Question about Milwaukee Tool 3/8" 12 V Cordless Variable - Speed Drill
My older Milwaukee 12v variable speed 3/8" reversible drill has a problem with the keyless chuck...it slips, regardless of where I've set the torque limiting controls. Can you assist, please? Thank you, Mark in Modesto
  • Mark Spencer May 23, 2011
    Thank you, Andrew, but I'm afraid I mis-described my problem. It's not the chuck, but the clutch assembly which is slipping, and I'm not sure how to get into it for a close internal inspection. I'd lock it up solid, like a real drill, if only I knew how...
    Mark
  • 20 Answers
All you can do is replace the chuck. Any good hardware store will have a replacement.
Posted on May 23, 2011
How to insert bit for Black and Decker 3/8 Variable Speed Reversing Drill.
Most new cordless drills don't have a key(keyless chuck). Put the drill in reverse and hold tight to the chuck barrel, pull trigger and the chuck will open. Opposite to close/tighten Best I can do with info provided
Apr 15, 2015 | Speed Drills
How do I change a bit
This drill uses a keyless chuck. which means you have to hold onto the barrel by the end of the drill chuck. Then you need to put the drill in reverse to open the chuck to put a bit in. Insert a bit and then put the drill back into forward and hold chuck to tighten.
Nov 14, 2010 | Milwaukee Tool Milwaukee 0824 24 v18...
I have a DR250 and I can't get the chuck open
I've run into this from time to time, usually have to fix it with two pairs of channel locks, one on each collar on the chuck. With the drill facing you, hold the inner collar steady and turn the outer collar counter-clockwise.
The chuck should not stick like that under normal circumstances (mine only did it when it got full of sawdust), so there may be a mechanism issue and there is a fair possibility that you will break the chuck doing this repair. That being said, 30 bucks is reasonable for a new one, and it's not doing you much good jammed like that.
Nov 06, 2010 | Black & Decker 3/8" Variable Speed...
Remove and repair or replace keyless drill chuck
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting on the transmission. Remove the power source! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck). Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you!
Sep 17, 2010 | Ryobi 18v Variable Speed Impact Driver...
Bosch keyless chuck stuck
Make sure you try it in both directions.
Apr 18, 2010 | Black & Decker 3/8" Variable Speed...
Milwaukee keyless chuck drill is closed and I
I'd try using a pair of slip-joint pliers (e.g. brand name example is Channel-lok™ (sp) to get a better grip on the chuck and housing. Try wrapping some scrap rags around under the jaws of the pliers to minimize gouging or other cosmetic damage to the chuck or drill housing.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "Very Helpful" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Dec 29, 2009 | Drills
How do I remove and replace the keyless chuck on a makita hp1621F?
Remove the screw inside (clockwise)
mount a big Allen key in the chuck ,shortest part inside the chuck,
hurt the key with a hammer to make tre drill move counterclockwiseto unblock it
Nov 16, 2009 | Makita HP1621FK 5/8" Hammer Drill, 5.7...
I have a Bosch PSR12 12V Cordless drill, but no instructions.
This drill has a keyless chuck. Put your bit in the chuck and hold the collar of the chuck while pressing the trigger in the forward position. To undo the chuck do this in reverse. You can also hand tighten the keyless chuck if you prefer. I have a 1/4' adapter that I keep in my drill so I can change bits quickly.
Sep 09, 2009 | Bosch Drills
Keyless Chuck how do you change the bit? Model
hold outside collar on chuck firmly with your hand and reverse drill
Jul 10, 2009 | Black & Decker 3/8" Variable Speed...
Can't remove the chuck retaining screw.
The screw is a LEFT HAND THREAD and also is LIKELY a Metric size!
Make sure you use a Metric Allen wrench.
Jul 08, 2009 | Makita 6408K 3/8" Variable Speed,...
Milwaukee Tool 3/8" 12 V Cordless Variable - Speed Drill Logo
111 people viewed this question
Top Milwaukee Tool Drills Experts
Mike
Harjeet Singh
Are you a Milwaukee Tool Drill Expert? Answer questions, earn points and help others
