I need instructions on how to refill origonal canon pfi-102 cartridges.
  • theresa May 20, 2011
    thanks that is very helpful ... for alot of things.
SOURCE: refilling of canon ink fine cartridge pg 41
reset the cartridge from the printer. there are a few steps to follow
Posted on Jun 24, 2008
SOURCE: How to refill Canon FX3 Laser Toner Cartridge
I drilled the hole on the side with no handle. I put packing tape over the hole and it worked fine. I'm refilling it again right now... Good luck, have fun, and save some $$$!
Posted on Sep 17, 2008
taran_2005
  • 10515 Answers
SOURCE: cartridge refill
The link is :)
http://www.ink-n-things.co.uk/acatalog/Lexmark_Instructions.html
Thanks.
Posted on Jan 11, 2009
SOURCE: refill instructions for a Dell Series 5 ink
The Ink Shop can refill these cartridges for you with a 100% warranree
Posted on Mar 30, 2010
inkfilling
  • 27 Answers
SOURCE: How to refill at home canon laser cartridge
http://www.youtube.com/watch?v=iMiTopIVMxM
hope i help you
Posted on Sep 30, 2010
How to reset inkje even with new refilled cartridge
Regarding your recent inquiry about the Canon 240 (black) or 241 (color) ink cartridge ink alert/error condition and the inability to print to your Canon MX452 printer, to reset the cartridge ink low/empty alert message condition, depending on your printer model, we suggest you follow the documented procedures below and/or provided on Inkjet411 at the following link. http://inkjet411.com/?page_id=1765
Essentially, in most cases, all you need to do is press the 'Stop/Reset' button (triangle symbol inside of a circle) for 5-8 seconds and the ink error ("ink has run out", etc.) indicators should extinguish; two common reset procedures are provided below (please refer to both videos): http://inkjet411.com/?page_id=1765
Canon 30/31/40/41 - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2709
Canon 50/51 - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2719
Canon 210/210XL/211/211XL - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2728
Canon 240/240XL/240XXL/241/241XL - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2733
Canon 245/245XL/246/246XL - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2740
If you have already attempted the 5-8 second printer reset without success, then refer to WORST CASE SCENARIO section below.
ADDITIONAL NOTES:
NOTE 1: Providing you can still print, you will need to wait until the "ink has run out" message appears on your computer, before activating the 'Stop/Resume' button for 5-8 seconds. However, if printing is not permissible, then please keep reading....
NOTE 2: If you are able to print the internal self test print, this will demonstrate that the ink cartridge is 'at least' partially functioning. If this is the case, then we suggest you continue printing until the software prompts you to press the 'Stop/Reset' button for >5 seconds. For poor print quality performance issues (as you indicated in your inquiry), we suggest you run a nozzle/cartridge clean test from your Canon software, followed by printing our 'Ink Recovery Test' print: http://inkjet411.com/wp-content/uploads/2013/02/Test-Print_CMYK.pdf
NOTE: To rule out connectivity issues, please ensure BOTH carriage/flex cables (point where the cartridge connects to carriage inside the printer) and BOTH ink cartridge rear electrical contact surfaces are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
      WORST CASE SCENARIO - INTERNAL ELECTRICAL FAILURE OF INK CARTRIDGE:
      If, after performing the suggested 'reset' procedures above, you still have an error condition which prohibits computer/host based printing (or permit copy/scan functions), then the ink cartridge probably has internal electrical damage (micro-electronics failure); such a failure is unrelated to the ink cartridge refilling process. Typically, when the cartridge fails the problem is 'masked' by the ink out/empty condition so it can be difficult to distinguish between the two. Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process (i.e. typically ~2 years from original manufacturing date). Refer to picture at bottom of this page: http://inkjet411.com/?page_id=1533
      If, following a reset of the printer via the 'Stop/Resume' button, printing is permitted but the 'Ink Low' indicator continues to be lit then one of the inks cartridges may be suffering from marginal internal electrical performance - a potential failure of the cartridge may eventually occur which will prevent printing.
      CAUTION: Be advised, the use of Canon compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors and/or permanent PRINTHEAD failures (due to incompatible ink formulations which may contain volatile organic compounds, or VOCs). We do NOT suggest refilling these types of ink cartridges.....refilling of Canon original/genuine ink cartridges is only suggested!
      Canon 30/31 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=3khyqBHMPVc
      Canon 240/241 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=HyEhCOxvdsA
      If you do need to purchase a new ink cartridge (to save on ink costs), we suggest you try a USA remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating and come with a 1-year warranty.
      Alternatively, if you are interested in the top 'refill friendly inkjet printer models', our suggested list is posted on-line and our internal labs have verified there are no issues (in ink compatibility or color output) with all of these models: http://inkjet411.com/?page_id=3585
      Please let us know if you have any questions regarding the technical information provided above by sending an e-mail to us directly: Inkjet411help@gmail.com
      -Thank you
Jul 20, 2014 | Canon Pixma MX452 Wlse All-In-One Printer...
