Question about Lumiscope 2215L Digital Ear Thermometer
Lost directions. Doesnt ever seem to work right, get inconsistent readings. Just put brand new battery in it and it is reading it as almost dead again. Not sure when and how long to push button before putting it in ear. Does not seem to matter what I do it is very inconsistent.
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
If it's brand new send it back to the store. It seems to be a faulty item, which would be covered under the manufacturer's warranty/
Apr 18, 2013 | Xerox ColorQube 9303 Printer
Metabo ssd impact loss of power
Thinking first to ask your dealer (if possible) before repair to try a second battery if you think its so, but the most LI-ION powertools , only with a carbon brush motor have in priority problems inbetween 2 and 3 years with their motor assembly because of heat dissipation in the armature, and you can hear that on the shrill sound , beware you make the battery damaged with an allmost shortened armature . if power is lost and or the sound is shrill, the assemblys are marketing technical made on a price that made it if your batteries are good to step over on brushless tools on some brands for not to much money. remplacements.
Mar 25, 2017 | Metabo Saws
Dead battery, replaced battery and alternator but still no charge!
if its not charging while running at14.5 volts or so you have a charging problem mabey no power to the alternator if its charging at 14.5 or so and the batery load tests good and its going dead over night you have a draw from some component in the system.
Dec 19, 2011 | 1994 Oldsmobile Cutlass Ciera
Inconsistent and unreliable readings
A flag is a hard object to get a reading on. It constantly moves and the sound or light waves (depending on the model) will not be reflected consistantly. Clean the sender lens and the receiver lens and install new batteries. Recalibrate the unit using something stationary, like a FLAT wall.
Oct 03, 2009 | Bushnell Pinseeker 1500 Rangefinder
Ps3 doesnt seem to be reading any ps3 game or dvd?? What can I do??
Ok remove any disc inside, unplug it completely and try to spray a can of air inside where you put the disc in. Then on top and the bottom of the unit there are vent holes for air, also spray air in there and behind it also. Then try using a brand new game because maybe you need to update you PS3 so it can read new discs. If that doesnt work let me know.
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
Red light keeps comming on and battery goes dead.
Alternator and stator....put a voltmeter on the battery - it should read about 12- 13 volts. Then start the bike.... when its running, the volts should increase.... if it doesnt....your charging system isnt working.
Jun 27, 2009 | 2006 Harley Davidson XL 1200 R Sporster...
Trucks battery dead Nothing when turning key, no signal or lights
most likely the headlight relay is stuck    replace relay.
Mar 23, 2009 | 1995 Dodge Dakota
Camera says brand new batteries are dead, then shuts down
It is possible that the batteries are dead (they might be faulty or too old) even when they are out of the package, though unlikely. Try another set of batteries, and if these don't work, you'll probably have to send it for a checkup.
Oct 28, 2005 | Fuji FinePix 4700 Zoom Digital Camera
Lumiscope 2215L Digital Ear Thermometer Logo
51 people viewed this question
Top Lumiscope Home Experts
Donni Steen
Tom Chichester
Are you a Lumiscope Home Expert? Answer questions, earn points and help others
