Question about Homelite Garden
I CANNOT FIND A REPLACEMENT CHAIN FOR HOMELITE MOD.UT10910 18" , CHAIN #32MD50-72. WHAT OTHER BRAND OR TYPE IS COMPATIBLE TO THIS PARTICULAR SAW? MOST STORES CARRY PRODUCTS FOR THE NEWER MODELS. PLEAS HELP!
  • 3 Answers
SOURCE: Need user manual for homelite chain saw model
try managemyhome.com
Posted on Mar 20, 2009
  • 7 Answers
SOURCE: how do I replace the primer bulb on a Homelite
Most of them snap in, meaning there are two small blades that are cast into the plastic for the primer bulb housing. These tabs fit into a recess and lock when pushed in from the outside. You will need the entire replacement as you cannot just replace the bulb like is possible on a Zama or Walbro carb. Whatever you do, make sure you mark the routing of the hoses. Its always fun to get them hoses mixed up and then wonder how theyre supposed to route...
Posted on Aug 31, 2009
Testimonial: "thanks for the advice, very helpful! "
dontbother10
  • 2220 Answers
SOURCE: I have an earlier model Homelite XL Textron, UT#:
Hello cf:
I need your help to help you.
Please count the drive links on an existing chain and post back (below) with the number. I have to close this, to post a photo. We can continue if you just reply.
I will provide the correct bar size and a link where you can make a choice, because your saw is so old I cannot match it to anything currently on the Homelite site and I am not willing to recommend a chain without seeing your level of expertise.
You can also take an existing chain to a local saw shop where one can be fabricated in a few minutes.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 26, 2010
  • 885 Answers
SOURCE: i need to know the
You need to mix 2.6 ounces of 2-cycle oil (NOT motor oil) with one gallon of fresh gas to get a 50 to 1 mixture. Most 2-cycle oil is sold in small bottles this size and have directions on them to get the correct mixture.
Posted on Sep 09, 2010
  • 4088 Answers
SOURCE: Homelite 18 " chain saw
It should be part of the lower plastic casting which contains both tanks that are not removable. If it is cracked, replacement is the only permanent fix. Make sure the oil hose coming from it to the pump is not decayed or split. The entire engine needs to be removed from the base to replace the tanks. Hope this helps!
Posted on Oct 19, 2010
Testimonial: "Thanks for the help!"
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
What is the replacement chain and bar for a homelite textron Little Red UT-10748
Ok, what you need to do is go on Google type in that model number UT etc etc and parts right after it. You will see a bunch of sites that have parts drawings, click on one of them, find your part numbers THEN do the same thing again, bqck to google, type in part number then the description, again you will see sites that will either offer the OM part or an aftermarket.
Nov 23, 2015 | Homelite Garden
Is there a replacement part other than plastic for clutch
you could either use an organic rubber type simelare to platsiic and do it urself - size etc
Apr 17, 2012 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
Need to know what type of oil to get for my chain saw
mysuccess52-
Any brand of two cycle engine oil will work.
Regards,
DIYpro
May 01, 2011 | Homelite ZR10926 16" Chain Saw
I have a Homelite UT 10518 46cc 18" saw. The replacement chain for that model does not fit the bar (not long enough) any idea what is up with that - also the 10518 does not seem to be listed on the...
you need a 72 link chain .375 pitch .050 guage at home depot the blue powercare B72 should be the one you need at lowes it oregon H72 there are other brands as well but you need to make sure of the links guage and pitch when buying a chain
Jan 15, 2011 | Homelite FactoryReconditioned ZR10522...
You don't get it people, no MATTER WHAT I DO, the chain keeps coming off the cheap electric chain saw. Both Homelite and Remington share the same problem. These DO NOT WORK! I haven't gotten more than 2...
Quit doing what you are doing before you cut yourself. The cut could kill or cost $10,000 just to live with an ugly scar. You chain is not staying adjusted correctly.
My Homelite does NOT do this. But my neighbors Poulan did. It thrashed the chain against the spike and threw it completely off. The adjustor didn't work right and an attempt to bolt it tight also failed. So I ordered the spike and the whole cover/brake handle/chain adjustor kit for it. Should get here from Sears in a week for under $40 USD.
URL: https://www.searspartsdirect.com/partsdirect/
Mod: PP4620AVX.
Parts items
(45) Spike 530014381 and
(70) Kit ezt c/br 545081874
Jan 15, 2011 | Homelite ZR10926 16 Chain Saw
I have an earlier model Homelite XL Textron, UT#: 10618A, Serial#: 7D2080207. I need to replace the chain and possibly the bar. Can you tell me where I can get a chain and/or what is the part # for the...
Hello cf:
Lou
Mar 26, 2010 | Homelite Garden
CHAIN SAW QUITS CUTTING AS IT HITS WOOD.
The make, model, and occationally the serial number help us solve your problem.
Does the engine quit running? (Carburator needs adjustment)
Or does it continue running and chain stops? (need clutch refaced or replaced.) (to aggressive a chain for the size of the engine)
I think you replaced parts unnecessarily. Maybe quicker and cheaper to visit your friendly neighborhood chainsaw shop. A good one can repair it even if they do not sell your brand.
HTH
Lou
Sep 09, 2009 | Homelite Garden
Garden Logo
89 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
