Question about Kenmore 33023 Gas Cooktop
I have a Kenmore cooktop/oven m# 79036693501 and the spark igniters for the 4 burners are constantly sparking, even with the dials in the off position. I think I know what part but am looking for conformation..
    Master:
    Sergeant:
  • 385 Answers
One of the switches is bad.
Posted on May 19, 2011
How to replace spark module?
How to replace spark module Todd, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/42129-thermador-spark-module-replacement.html
Thermador Stove Burner Won Light
Burner on Thermador cooktop won light
Mar 22, 2016 | Thermador Cooktops
3 of the 4 burners clicks and sparks when I try to
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jul 27, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
New cooktop-1 burner does not light automatic
find the spark module. Follow the spark wires to the module . unplug the one that doesn't work and plug in a working wire. If it sparks it the wire if it doesn't spark change module
May 16, 2009 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
Constant sparking
I don't have a Thermador cooktop but here is ma taught.
Could you unplug the two faulty igniters and see if problem remained
Could you plug one of the faulty igniter at the location of a good one. The goal is to isolate the problem. Is it the igniter or the electronic board.
Faulty ground problem may occur also after an spillover on the stove. In that case, use a cotton swab dipped in scrubbing alcool and clean the spark area on the igniter and the burner.
Good luck
Mar 31, 2017 | KitchenAid 31 in. KGCC505 Gas Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Viking professional 30 inch, sparking problem
If you have replaced the spark module with the new, blue PA020041 Tytronics 0+4 spark module, the physical positions of the leads that go to the burner igniters are reversed compared to the positions on the old, white module. Make sure that the switch wire for the burner and the position of the spark wire both go to the same burner! The positions are marked on the white label with green lettering.
Nov 25, 2008 | Viking 31 in. VGSU101 Gas Cooktop
Kitchen gas 4 burner cooktop
i think all igniter switch are grounded,i request to call expert technician to repair it, or uf u want u open the cooktop to see the igniter swicth at konb control area,clean one by one using thinner,remember switc off the plug first.
Aug 03, 2008 | KitchenAid 31 in. KECS100 Electric Cooktop
Kenmore 33023 Gas Cooktop Logo
75 people viewed this question
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
mcgsp
Level 1 Expert
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
