My windows drive is ok but I can not access my internal data drive. It shows up in Disk Management but when I run the diagnostics it says I have the bad sectors. So I can not access my data. I need my data. Please experts what can I do to recover my data?
  • 343 Answers
Sorry to here your but it sounds like your data drive is failing.The one suggestion is to try running in safe mode and see if you can copy files from the data drive. Also in safe mode have you tried running windows error checking tool by going into my computer and right clicking on the drive and go to tools tab. Could also try connecting it to an external usb adapter. You can also try a free program for file recovery that the link will be below if that does not work read the article also attached. Let me know what worked for your situation. Thanks for using FixYa
http://www.pcinspector.de/default.htm?language=1
http://www.popularmechanics.com/technology/how-to/tips/4294038
Posted on May 19, 2011
Running windows 7 ultimate, my 2nd internal drive suddenly no longer is listed in disk management, and 3rd drive listed cannot copy to it. cannot now open an exell file that could yesterday??
Couple things you can try. In Computer Management right click on Disk Management and select Rescan disks - see if it shows up as one of the volumes. In the bottom pane check to see if there is an unnamed drive or a drive with an error.
If there is no sign of the drive, and you're comfortable cracking open the case, check to make sure the drive is connected to the motherboard (make sure to unplug the PC and ground yourself by touching the metal frame inside the computer before touching any components). If the connection seems ok, swap it with one of your other drives and boot up the PC. If it shows up, the problem was the cable. If it doesn't, it's likely the drive. Is it a Dell? Depending on the manufacturer you can run a diagnostic to see if the drive is damaged.
One other thing to try is to open a command prompt in Windows (Click Start and type cmd in the text box). Change the drive letter to the drive that was giving you trouble. Then run the command chkdsk /r to check the disk for errors and repair. It should prompt for a reboot. Hope this helps.
Nov 15, 2011 | Computers & Internet
Tip
Using Windows Disk Management Utility to Manage Internal and External Disks
Disk management utility will help you see all the drives that are connected to your computer, including internal hard drives, CD or DVD Drives, and removable storage like USB sticks and external hard drives. Using this utility, you can check for attached drives that are not visible in windows when attached to your computer. You can also format drives, change drive letters, mark a partition as active and delete partitions. A word on caution about using the Disk Management Utility: This utility can cause destruction of data. If you are not sure of what you are looking at and uncomfortable with using this utility you should consult with an advanced user before making any changes to drives using this utility.
The Disk Management utility can be accessed in two different ways.
#1- You can open the Control Panel,
Click on Administrative Tools,
Click on Computer Management and the Computer Management window will open.
#2- Right click on you “My Computer” Icon
A menu will open
Chose “Manage”
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a “Drive” and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show “healthy”)
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter “C”.) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters “F” or “G”. In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
on Jan 29, 2010 | Computers & Internet
My laptop lenovo ideapad y450 shows blue screen error.i tried to format with windows xp also,but it appears once format was completed also.advice me pls
Dear! Delete your C drive and create again with the help of windows and then format and install Windows. Your problem will be fixed.
Jul 27, 2011 | Computers & Internet
How to unlock a sandisk cruzer usb flash card 16 gb
If you cannot open your usb drive, you will need to open your drive management. Sometimes, drive letters that the usb drive looks for, usually F, G or H, are taken by other drives. You can change drive letters on other network drives to different letters, therefore, allowing the usb drive to access the letters it is looking for, and effectively, unlocking it. Below are directions on using the Disk management utility in windows:
Disk management utility will help you see all the drives that are connected to your computer, including internal hard drives, CD or DVD Drives, and removable storage like USB sticks and external hard drives. Using this utility, you can check for attached drives that are not visible in windows when attached to your computer. You can also format drives, change drive letters, mark a partition as active and delete partitions. A word on caution about using the Disk Management Utility: This utility can cause destruction of data. If you are not sure of what you are looking at and uncomfortable with using this utility you should consult with an advanced user before making any changes to drives using this utility. Also, drive '0' is usually your main hard drive.
