Question about Feber Early Childhood Resources Elr 0465 Activity Train
Hallo,I have the febergus 4 sections with head and tail and i have broblem with the items on the top of the toy which hold the head and the tail.Sorry i dont know the word exactly.what can I do?? Thans you. Gounari Vicky
How could i use my iphone 4g to control my toy helicopter
Instructions
    • 1 Remove the main rotor blades, throttle up the helicopter while holding it in your hand and twist the helicopter from side to side to determine if the gyro is working. The gyro should make the tail rotor spin faster when the helicopter twists; you will be able to hear a difference. If the gyro does not appear to be working, replace it. Some gyros have a sensitivity adjustment screw; try making small adjustments if possible.
    • 2 Check the tail rotors and see if they are connected correctly. If the tail rotor blades are not pitched correctly they will not be able to hold the helicopter still.
    • 3 Test the tail rotor motor and see if it seems strong and responsive. Brushed motors, like those commonly used to drive tail rotors, can wear out in a relatively short time. Replacing the motor may solve your problem if the gyro seems to be working.
    • 4 Check the trim on your transmitter. Ideally the trim should be in the center of the stick movement. You may need to dial in some extra right trim or you may find the trim is set too far to the left.
Jan 20, 2013 | Toys
How do i replace tail rotor on v-max hypersonic copter
Depending on what you ordered for replacement parts. You can buy
the whole tail boom section or just the motor either way you'll need to
solder those hair like wires to the motor or the PC board. The motor just
slips out through the top of the plastic case that holds it. The hair like
wires route down the hollow tube to the PC board.
Dec 28, 2011 | xheli 3 Channel Mini VMax RC Electric...
The tail rotor on my Syma s107 metal series helicopter won't spin. the battery is fully charged. the top rotor still spins. i don't know what to do
It seems tail motor is not working.
S107 knows to come with faulty tail motor.
If you open pilot cabin, you should see blue and red (or green and red) wire. See if they are welded on the motherboard.
If they are, then tail rotor is not working properly.
Mar 25, 2011 | SYMA Toys industrial New Syma S107 Radio...
How do i remove my tail light
Follow this steps below,
Tools:
  • 8 mm Socket with Extention
  • Flat-Head Screw Driver
  • Piece of Cloth
Step 1:
Open the Tail Gate and you will see two tabs on the inner side of the tail light.
{mosimage}
Step 2:
Using a Flat Head screw driver, pry open the two tabs. This will expose the 8mm bolts that are holding the tail light.
{mosimage}
Step 3:
Using a 8mm socket unbolt the two. Using a flat head screw driver, pry the tail light out. Make sure you use a piece of cloth so you do not damage the paint on the side.
{mosimage}
Step 4:
If you are using this process to change light bulbs, then you can just go ahead and swap the bulbs. Otherwise you can just take the tail light out by removing the harness.
Take care.
Jul 24, 2010 | 2002 Subaru Legacy
Loose dryer paddle and how to get to it.
This item can be accessed by removing the top portion of the dryer. Disconnect the power source so you will not get shocked. On the back two very small brackets will be needed to be removed. Each one should have one hex head or phillips head screw. Remove those two items then pry the front section of the top upward. Then you can remove the wiring connectors by unplugging them. Now you can take the top off and put it aside. Look down and you can see the drum and the retaining screws that hold the paddles in. You may need to take one of the other ones out to see what size and type of screw is needed. Oh yes the drum can be easily turned while your working on it at anytime
Apr 08, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I cant seem to get to the tail lamp for a bulb replacement on my 2005 Chevy Express.
Look at the tail lamp, if there are two screws at the top and bottom, simply remove the screws. If not, you will need to open the rear doors and remove a section of the rear panel and access the bolts that hold the tail lamp in place.
Feb 17, 2010 | 2005 Chevrolet Express
WHERE CAN I GET DEMINSIONS FOR A PRO RAZOR SCOOTER. IS THERE A WEBSITE I WANT TO MAKE ONE IM MY METALS CLASS. IM IN DRAFTING ONE SO I WANT TO GET THE DIMENSIONS AND PUT IT ON THE CAD SYSTEM.
Item dimensions are 25.5′ x 4′ x 7.25′ - Weight 8lbs.
  • Razor Pro Model Scooter has a double stacked head clamp for extra head tube strength and the scooter is made from aircraft grade aluminum.
  • It has a full deck and 98mm urethane wheels equipped with ABEC-5 high speed bearings.
  • Razor Pro Model Scooter folds for easy storage and transport.
  • It can hold riders up to 220lbs.
  • Item dimensions are 25.5′ x 4′ x 7.25′ - Weight 8lbs.
Sep 23, 2009 | Razor Pro Model Kick Scooter Fun Kid...
ZANUSSI INSTRUCTIONS MANUAL NEEDED
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 31, 2009 | Washing Machines
Brake Light Control Module
91 Honda Accord has 2 separate tail lights on each side(total of 4 pieces). My problem stemmed from a faulty control module on the right hand side(passenger side). The module in question is located inside the smaller of the 2 tail light sections. In order to change the module you have to remove the tail light. There are 4 nuts holding in the taillight section and 2 phillips head screws holding the module in. The module on this side is 6 pin plug in. The one on the drivers side is a 5 pin plug in. Whole effort takes about 45 minutes. It is strictly plug and play.
Feb 05, 2009 | 1991 Honda Accord
Feber Early Childhood Resources Elr 0465  Activity Train Logo
50 people viewed this question
Top Feber Toys Experts
ray gallant
Are you a Feber Toy Expert? Answer questions, earn points and help others
