Question about Roper REX4634KQ Electric Dryer
How do I replace the belt back around the drum? I have the backside completely off...Thank-you
  • Roper Master
  • 7,482 Answers
Hi tvstar...
You need to pull the front off to replace the belt.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, loop it around the drum and as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please take time to rate me
Posted on May 19, 2011
Testimonial: "I definately needed this help thank-you sooo much Hunter."
    Master:
    Sergeant:
  • 385 Answers
You need to lift the top and take off the front of the dryer to put the belt on. Hope this helps.
Testimonial: "Thank-you Tony!!=)"
I HAVE A MAGTAG PPTS20 HOW DO I DO THE BELT
If you are talking about replacing the belt wit a new one.
YOU NEED TO FIRST UNPLUG THE DRYER!
This is a difficult procedure, you have to take the dryer apart, this includes removing the drum. after you remove the drum, place the belt around the drum, there will be a place worn where the old belt was, with the belt on the drum put back in the dryer, place the belt on the motor pulley with the tension pulley pushing on the belt. Make sure to get the felt around the drum in the back. Replace the parts you removed. plug back in and see if runs ok.
This is very difficult and is why we get $95 + parts
Thank You
Jerry
Aug 31, 2014 | Maytag Dryers
I have a Kenmore Gas Dryer (model 11087471810) that threw its belt. I have the replacement belt and know how to replace that. When I opened the bottom of the dryer, I noticed the Idler pulley sitting at...
The idler pulley/tensioner fastens into two slots in the base of the dryer to the left of the motor . The belt goes around the drum then through the idler to the motor pulley ,you have to make a loop with the excess belt and feed it through the idler pulley, i normally pull the plastic pulley towards the right side of the dryer to give enough belt to go around the motor pulley then let the plastic pulley rest on the backside of the belt. do not turn the drum too much as you may pull the belt back off .
May 13, 2011 | Kenmore Dryers
Good Morning: I have an older Kenmore Dryer with the serial # of : 77982600 and the belt broke. I can get the new belt but am wondering how it goes on. Do I have to remove the felt belt on the backside?...
dont mess with the felt on the drum... pop the top of the dryer. 2 clips hold it down.. use a screw driver to pop it. then take out screws on the front and bottom to remove the front part of dryer with the door . now put the belt around the drum put front on. then comes the fun part feeding the belt through pully tensioner good luck remove back to get to belt pully /tensioner
Aug 16, 2010 | Kenmore Dryers
Changing a dryer belt on a Maytag DE410
in some models you do it from the front the drum sits on 2 bogie wheels and the belt sits behind ,lift drum off bogie wheels and thread belt around pulley it should be on a spring tensioner and it allows you to swing pulley up or down try to thread belt around drum and replace drum back on bogie wheels.... in some dryers you may need to thread belt on drum and then onto pulley good luck
Dec 18, 2009 | Dryers
How do I replace a broken belt around the tumbler on my Maytag LDG612? Thank you.
remove front cover and access top cover screws and remove top. lift up drum and string belt around drum,set drum down and string around remaining belt around motor and idler pullys and hand manually rotate to align belts before putting top and front covers back on
Sep 24, 2009 | Dryers
you need to remove the drum.route new belt with ribs on motor pulley.and backside of belt on sping loades idler pulley
How do you replace a broken belt on the Kenmore 80 series dryer?
The belt is acessable from the front of the dryer you can remove it by popping the top up then taking off the front of the dryer off the drum will come out now place the belt around the drum and put back in now the belt goes around the drum the motor pulley and under the tentioner pulley replace front and top and you are good to go thank you
Please rate me
Apr 20, 2009 | Kenmore Dryers
Best way to replace drum belt
Please rate me
Apr 18, 2009 | Bosch Axxis WTA 3003 Electric Dryer
Tumble dryer
pull the front off then put the belt around the drum then pull the idler pulley back to put tension on it and put the belt around the motor pulley let the idler pulley back against the belt to keep it tight replace the front and your done
Mar 12, 2008 | Dryers
Roper REX4634KQ Electric Dryer Logo
463 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
