Question about Garmin nuvi 1450 GPS Receiver
My garmin nuvi 1450 cannot locate satellites - Garmin nuvi 1450 GPS Receiver
  • 343 Answers
Make sure the Garmin is fully charged and try driving with it on and it should find the satellites. If it does not work try this.
Then go to the Garmin site and register your product. Then download Garmin Updater and connect your unit with a usb cable directly to your computer and not thru a USB hub. Let the update go directly to the GPS and not a folder. It will take a few hours even with a fast internet connection. I have attached a link to the Garmin site. Thanks for using FixYa
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
Posted on May 20, 2011
SOURCE: My new Garmin Nuvi 1450 lost satellite signal more
I have the same exact problem. Satellite detection outside of vehicle before starting out was full strength, as soon as you get into vehicle strength drops off to practically nothing. Now start driving and it continually loses satellite reception even on the open road with no hills and a clear day. It was mounted as far into the front windshield as I could get it and still crappy reception. Very disappointing as a cheaper Tom Tom my sister has works flawlessly. Also my daughters HTC desire Z cell phone GPS works flawlessly even from the back seats in the van. Maybe 1450LMT is just junk, and I should look for a refund.
Posted on Jan 02, 2011
Sea Breeze
  • 4654 Answers
SOURCE: "locating Satellites"
When you purchase a Garmin product you are given a key upon registration. If your Nuvi is registered then you need to go to Garmin and click on support. Here is a link to Garmins home page. Hope this helps, Sea Breeze
https://my.garmin.com/mygarmin/marketing/register.htm
Posted on Jun 20, 2009
  • 40 Answers
SOURCE: Nuvi 660 not locating satellites
Try this and see if it fixes your problem...first disable bluetooth then follow these steps.
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the problem.
Posted on Jan 02, 2009
SOURCE: Garmin NUVI 660 - can not locate satellite
The nuiv 660 is the worse product Ihave ever purchased. For those whoe are thinking of buying a GPS research this product. It is the most unstable device I know. Considering I purchased it new and only less then 1 month down the track it starts crashing and doing completely what its not suppose to do it is not a good GPS to have. It is unreliable and you cant trust a system which freezes frequently and leave you helpless.
Posted on Nov 17, 2007
jerryg50
  • 1667 Answers
SOURCE: Garmin Nuvi 260
Check to make sure that the unit is not in demo mode. Go through the menus to find where the demo mode is located. Cycle it on and off.
If this does not work, I suggest calling Garmin tech support to find out if they have a simple solution.
In the worse case you will have to send the GPS in for service.
Jerry G.
Posted on Jul 01, 2008
GPS Garmin 1450 poor satelittle signal- can't find satelittloes
If the Garmin nuvi 1450 could find satellites at the same location and time before there's something wrong with the built-in receiver / antenna. Because it's not accessible from the outside it needs to be opened to check the antenna connections. Best is to check battery at the same time and replace it - once the problem is fixed.
At some locations there can be poor GPS sat reception - due to line of sight obstructions, such as trees, buildings. For a 2D fix it needs to "see" at least 3 satellites signals.
Jul 05, 2011 | Garmin nuvi 1450 GPS Receiver
Tip
Garmin Nuvi 1450 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1450 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1450 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1450 Manual Download
Garmin Nuvi 1450 QuickStart Download
Garmin Nuvi 1450 Webupdate
Garmin Nuvi 1450 Favorites Backup
on May 27, 2010 | GPS
Tip
Garmin Nuvi 1450 Favorites Backup and Restoration Procedure Models: Nuvi...
Would you like to back up a copy of your Garmin Nuvi 1450 Favorites and Waypoints?
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
I hope that helps.
Tip
Garmin Nuvi 1450 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1450 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Tip
Download Garmin Nuvi 1450 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1450 GPS?
Would you like a digital copy of the Garmin Nuvi 1450 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1450 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
Tip
Download Garmin Nuvi 1450 Manual
Have you lost your Owner's Manual for your Garmin Nuvi 1450 GPS?
Would you like a digital copy of the Garmin Nuvi 1450 Users Guide for easy searching of terms and quick reference?
The Nuvi 1450 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
Tip
Garmin Nuvi 1450 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 27, 2010 | Garmin nuvi 1450 GPS Receiver
Tip
Garmin Nuvi 1450 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
I hope that helps.
Tip
I hope that helps.
Tip
I hope that helps.
Garmin nuvi 1450 GPS Receiver Logo
2,662 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