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
Jan 04, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have a My Book which has a broken USB jack. I removed the drive from the case and would like to know if it's still possible to access the data on it. Smart tests detect the drive as OK, and it ran...
If the SATA-to-USB converter is working properly, then Disk Management should show the device, assuming that the disk-drive itself is working properly.
Dec 27, 2010 | Western Digital My Book Essential...
My western digital dosent get detected, whenever i connect the device a new hardware found sound comes and nothing comes in my computer, i tried restarting nd olso tried to connect the device on other...
sometimes drives need to be initiallized when they are connected I will give you instructions to use the Manage Feature of windows to manage your drives. The instructions are as below:
If you cannot see the drive using the disk management utility, then you need to check to be sure the drive is not malfunctioning and also check your connection cable to be sure it is not the problem.
I hope this is helpful!!
Brian
Using Disk Management Utility
#2- Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
Dec 23, 2010 | Western Digital 320GB MyBook External USB...
My 2gb pendrive not working it is not detected
Trouble:
You may have faced a problem when you insert your pen drive and it gets detected very easily but it doesn’t show up as a drive icon in My Computer. The Computer detects the pen drive but data on pen drive is not visible as the pen drive is not visible in My Computer (Explorer).
This problem occurs mainly when windows XP fails to allocate a drive letter to your portable drive(pen drive). It occurs mostly with new pen drives connected to your computer for the first time. If you face such problem then it may not be the pen drive’s fault, rather it may be windows trouble.
If Problem Fix:
Fix:
You can fix this issue by following some simple steps given below.
1. Click Start, click Run, type compmgmt.msc, and then click OK.
2. In the console tree, click Disk Management. The Disk Management window will appear.
3. On this disk management window, you can see some drives including the portable drive. Right click on your portable drive and click change drive letter and paths.
4. Now a assign a new drive letter which is not being used by any of your drives in My Computer.
5. After assigning the new drive letter your portable drive will show up in my computer with other drives
Jan 29, 2010 | Transcend T.sonic 612 MP3 Player
Reduced Hard Drive Capacity with Internal to External Kit
Problem can be tricky.. though i offer my two cents.
1. some BIOS have upper limit of hard disk capacity. check that out. try connecting IDE device to IDE connector in same comp and see if it is being detected properly.
2. seagate guys are true .. IDE to usb conversion can be tricky ... a lot depends on card convertor.
my advice would be if you have precious data on it ... first take a backup of it, if possible connecting the disk to nomal ide connector.
Aug 06, 2009 | Sabrent 1 Bay USB 2.0 External Drive Case
My Book (WD Western Digital) says "The disk in drive _ is not formatted. Do you want to format it now?" My Book has important data but I can't access stored files on my new computer.
The problem you are having is not uncommon and is fairly easy to resolve with the help of a pro. The Partition Table or File allocation table is modt likely damaged and that is why you are having difficulty accessing it.
You can try running chkdsk ?: /f from the run box(?=drive letter), this will pop up a warning that the disk will be checked on the next restart.
This does run a slight risk of damaging files but quite often recovers the drive successfully.
Your other option is to send it to a data recovery firm and have them extract the data without risk of damaging the files, then they can test the drive for any potential failures, format it and reload it with your data.
If you are in North America try Armor-IT Data Recovery, if you're in another region let me know which one and I'll make a recommendation for you.
Chris
May 23, 2009 | Western Digital My Book Premium ES...
External Drive not recognized
Have you tried in Disk Management Right-Clicking on the drive and selecting 'Change Drive Letter and Paths...' ? That is the normal way to change or add a drive letter to any drive, internally or externally attached (other than by network connection)?
Dec 03, 2007 | Western Digital My Book Essential Edition...
Computers & Internet Logo
246 people viewed this question
David Payne
David Payne
