Question about Brother MFC 240C All-In-One InkJet Printer
The black on my printer wont print. I have cleaned the ports about 7 times. The color prints fine its just the black. Is there anything else I can do. With the black not printing I can not receive faxes and print copies. Thanks
  • 1,218 Answers
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies. get more help to fix printer not printing black. hope this helps you.
Good Luck!
Michel
Posted on May 20, 2011
Kodak esp 5210 wont print black
I figured it out. If you are low on (25%) on either colors or black, then it won't print. Even if you load a new black cartridge and it reads as 100% black, it won't print because it will only print when BOTH cartridges have been replaced and reads 100%.
Same thing happens reversed with color being replaced.
So basically, ALL printers short you 25% ink and FORCE you to buy their ink more often. Kodak is no exception.
I have 100% black and 25% color and a BW only needed text paper won't print. I been through this before. *facepalm*
Apr 16, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
HP OfficeJet 6210 All-In-One not printing color
The issue sounds like it is with windows 7 you are going to have to go onto HP website and find the driver for windows 7 and update your driver for you printer on your computer
Jan 02, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Can the printer still print on low ink on colors? It wont let me print anything, even black and white. On windows 7.. any problems there? It says that the printer is printing the page. But the Cyan is low...
It will print with no ink it will just be patchy.
It is also best to not let them run out of ink as they dry up in the print nozzle a pain to get working again and uses a lot of ink as you need to do several head cleans.
You may need to turn it of at the power point then after 3 minutes turn it back on again.
Also reboot your computer it may have not have started properly.
This should reset it.
Feb 07, 2018 | Epson Stylus Photo R200 InkJet Printer
Kodak esp7 wont print black
Click on menu on the printer,scroll down and choose clean printhead or go to maintenance and then click on clean printhead .After that try to print. If issue persists,call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.Printhead is the part which holds the cartridges and has 4000 nozzles which sucks ink from cartridges.It Might have gone bad
Sep 28, 2009 | Kodak ESP 5 Printer
IP90 WONT PRINT BLACK
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head move to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head holder. Slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out of the tank.
5. Have several paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. My color and black and white print came right back!
Hope this helps.
Jan 30, 2009 | Canon PIXMA iP90 InkJet Printer
Wont print black but colors are fine,
Clean heads, clean heads, clean heads, etc. Then do the test print to see if the heads are open. I had similar problem with an Epson, had to clean the heads often, finally got to where the heads wouldn't clean so threw it away and bought another one (HP this time, the heads are included in the ink carts, haven't had to clean the heads at all.)
Oct 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Wont respond to computer and printing question
With the kodak printer there is only a single printhead.. When cleaning is done all nozzles are fired. if one color is out of ink and those nozzles fire they can burn out. Inkjet uses electricity to rapid boil the ink to make is squirt out. The ink acts like the water in your cars radiator, if there is no ink and the nozzle keeps firing it will fry. That is why you have to have ink in both cartridges.
As for your printer not responding you could try a different USB port. USB ports on the back of PC are best. A powered USB hub is even better. Try disconnecting all USB devices then re-connect only the printer and see if its responding.
May 01, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printer wont print anything in colour
Printer nozzle dirty/clog. Need new color ink. Goto printer menu and do the printer cleaning application there.
Aug 04, 2007 | Canon BubbleJet i550 InkJet Printer
Dell A940 Color Ink Problem
Do check the option and make sure that you have not inadvertently set it to black only- This could be computer wise or on the A940 panel. If you are sure all is well here Remove the scanner software and reinstall. Email Dell to See what they have to say
May 08, 2007 | Dell A940 All-In-One InkJet Printer
Brother MFC 240C All-In-One InkJet Printer Logo
100 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