Waht kind of cartridge is used for canon printer K10282
Your machine is a Pixma MP160. It can use either the PG40 or PG50 Black cartridges, and the CL41 or CL51 Colour cartridges. These can be refilled, but the cartridges have a memory function that will need you to bypass the printers cartridge level calculator. Your cartridge refiller should be able to provide you with instructions for this.
Jan 30, 2014 | Canon PIXMA MP160 All-In-One InkJet...
Reset ink level on canon mg2120 after ink refill
The following procedures may be used to reset the Canon printer ink level monitoring following the installation of a refilled Canon 30, 31, 40, 41, 50, 51, 210, 211, 240, or 241 integrated ink cartridges. In most cases, the error/alert will need to be cleared to enable printing. Ink waste container reset procedures are also provided below.
NOTE: for multi-cartridge installation, the procedure(s) may need to be repeated twice.
For PGI-5, PGI-9PBK, CLI-8, PGI-220 CLI-221 PGI-225 CLI-226 PGI-250 CLI-251 Cartridges: These are new Canon cartridges which have an embedded chip on each cartridge. If you just refill the ink, the printer will still reads the cartridge as empty. You have two choices:
Purchase a "refillable cartridge" from www.asapinkjets.com
BCH or other sellers. These refillable cartridges have an auto-reset chip (non OEM) and will reset automatically.
Use a chip resetter (e.g., search Canon + model number + resetter on eBay). Follow the instruction below to refill your original cartridge, and use the resetter to reset the chip.
Inkjet Cartridges and Toner Refills
Aug 29, 2012 | Canon PIXMA MG2120 Inkjet Photo All-In-One
I refilled the ink cartridges on my canon mp250 printer. Now the ink lights will not quit flashing and I am unable to print anything. I tried resetting according to instructions provided by canon and it...
How much time you have done refilling a same cartridge? You shouldn't refill a same cartridge more than three times. Make sure that the cartridges are OK. May be the head of the cartridges are not in good condition. You may need to replace cartridge. Check that you have installed the cartridges properly or reinstall it. Align the cartridges. If it doesn't solve your problem then you have to replace the cartridges. Using original cartridge always is recommended.
Jun 10, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
How to refile the cartridge of canon pixma ip1300 printer
Instructions :
  1. Remove the old ink jet cartridge from the printer following the manufacturer instructions. Close the lid on the printer to keep it free from dust and debris while you are refilling the Canon ink cartridge.
  2. Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
  3. Gently insert the needle on the bottle of ink into the hole you just drilled in the ink cartridge. Avoid squeezing the bottle until the needle is completely inserted in the ink tank.
  4. Squeeze the ink bottle gently to refill the cartridge. Fill the tank with a little at a time until the cartridge is full.
  5. Remove the needle from the ink tank. Wipe the top of the Canon ink cartridge off with a paper towel. Place a small piece of duct tape over the drilled hole. Rub the tape to remove air bubbles and to make sure it adheres to the cartridge.
  6. Put the refilled ink cartridge back into the printer. Clean the head of the printer by running the printer software and following the instructions for head cleaning.
Good Luck!
Aug 28, 2010 | Canon PIXMA iP1300 Printer
Ink refill not detected
you must reset the cartridges on mx300
check here the ways
http://inkfilling.net/instructions-on-how-to-refill-canon-pg-37-pg-40-pg-50.html
Jul 25, 2010 | Canon PIXMA MX300 All-in-One Printer
Instructions on how to refill the the ink cartridge for a Canon mp730 .
You can easily to refill it only one time.If itself open cartridge and hole top of the cartridge push refill ink and close tide and tide.First time clean cartridge OEM software by printer default.
May 15, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Please help me to refill my ink cartridge, hp has complete instructions for remanufacturing but i could not find for canon. can you help?
There are catridge refill kits available for Canon catridges. Be sure to make sure that the kit will refill the cartridges for your model. Here is a link to a refill kit available on Amazon.com: http://www.amazon.com/Cartridge-Refill-CLI-8B-CLI-8M-CLI-8Y/dp/B00246MOHK
Jan 10, 2010 | Office Equipment & Supplies
I NEED TO KNOW HOW TO REFILL INK FOR A CANON MX310 #41 COLOR.i DON,T KNOW IF YOU PRY THE TOP OFF OR IF THERE ARE SOME REFILL HOLES SOMEWHERE.SHIRL85@EMBARQMAIL.COM
Your printer uses the following cartridges:
canon-pg-30
Black Pigmented
canon-cl-31
Color
canon-pg-40
Black Pigmented
canon-pg-50
Black Pigmented canon-cl-41
Color
canon-cl-51
Color
ou find the refill instructions for your cartridges in the book at the link below:
Download Inkjet Refill Instructions
You can also buy refill kit here: inkjet refill products.
You also need to reset the cartridge after refill, see: Reset Ink levels for canon mx310 - FixYa
Mar 02, 2009 | Canon PIXMA MX310 All-In-One Printer
483 people viewed this question
k24674
jasbo
jasbo
