Question about Toro 52" 27hp Z Master Zero Turn Lawn Mower
Mower was running then shut off. And now when I turn key it just clicks.
  • 577 Answers
Sounds like your battery went bad...try a battery charger and see if it works that way ..if so then bad battery or not charging the bat. when running
Posted on May 20, 2011
My Husqvarna YTH24K48 won't turn over. When I turn the key to the first notch, I hear one click. When I go ahead and turn the key to the start position, nothing happens.
Check that the interlock on the seat is connected. Mine failed in the same way a while back and all that was wrong was a broken wire to the interlock switch on the seat. This is designed to stop the engine if you get off the mower.
May 20, 2016 | Husqvarna Garden
When I shift from neutral to reverse, why does engine shut off?
If you have a newer mower, you may not be able to mow while backing up. You can turn off the deck a?d then b?ck up or see if your key switch can be turned back towards the off position by one click. Some mowers have that key position requirement to mow in reverse.
Apr 19, 2016 | Garden
What can I try next? My husqvarna RZ4623 wont start. Nothing when the key is turned.
Is the small wire, coming from the Ignition Key, Getting 12V to the Relay when you turn the Key? Were Mice chewing on your wires?
Jun 25, 2014 | Snapper Husqvarna RZ4623 46" 23HP Kohler...
Mower was running shut off now does nothing when i turn key
If electric start check for low battery or loose battery cables. Could be a bad starter.
Jun 21, 2014 | Toro 52" 27hp Z Master Zero Turn Lawn...
Mower was running then shut off. And now when I turn key it will not do anything.
Check the plug and wiring connected to the seat under the seat. May have crimped or come undone. This is a safety feature on most mowers.
Jun 04, 2014 | Toro 52" 27hp Z Master Zero Turn Lawn...
My 155c John Deere will not start! Brand new charged battery....I turn the key...nothing(no clicking either). When bypassing it to cellinoid, it starts right up. When I shut off the mower, I have to...
Usually when the key is turned to start position the starter soleniod engages thus applying power to the starter. There are three possible causes to your problem . (1) Check for 12vdc at the terminal on the soleniod when the key is turned to start position, if there is 12vdc at the terminal then the key switch is good. (2) loose or bad cable connection at the soleniod, check connections. (3) bad soleniod -- replace it. generally you will hear a click from the soleniod when the key is turned to start position. Also be sure to check that ALL safety switches are engaged. You may need someone to sit in the drivers seat so that switch will be "made" / engaged. Park Brake is set, mowing blades are "NOT " being engaged, on some mowers if the transmission is in reverse ,even tho the brake is set the mower will not start.
Nov 10, 2013 | Garden
Model 425 jd getting fire at plugs changed fuel filter primed carb will not start
when you turn the key on to the run positon do you hear a clicking sound coming from the carburator? this tractor is equipped with a fuel shut off solenoid on the carburator if you dont hear the clicking sound solenoid is either not getting 12vdc or it is defective.
Aug 29, 2009 | John Deere Garden
Toro 52" 27hp Z Master Zero Turn Lawn Mower Logo
567 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
