Question about Refrigerators
My Frigidarie model #: FRS26ZGH is freezing water on the bottom of the freezer and leaking out onto the floor. I understand that the drain plug may be frozen. However, I do not see a drain plug or know where it is or how to unfreeze it. Your help would be greatly appreciated.
    Master:
    Sergeant:
  • 385 Answers
The drain trough is at the bottom and way way back on the freezer side. After you get rid of the ice you need to get a flashlight and look way in back and at the very bottom of the freezer. You should be able to see the drain trough.It will be frozen, you need to get rid of the ice and then clean out the drain tube.A hair dryer might work to melt the ice but be very carful not to melt anything on the refrigereator.Then you can put hot water in the trough to be sure that the drain line is clear. Hope this helps.
Posted on May 19, 2011
  • jobber1st May 20, 2011
    I removed the ice on the bottom of the freezer side. No where do I see a drain trough. Is it located behind the rear panel? Because the bottom inside the freezer does not have a drain trough. Thank you.
  • Tony Wisinski May 20, 2011
    Yes on some models it is behind the panel.
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Magic chef model number CSB2323AR seems to be a defrost problem. Water accumulates at bottom of freezer then ices up. Is there a drain pan on this model?
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the lower right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 07, 2011 | Magic Chef Refrigerators
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
GE Monogram bottom freezer leaking water from left side onto the freezer floor and onto hardwood floor of the kitchen . Already tried totally defrosting freezer and that did not solve problem. Help!!
ck the drain in the back of freezer . it may be pluged and when it goes into defrost cycle you get about a cup of water on the floor . if there ice on bottom of freezer then the drain is iced over . some models require a drain heater to prevent this . mm hope this helps ..
Oct 14, 2010 | GE Monogram ZICS360NR Bottom Freezer...
Freezer drain not working. water accumulates and freezes in bottom of freezer compartment and sometimes will melt/leak onto floor
use hot water and turkey baster . force the water down the drain till it clear's to prevent it from freezing again install drain heater . some model's need them.
Jan 18, 2010 | Refrigerators
Water setteling on bottom of freezer side and freezing also leaking. 2 fridges both doing the same thing . leaking on the inside and freezing and underneath water is leaking.
Clean out the defrost drain. There is a drain in the freezer that lets all the defrost water run under the fridge. If that gets clogged then all the water runs into the freezer and can even leak onto the floor
Sep 13, 2009 | Refrigerators
My freezer has water that leaks into the bottom and freezes but water also leaks out onto the floor
Inside the freezer at the bottom in the back there's a drain hole that must be clogged and the water from every defrost cycle freezes up and make it worse , so first pour hot water into the drain to melt the ice and keep pouring until it goes through .Keep the drain clean doing this every 3 or 4 months.
Aug 10, 2009 | GE Refrigerators
Freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Aug 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer leaking on Ge Profile
The drain is frozen over and water cannot escape when it defrosts. You will need to remove the back panel inside the freezer and run some hot water down the drain until it has thawed. Hope this helps
Sep 24, 2008 | Refrigerators
Freezer leaking water
The drain is plugged just below the coils in the back of the freezer. My fridge had the same problem and I found the hose (which can be accessed from the rear bottom) was plugged with mold. Also, i noticed the hose was connected to the water holding pan and was too close to the bottom and easy to plug. I removed it from the connector and just let it dangle in the holding pan.
Aug 30, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
