusted, and it's running good for a bit, then the timing gears jump and it'll backfire, spit, cough and make life miserable...
May 31, 2010 | 1986 Ford F 250
I have a 91 cutlass supreme that will turn over but it will not fire...where should i start looking??? different ppl tell me diff things i keep hearing coilpacks,ignition, and some modular thing!! plzz...
Are you getting any fire to the plugs? It could be the coil, ignition module, or even a broken or slipped timing belt. How many miles does the car have? Have you had starting problems in the past, or did it just stop working suddenly?
Dec 13, 2009 | 1991 Oldsmobile Cutlass Supreme
Onece in a while turn over wont fire. runs great other wise
your injector or fuel pump may be going out, next time when you check the issue, check your distubutor again and making sure you getting sparks, if you do have sparks than it has to be your fuel problems.
Jun 25, 2009 | 1991 Honda Civic
Ariens 34 In 344 CC Briggs  Stratton Hydrostatic Zero Turn Mower Logo
131 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
Are you an Ariens Garden Expert? Answer questions, earn points and help others
