Question about Prestige Remote Start
Have a Prestige remote starter on a 2006 Corvette the wont seem to start the vehicle. How many times or what is the procedure to start the vehicle. The remote has a blue button with a key symbol on it?
  • dmitchell523 May 20, 2011
    Tried this procedure, did not work. Do you know want length warranty comes with the system?
  • Anonymous Mar 19, 2014
    prestige remote is dead also my key is dead
  • 3,018 Answers
  • To start your vehicle you have to push the transmitter button (key button) two times withing two seconds. If you do this and the vehicle does not start then there is an installation malfunction or a dead transmitter battery.
  • The vehicle will run for the designated time you programmed into it.
  • The parking lights will either flash or stay on steady depending on how it was installed.
Regards, Tony
Posted on May 20, 2011
  • Iron
    Iron May 20, 2011
    • Prestige offers a 1 full year warranty against manufacturer defects.
    Regards,
    Tony
  • Iron
    Iron May 20, 2011
    Regards,
    Tony
Why won't my Corvette start?
when you remove a battery ,the immobiliser is energized
try resetting the ECM using a scan tool
May 28, 2015 | Vehicle Parts & Accessories
Prestige car alarm/remote start not working properly
This would be difficult to give an accurate diagnosis without full details like:- what model alarm system or vehicle this is for!
sounds like it might be the starter connection to the key switch is disconnected!
Oct 13, 2014 | Prestige Remote Start
Not enough voltage comes out of remote starter to start car
Ck. your battery or jump car and see how it starts if the same. you could have cable or connection problem. Could be a bad starter! or battery. Some auto part stores will check it for free.
Mar 21, 2014 | Prestige Remote Start
Prestige APS787C wont start car
Try reprogramming the remotes: Turn ignition on, press and release programming/Valet button on antenna three times. You should here a short chirp, press the lock button on one remote. You should here a long chirp. Press the lock button on the other remote, you should here a long chirp. Turn ignition off. Test system.
Feb 11, 2013 | Prestige Remote Start
Ive disconnected from battery to disable then reconnected for new start it dings but will not tirn over done all i can think but will not turn over starter wont engage
If this is a Prestige alarm with a starter disable, turn ignition on, press and release valet switch. This manually disarms the alarm.
If your vehicle does not have a starter disable, then your issue is mechanical with the vehicle itself.
If your battery is fully charged, then you may want to check the crank fuse for the vehicle. If the fuses are all good, try starting the vehicle in a different gear, (R,N,D).
Aug 18, 2012 | Basic Remote Vehicle Alarm System
My preinstalled remote starter on my truck has a combination/sequence that the dealers salesman could not get roght bit twice to start pickup. im looking for fimiliar combination/sequences that my seem to...
If you have to press the vehicle's door lock AND the remote starter button...something is definitely wrong with the installation. If the prestige is a one button unit, try pressing the button twice within two seconds to start vehicle (press...thousand one, release, press...thousand two,release) this is the default setting.
Aug 05, 2012 | Prestige Remote Start
My preinstalled prestige remote starter has worked twice at the dealers and i got it to work once. my question is do this combination sounds fimiliar for a chevy 1500. lock doors...lock door again, ho
If it is an add on remote starter, then you would use the factory remote to start it. If using the factory remote to start there are a couple of combinations to start it. Try lock, unlock,lock for Prestige/Pursuit models. If Directed models, try lock, lock or lock, lock, lock. If its a GM remote starter, press lock and then hold the remote starter button(circle with arrow.
Aug 03, 2012 | Prestige Appliances Vehicle Parts &...
My truck wont start when i use the remote. the power in the tuck turn on but the truck never turns over. 2006 ford f-150
Sounds as if your immobilizer bypass is malfunctioning. To test, remote start vehicle. Check vehicle cluster (gages). If the immobilizer bypass is the issue, there will be car/lock symbol flashing rapidly. To confirm, put the key in the ignition(do not turn), remote start the vehicle. It should start. If the vehicle starts, remove key, remote start again without key. If the vehicle does not start, have the immobilizer serviced. If the vehicle does not remote start with the key in the ignition, the issue may be with the remote starter's starter output.
Jul 25, 2011 | Prestige Remote Start
I have a new prestige car remote installed recently and i have a problem how to shut off the alarm coz the installer did not or forgot to give me the manual. When i start the car remotely i press the...
You did not mention the year/make/model of your vehicle but, the issue appears to be the factory alarm. The installer failed to make the connection. If you intend to make the connection yourself I would need information pertaining to the vehicle. The (-) pulse before start wire for Prestige remote starters is black with a blue stripe. It is in a 4 pin connector at the module. This wire can be used to disarm the factory alarm before the remote start sequence.
Jan 23, 2011 | Prestige Remote Start
Cant remember how to use the remote
To start the vehicle, press and release the Key/Trunk button two times within 2 seconds.
Jan 15, 2010 | Prestige Remote Start
Prestige Remote Start Logo
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
