Question about Balboa Instruments BALBOA 30 kW HEATER W PRESSURE SWITCH 15 INCH M1 M3 SYS TUV 50145
My balboa spa says sl and isn't heating up - Balboa Instruments BALBOA 30 kW HEATER W PRESSURE SWITCH 15 INCH M1 M3 SYS TUV 50145
    Scholar:
  • 46 Answers
SLP or SL Message
If the SLP or SL Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Sleep Heating Mode.
If the SLP or SL Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Sleep Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
You can find answers to common spa panel messages on the following page:
COMMON SPA PANEL MESSAGES
Posted on Sep 09, 2011
  • Robert Brewer Oct 25, 2011
    how do I fix the sleep mode problem
My balboa spa is not heating everything seems to be working fine what could be wrong
check fuses for heater element if ok see if calling for heat if so check element if not calling for heat bad temp sensor replace
Sep 08, 2015 | Balboa Instruments Pool & Spa
If hot tub is in sl mode. How do I change it so temperature goes up
Hi, this sounds like a Balboa pack and topside control. press the temperature button along with the light button. This should put you into the filtration mode selection. Then toggle using the temperature control buttons until you find your mode ST for standard and EC for Economy or SL for sleep. You can find more information here. How to change the Filter Mode on Dream Maker Spa
Jun 05, 2015 | Pool & Spa
The instrumentation panel says "SL" and the spa isn't heating.How do I get it to heat again?
You have it in "Sleep" mode. Spa will not heat normally in this mode...
If the SL Message is Alternating with the Water Temp in the Display Screen (we call this "Flashing Sleep"), the Spa is Operating in the Sleep Heating Mode.
If the SL Message is ON Solid (Not Flashing) in the Display window of the panel, the Spa is Operating in the Sleep Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
SL or SLP is one of the Modes you can program your spa into:
EC - Economy
ST/Std - Standard
SL/SLP - Sleep
It is advised you keep your spa in Standard mode. Push the Jets button then immediately push the light button. Each press of the light button will scroll between these three modes.
Good Luck
Aug 27, 2013 | Balboa Instruments Duplex Digital Panel 2...
Balboa vl700s
itheats when circ pump is on.
Jun 22, 2013 | Pool & Spa
Balboa vs510s not heating
questions first:
is the heat indicator lighted up on the topside panel?
Is is tripping the breaker shortly after you turn the breaker on?
Is the tub running but not heating?
Rod
www.uspartscenter.com
888-521-6183
Jan 31, 2013 | Balboa Instruments Pool & Spa
Had a new heater element installed. won't go
You need to put the system into 'ST' mode. 'SL' stands for 'Sleep' and will prevent your spa from heating.
'Regards,
Ian.
http://hottub.synthasite.com
Feb 24, 2010 | Sys BALBOA SUV SYS 5.5kW W/ 120V 1.OHP...
How to Get Hot tub off sleep mode
press temp button and then the light button in sequence.
Nov 14, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
OC hot tub is getting SL error and does not heat. Model is M-09-MOC1545-3. Recently purchased and lost manual. Thanks.
sl means sleep mode and will not heat! try depressing the temp button the either the light button or the jet button usually that will change modes u want st or std mode which means standard. or if u have a mode button try that 1st. or email me a copy of control head to hottubbob2@aol.com for tips! thanks Bob
Oct 17, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
Balboa Instruments BALBOA 30 kW HEATER W PRESSURE SWITCH 15 INCH M1 M3 SYS TUV 50145 Logo
889 people viewed this question
Top Balboa Instruments Pool & Spa Experts
russlakeside
Level 1 Expert
Are you a Balboa Instruments Pool and Spa Expert? Answer questions, earn points and help others
