Question about Canon LBP3200 Laser Printer
Leaves unprinted sections all the way down the page
  • Canon Master
  • 4,338 Answers
leaves unprinted sections all the way down the - joed911_9.jpg If it appears like the example above, you have a bad drum or (most likely) a bad fuser unit.
Take the drum (toner) out and shake (horizontally) back and forth. Check inside for loose paper or toner.
You can use a flashlight to look inside to the back and see the fuser roller. Check to see if you notice a bad spot on the fuser roller.
Posted on May 19, 2011
White unprinted band on the top end of printed sheet
Look to make sure your developer is flowing evenly on the mag roller. Next I would check the scoretron\grid it is the saw tooth blade that faces the drum.
Aug 18, 2014 | Sharp AR-5320 Black and White Copier
Scan has gray on whole page
The scanner may be set too dark that an unprinted white page may show up light gray.
Apr 05, 2013 | Lexmark X7170 All-In-One InkJet Printer
There are equally spaced unprinted lines on word docs when printing - why ?
It is cause of Error On Drum Roller of Your Printers Ink Section or in Cartridges. You have to replace it to resume good printing.
Hope You Enjoy.
Nov 10, 2012 | Epson Stylus Multifunction Inkjet Printer/...
Only right side of the page prints - help!
Marks repeatedly appear at even intervals on the unprinted side of the page.
c00366165.gif Internal parts might have toner on them. The problem typically corrects itself after a few more pages. The paper path might need cleaning. Click here to go to the Print Defect ruler for more information.
Clean the device. The imaging drum might be low. Click here to go to the Print Defect ruler for more information.
Replace the imaging drum. The fuser might be damaged. Click here to go to the Print Defect ruler for more information.
Contact HP Customer Care Marks repeatedly appear at even intervals on the unprinted side of the page.
Contact HP Customer Care hi at the link given below, click on it and locate the page (halfway down) where it states this
Contact HP Customer Carehttp://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=ca&taskId=110&prodSeriesId=445194&prodTypeId=18972&prodSeriesId=445194&objectID=c00366102
Nov 04, 2010 | HP LaserJet 2840 Printer
Zebra stripe wont print properly
Check the printhead pressure. there is an adjustment screw that does this. It could also be that your platen roller is worn or that your printhead has burned out pixels.
Dec 30, 2009 | Zebra Stripe S600 Thermal Label Printer
Won't print. Red light blinking
Reboot your computer and power down your printer. Leave them off for about 30 minutes or even overnight. (In other words, leave the computer and printer off more than a few minutes--some of the printers take more than 5 minutes before they'll clear their memories--a quick reboot won't do it.)
When deleting print copies it is safer to use the delete button on the printer than to delete from your computer, as then the copies don't get hung up in spooling.
I've had to do this a few times with Vista and printers, as things get held up in spooling on a regular basis.
Jan 05, 2009 | Brother HL 1440 Laser Printer
Printer prints about three inches down the stops
no solution yet. cant afford your services but thank you anyway.
beeharmon2@netzero.net
Jun 26, 2008 | Office Equipment & Supplies
Printing problems
According to the manual, "If there are white vertical lines on your printout, you will need to clean the print head."
I had that problem and cleaning the print head solved it.
Mar 07, 2008 | Epson ACULASER CX11NF All-In-One Printer
Not printing full A3
Make sure the machine and the driver are set for A3 . Most likely the paper tray, or setting in the menu are not correct.
Or the driver paper size is not correct.
Jan 31, 2008 | Xerox DocuPrint C20 InkJet Printer
Canon LBP3200 Laser Printer Logo
53 people viewed this question
old marine
old marine
