Question about XRS - 9930 Radar Detector
THE RADAR WORKS BUT I CAN'T SEE THE LCD SCREEN. IT'S VERY DARK
I have a proview lcd screen and it palys the tv shows in back ground but it's a dark screen like dark blue no picture. Volume and everything working but just no picture. What can i do.
Show a torch light on the screen for a distance, and if you can see the picture, the backlight is not lighting up. Check for its settings on the remote, if you have that option. Check also the settings of brightness/contrast/sharpness/color. If you still have problems, please call in a qualified service technician.
Jul 25, 2012 | Proview PA-37JK1A 37 in. LCD Television
Laptop LCD screen has a faint image or is very dark and i checked Lcd,Invertor, video cable and its working properly . i don't know what to do pls help me.
Sounds like the backlight has gone. What is the make and model - you may be able to get parts or you may be looking for a salvage one.
Apr 10, 2012 | Computers & Internet
1. What is the average life span of a marine radar? 2. Where is the TR cell located? 3. How to test a marine Radar?
The life span of the radar depends on its use.
There are consumables inside, mainly the Magnetron and the scanner motor assembly, the life of which depend on running hours. The life of Display is high compared to these two.
The TR cell is located in the wave path before the receiver(detector/MIC)
Most Radars have a menu function for 'Test".
Aug 05, 2011 | Furuno 1715 LCD Radar System GPS Receiver
HDR-SR12 - LCD Touch screen very dim , screen works but almost completely dark. tried increased brightness etc no help
My camera's backlight went dark. Occasionally it would work if I pressed just the right way, but it was basically toast. With the right external light you could sort of make out what was on the screen by back reflection of what was on the LCD screen.
Search ebay for an HDR-SR11 or HDR-SR12 flex cable similar to this one:
http://r.ebay.com/L4dWDQ
It's not impossible to replace, but it's definitely not for the faint of heart. Some offer a replacement service with it. I did mine and it works excellently. An $8 cable and about an hour (plus a lot of pictures-as-you-go for reassembly) is all it takes.
Jul 13, 2011 | Sony HDR-SR12 HDD Camcorder
Ihave a brothers PC-7500 and the screen is dark
When your Brother PC 7500 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the Brother PC 7500 LCD screen, or buy a new machine.Brother no longer stock this item direct, but there is an affordable replacement available.
Check this Link
May 29, 2010 | Brother Sewing Machines
A furuno 1715 lcd radar was wired to battery backwords
internal damage to the display, fixable by Furuno, and probably economically feasible (guess $250 with round trip to Furuno)
Nov 17, 2009 | Furuno 1715 LCD Radar System GPS Receiver
I am not picking up objects on my screen until I am right on them. Tried tilting the radar dome down foward to see if this would work to no avail. Any suggestions greatly appreciated.
depending on the type of boat you currently have it mounted on, you may be out of range. Also your radar may need tuning and make sure your rain and seaclutter is not too high. Make sure the rain clutter is off. If the radar is mounted on a sailboat and you're having this problem, it's most likely the height unless it worked before in which case it could either be the display or the radar components. Magnetrons which run the radar also have a life.
Oct 18, 2009 | Furuno 1715 7" Monochrome Lcd 2.2kw Radar...
Furuno 1622 doesn't work, water coming out cable at screen!
yes the cable should be replaced if you are lucky, the unit is still OK (display) Try the new cable, draped across the boat before rigging. If fault exists with new cable, replace system, or find a new display on ebay
Nov 17, 2008 | Furuno 1715 LCD Radar System GPS Receiver
Vehicle Parts & Accessories Logo
22 people viewed this question
Top Cobra Vehicle Parts & Accessories Experts
John Nolan
Jason
Are you a Cobra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
