Samsung P2370 monitor screen flashes bright then dark. Looking for tips on do it yourself repair
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and to have an end so any faulty leads will end up with a computer error
also
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
click start control panel administrive tools computer management device manager scoll to scroll to monitors + to expand plug and play monitor you might see a yellow question or exclamation mark ? or red x you will have to update the driver right click where you have options to update driver
if your computer came with a motherboard disk the drivers could be on it or you could download
cnetdownload.com on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need or major geeks download this graphics driver this will depend on your operating system
http://download.cnet.com/%7Bvalue=http://www.download.com/ati-catalyst-display-driver/3000-2108_4-10608736.html
This is a WHQL release from the Release 260 family of drivers. This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, and 400-series desktop GPUs as well as ION desktop GPUs. What
Posted on May 20, 2011
Model -syncMaster P2370
http://www.samsung.com/sg/cyberservice/
Consumer Electronics Products One Commonwealth
1 Commonwealth Lane #01-01, Singapore 149544
Operating hours:
10am to 7pm (Monday ~ Friday)
10am to 3pm (Saturday)
Closed on Sunday & Public Holiday
http://www.samsung.com/sg/support/servicelocation/
Apr 02, 2015 | Samsung SyncMaster P2370 23" Monitor
Monitor screen flashes only, no brightness
Flashing display and no picture is a very common symptom of bad capacitors on the power supply board. If you can do a little soldering then you can repair the power supply board yourself. Here is a link to information showing what capacitors need to be replaced on the power supply board.
http://www.ccl-la.com/catalog/product_info.php?products_id=215
I hope this helps,
BuddyMc
Aug 15, 2012 | Samsung SyncMaster Computers & Internet
Samsung p2370
That model should still be under warranty, they have a 3 year warranty from Samsung. Your problem sounds like a dead power supply board. Here is the link to check the warranty and get a warranty ticket:
http://www.samsung.com/us/support/
I hope this helps, if so please rate my solution.
BuddyMc
Feb 16, 2012 | Samsung SyncMaster P2370 23" Monitor
My samsung 940b it has a clear bright screen ( as normal ) just for 2 seconds then the screen turns dark but you can see very very dim Window logo.Turn off the power ( does not matter for how long ) when...
Shine a flash light onto the monitor, if you can see icons/desktopon the screen then you know you need a new monitor!
You should be covered under warranty!
Mar 02, 2011 | Samsung SyncMaster 940B Monitor
I have 2 monitors connected to 1 computer using a
satservice, What happens AFTER 15 min of FLASHING?? What did unit do or act like 3-4 weeks ago? Is the screen both BLACK and BLANK? or is screen just black and you can SEE win-desktop if you shine a bright flashlight 1 inch from screen at differnt angles? Can you use your Samsung warranty? Will monitor do same when connected to different KNOWN GOOD prebooted to desktop PC? Are you refering to the "power ON" indicator light on front BEZEL as the FLASHING thing? Need more info, but I suspect "shutdown of units "switch-mode-power-supply" due to detection of FAULT CONDITION having been detected with other circuit or with itself. Read some of my other responses in my fixya profile that deal with BLACK SCREEN repair. If this response useful, rate on fixya. 12fixlouie
Dec 19, 2009 | Samsung Computers & Internet
Am unable to see anything on Samsung 740N monitor
the inverter which sends a signal to the lcd is either bad or the cable inside is loose.
good luck
Aug 26, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung Syncmaster 204T flashing
Please check that all the cables are plugged in firmly on the back of the monitor and on the back of the computer.
However....
It sounds like the back light on the screen is faulty. If this is the case it is definitely a return for repair problem. You should be able to find the warrantly procedure for your area on the samsung website.
Cheers
Dave
Jun 21, 2009 | Samsung 204T 20" LCD Monitor
The auto-darken feature(monitor goes dark on dark
In your monitor panel you'll find 4 buttons. Press the menu button and get into Magic Bright. There you can choose the one that best suits you. You can even set to Dynamic contract where the monitor adjusts the brightness according to the elements on the screen
Jun 20, 2009 | Computers & Internet
Monitor dark
I had a similar problem with this monitor, mine was dim all the time to the point you cant use it, but the MENU icon was bright as new... also if cable was unplugged the box would float around as normal.... anyway I fixed it by taking it all apart and pushing in the socketed chip.. it clicked like it moved, I also pushed on the variable resistors on the power supply... now it works!!! First time since it quite working long time ago
May 29, 2007 | Samsung SyncMaster 175V 17" LCD Monitor
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
