Question about Cell Phones
I have a telepghone set - Model # KXTG 1061 and can't change the voice message. My phone # has changed and I need to re-rerecord the greeting. I have only a button that says CID and Menu. How do I do this.
  • 5,473 Answers
If you want to change the greeting for the answering system, make sure that it is on. Press Ans On on the base to toggle the answering system on or off. (Alternatively from the handset, when in idle mode, press Menu. Then press # 3 2 7 and the press the Off key. This turns the system on.)
To record a greeting message, press Menu. Then # 3 0 2 and use the up/down arrows to choose Yes. Then press Select. After you hear the beep, hold the phone about 8 inches away from you and speak your message clearly. Press Stop to end the recording (max length of 2 minutes and 30 seconds). Then press Off. To play back the greeting, press Menu # 3 0 3 . Press Off when done.
The manual for the telephone is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG1061-MUL.PDF .
I hope this helps.
Posted on May 19, 2011
Where do I change my message after hours when the phone rings
This function varies substantially depending on the make & model of voice mail system that you have. The voice mail system also needs to have a schedule defined that matches your (or your company's) business hours. Setting this schedule up is the responsibility of the system support person. From that point the procedure for recording your out of office or closed greeting will vary, per the make/model of voice mail equipment that you have. On some systems this is referred to as your extended absence greeting, on still others it is called your alternate greeting. On yet others they call it the 'closed' greeting. Hope this helps.
Apr 24, 2014 | Mitel Superset 4150 Like Phone
Our company uses the Panasonic KX-T7730 phone system. When I change the answering message, it is immediately followed by an outdated message. Changing the message works, but the old message still fo
When we set up a Panasonic voice mail system, you have a menu that plays. Usually, there is a Company Greeting, then a Custom Greeting. They are changed from mailbox 998 option 5 then 1 or 3 depending on which greeting you want to change.
Of course, you may not have a TVA or TVx voice mail system, but I'm guessing that's what you have. In all cases, the Company greeting plays in front of the Custom greeting. By default in a TVA it's probably both greetings 1. You can log into the system and play them without changing them to verify what's where.
Carl
Feb 10, 2012 | Panasonic KX-T7730 Corded Phone
How do I change voicemail greeting on Nortel Model T7316 phone?
feature 981
enter password
listen for promt to change greeting.
for main greeting
press feature 983
if 3 digit extensions enter 1020000 if 2 digit extensions enter 120000
press AA
press grtg
press 1
press rec
press ok to end recording
press ok
press rls
To Listen to the Greeting, press Play. To ReRecord, press RETRY. Press OK to accept Greeting.
Jan 11, 2011 | Nortel Lands Phones
Record greeting
What kind of voice mail system do you have? They all are limited to the amount of total storage available. It probably has one or more mail boxes that are full and using up your storage. If it is a call pilot 100 or 150 and you have call pilot manager access, you can click on "message usage" under the reports menu and it will tell you the current storage available. Hope this helps.
Bill C www.dyna-tech.us We also offer remote programming and tech support for the Norstar CICS, MICS and the Call pilot 100/150.
Mar 16, 2010 | NorStar M7310 Corded Phone
Change night message
the night mode message that is being used is the main phone's (phone with lowest Ext. number) night mode message that was customized through it's voice mail.go on the main phone and listen to its voice mail. (voice mail ext. usually 165)continue listening until you hear some options.select the voicemail management optionthen select the change personal greeting optionthen select the after hours greeting optionhope this helps!
Feb 19, 2009 | Toshiba DKT-2010 Corded Phone
Voice Mail Greeting
Get into admin section of voicemail. Select change greeting. Select greeting number (probably 001). Rerecord. Need help. Email. If this is helpful, please post as such
Jan 27, 2009 | Vodavi Starplus SP7314-08 Corded Phone
CHANGE RECORDED MESSAGE
To change the greeting you need to either pick up the phone or press speaker phone then dial *38 then 1 then you will hear a beep/call tone. When you hear that tone record your message/greeting. Once you are finished press the auto dial/store button. If your are satisfied with that message hang up or press speaker phone again to end the call. If you would like to clear the message, then right after you hit auto dial/store you will hear a beep/call tone press 0 to clear or 1 to rerecord.
Dec 08, 2008 | Panasonic KX-T7630 Corded Phone
How to set message for answering machine lost directions
I lost the directions for my NW Bell GHZ answering machine. I would like to change greeting and set the time. How do I do this? It is model 36288.
Nov 15, 2007 | Uniden Cordless Phone
Message Greeting
The KX-T7456 is a proprietary system phone. You have a Panasonic phone system and a voice mail, both separate items with their own part number. Your phone can work on several different systems and use different voice mail so your first step is to determine the part numbers from the system and voice mail. Then you will need a "programming" manual or possibly "administrator's manual" NOT a "user guide" for at least your voice mail and maybe for the system as well.
Oct 16, 2007 | Panasonic KX-T7456 Corded Phone
Cell Phones Logo
70 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
