Question about Cell Phones
The phone does not come on . when i try to charge it . it dont charge .
    President:
  • 695 Answers
It might be that your battery is got dead
Or the PLUG IN charging of your mobile has some rust
First : check if your PLUG IN charging has rust or not ,if it has clean the rust with a blade carefully without you damage it.
If your PLUG IN charging is clean and seems good change your battery
Posted on May 20, 2011
Dont charge i think grounded.how to fix it
hi,its a charging port problem,so you need to take it to a mobile phone engineer to fix it up for you.it can be repaired so put your mind at rest.you can also try to test your battery by trying it on someone elses phone.thanks.
Mar 09, 2010 | Cell Phones
My w880i dont turn on it just blinks a red light i holded in "C" and it still dont turn on how do i fix it
the red light on my friends phone usually means it is charging the phone (it is totaly dead, then it comes to charge screen after few mins) it should be ok if you try to start it after a few mins of charge..
if not try getting a new battery, it might not be holding its charge.
Jan 04, 2010 | Sony Ericsson W880i Walkman Smartphone
New cell phone battery trouble
Dont talk or use mobile phone when the phone is charging its battery and charge your mbbile battery for 10 hrs continusly before intinal use Only Charge your mobile when it shows " LOW BATTERY " Dont over charge your mobile Use the mobile to talk only when the network signal is high else use sms facility to communicate Use only original charger to charge the battery
Oct 22, 2009 | Sony Ericsson TM506 Cell Phone
Nokia E71 power on / off issue
i think that you might have not properly charged your batterry before first use it is being noted that all mobile manufacture recommends at least 10- 15 hrs of continus charging of the battery with the phone swtiched off is needed to work effectively in the future if you do so life of the battery will incress and you can incresse the back up of the battery and it is proven also so charge the battery well and try and remeber only recharge the battery agin when a battery low signal is shown
these are some tips :
Dont talk or use mobile phone when the phone is charging its battery,
Only Charge your mobile when it shows " LOW BATTERY ",
dont use mobile if any water particals get inside the phone ,
use only orginal battery ,
Dont over charge your mobile,
Use the mobile to talk only when the network signal is high else use sms facility to communicate,
Change the mobile battery as soon as possible if it damaged,
Use only original charger to charge the battery,
when you try to remove battery make sure that the phone off,
if the phone is not using in long time remove battery and keep it safe,
Dispose the battery safely if its life is over
Oct 20, 2009 | Nokia E71 Smartphone
Every time I try to charge my phone it says "charging paused due to phone temperature being too high or too low" What causes this
very hot battery ... batteries dont like to charge if they are very hot or cold.
Turn your phone off and let it sit for a while before you try to charge it.
Better yet, bet a second battery and change it regularly.
Oct 13, 2009 | Samsung Propel A767 Cell Phone
The phone is not recognizing the backup battery. can someone please help me on how to charge or replace the backup. battery
The backup battery is located inside the phone and canno be replaced by normal methods. the phone needs be disassembled and the battery are solded on the board.
the lifetime of these bateries are very high, maybe 5 or more years, and the charge occurs every time when you charge the phone.
Try to leave your phone charging for more than 3 hours, and if the battery dont charge, try a master reset on it.
If ater all, the battery dont charge, maybe you make some mistake or shorted some circuit. Take apart your phone again and re-check all the steps to reassembly.
Good luck
May 23, 2009 | i-mate JAM Pocket PC
Phone wont charge or turn on
i don't know if it works a not, but give it a try. press the call key, and key in "3845#*850#" ( without quote ) and scroll down and press on device, and then charging> USB/UP Charging on/off
the "3845#*xxx# tricks works only for some phone. i dont own prada II, so i dont know if its work anot.
but give it a try
Mar 14, 2009 | LG Prada KE850 Cellular Phone
NTO ABLE TO CHARGE BATTERY
Try charging the battery for a long time.
Feb 29, 2008 | Motorola Mobility RAZR V3i Cellular Phone
NOKIA 6630 displays not charging when connect charger
hi dude,
>>> dont remove any thing from u r mobile, first confirm the problem where it is...
>>> first try to put the charge by using other charger... still u r getting same problem means change the charging unit
>>>good luck... thank u....
>>> dont forget to rating the solutions...
Feb 16, 2008 | Nokia 6630 Cellular Phone
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
