Question about AEG Washing Machines
Hi I have this type of washing machine AEG W1010 is it possble to clean it inside where the wahing powder is running in the mashine? The powder is runnig very slow down to the mashine. Thank you very much
    Genius:
  • 1,140 Answers
Try a lint brush and switch to a liguid
Posted on May 20, 2011
My AEG Lavamat W1010 will not put the final rinse through the fabric softener section of the dispenser drawer
Hi Cath.
You probably have a faulty Inlet Valve. This is the one which introduces the water through the Softener drawer (As you said)
The other one which seems OK flushes the detergent into the machine.
It may be a double inlet and only the rinse part is faulty.
Not a big job for a Technician
Good luck
Nomess
Jan 29, 2015 | AEG Washing Machines
My aeg lavamat 73620 fills water in the wrong compartment. How do I take out the powder-dosing unit to clean it?
with all the machines ive had you pull it out and lift it up at the same time, then give it a good wash when you put it back you have it upright and slowly lower it as you push it in, don't try and force it.
Nov 22, 2014 | AEG Washing Machines
How to clean it
You could purchase front loader washing machine cleaning chemical or soap. My experience with cleaning chemical and soap was to just masking smell, not fixing the problem. I did a few search and came out with using vinegar, baking powder and bleach is most effective way to clean and get smell out of washing machine. ie run cleaning cycle with 1 or 2 cup of vinegar, let it run for 20 ~ 30 minutes and pause for 30 minutes (it help break it up) let resume and finish cycle. Run cleaning cycle again with baking powder. If your machine don't have cleaning cycle use hot water and heavy load setting. Hope this help you.
Apr 19, 2014 | Zanussi FS1255S Front Load Washer
Aeg washing machine e320 error
Hello my AEG washing mashin d
Feb 18, 2012 | AEG Washing Machines
I need the user manual for an AEG Lavamat 1100 washing mashine
How to operate ano AEG LAvamat 1100 washing machine
Apr 13, 2011 | AEG Washing Machines
My kenmore elite wahing machine is blinking PF and done of my buttons are working, the mashine will not run at all. I'ts a black top loader, not sure the year.
Hello
PF error means power failure which is generally caused when the control board inside the unit goes bad. You can try unplugging the unit for 15-30 minutes, if the issue returns then the control board needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 09, 2010 | Kenmore Washing Machines
Dear ladies and gentlemen, our problem is, that we have a full mashine stopp with e20 accuring on the led before the detenser enters the toumble. our mashine is an aeg 16809 e20 thanks for your fast reply
You've answered your own question. E20 is a draining failure. Blockage in the sump hose, pump, drain hose or faulty pump. Clear the blockage or replace the pump if faulty and you'll clear the fault.
May 16, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG 16820 Lavamat-turbo
Hi
this sounds like the fill vavle is fauty you can check this if you have a muiltmeter.
remove lid and unplug the green soliaod and check to see if open circuit.
if so replace and should be ok.
regards
Mar 08, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing powder residues left in washing powder compartment.
5 bar is a good pressure. worth while to check the valve filter as suggested. turn off water, remove hoses from machine. look down valve spigot and there is a mesh filter inset. remove with small pliers and clean
Jun 09, 2007 | AEG Lavamat W1050 Front Load Washer
Aeg washing machine
you may have blockage in pipe from drawer to tub but more likely the soap drawer is clogged. take it right out and clean thoroughly
Mar 21, 2007 | AEG Lavamat W1050 Front Load Washer
Washing Machines Logo
64 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
