Question about Samsung CLX-3175FN Printer
I have replaced the imaging unit and it still asks for a new one how do i reset it
    Scholar:
  • 111 Answers
Folow the steps please:
Checking replaceables
If you experience frequent paper jams or printing problems, check the
number of pages the machine has printed or scanned. Replace the
corresponding parts, if necessary.
1. Press Menu until System Setup appears on the bottom line of the
display and press OK.
2. Press the left/right arrow until Maintenance appears and press OK.
3. Press the left/right arrow until Supplies Life appears and press OK.
4. Press the left/right arrow until the item you want appears and press OK.
• Supplies Info: Prints the supply information page.
• Total: Displays the total number of pages printed.
• ADF Scan: Displays the number of pages scanned using the ADF.
• Platen Scan: Displays the number of pages scanned using the
scanner glass.
• Imaging Unit, Transfer Belt, Fuser, TransferRoller, Tray1
Roller: displays the number of pages printed each item.
5. If you selected to print a supply information page, press OK to confirm.
6. Press Stop/Clear to return to ready mode.
when you reach the imaging unit reset it then try, it should work then
Posted on May 20, 2011
I have Konica c220 a maassage : replace the Drum unit Black. There no broblem in print quality so how it reset
you replace the image unit when asking for a new one do so if not it will cause problem when you need the machine most
Feb 19, 2015 | Konica Minolta Bizhub C220 Color...
I have tried using a new fuse to cause an imaging unit to reset on a Phaser 7400 but the fuse will not blow.
If the unit is remanufactured or if you know how, you will have to disassembly the imaging unit and replace the fuser that blowns or simply just solder it. http://www.uninetimaging.com/downloads/technical/xerox/english/Xerox_Phaser_7400_Reman_Eng.pdf
Graphic 27.
Mar 30, 2014 | Xerox Phaser 7400/DXF Laser Printer
Reset imaging unit of Minolta MagiColor 2210
when you replace the image unit for what ever color is the machine asking for
Feb 11, 2014 | Konica Minolta Minolta MagiColor 2210...
Reset image unit (Magenta) Konica Minolta Bizhub C352
Change the chip or enter in service mode and change the imaging unit life duration to long life.The copier displayed continuosly Please change the image unit,press OK and ignore.
Feb 13, 2013 | Konica Minolta bizhub Office Equipment &...
What solution for samsung clx3175 asking intall image unit
Dear ,
Kindly refer the following link,
http://www.samsung.com/us/computer/printers-accessories/CLT-R409/SEE
This imaging unit needs to be replaced after it complete its life (6000 color pages/ 24000 mono images)
To replace first you need to takeout the toners and waste toner container ( a transparent/black container on the left hand side)
after that you may take out the imaging unit.
after that put the new imaging unit.
put the waste toner container and put back the toners.
If problem persists please provide your feedback.
Best Regards
Apr 19, 2012 | Samsung CLX-3175FW Multifunction Laser...
The imaging unit need to be changed but it was just changed
When a new Imaging Unit is installed there is a fuse contained within the new unit that blows and resets an electronic counter in the machine. If you installed or had installed a new imaging unit, then the only way the machine would be asking for a new imaging unit now is if either you ran about 70,000 copies or somehow the new unit did not reset the counter. I have never heard of one not resetting the counter as at the same time the counter is reset, the machine initializes the new unit and adjust the ATDC ratio. If this had not occured the mixture of toner to starter (developer) would not be correct and the copies would either become light (undertoned) or have a dark background (overtoned).
If you had the new unit installed then I would contact the service company that installed it and ask for a replacment. If you installed it yourself then there may not be much you can do. You can order a new reset fuse for around $5 and replace the fuse in your imaging unit so the machine thinks there has been another unit installed. precisionroller.com has them. Just go there and enter "Di350 fuse" in the search box. In case you were not aware, Your NEC is made by Minolta and is indenticle to a Di350/351.
Those would be your options.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 17, 2010 | NEC IT3510 Copier
I am getting an error, please chnage imaging unit and My printer is unable to print any document since this morning . It is taking time as weelll
Printer needs a new drum unit (imaging unit). Replacing it will either automatically clear the error (and reset the counter for the imaging unit), or there will be a set of reset instructions provided with the new unit.
Feb 03, 2010 | Minolta - DI200F Printer
Technical Black Imaging Unit Replaced,Error message still shows
These units are automatically reset with a fuse. When you put the imaging unit in it will completes a connection which resets the count then simultaniously blows the fuse. Sometimes the fuse blows before the reset, which is what it sounds like happened here. The machine should print normally but the error will persist until the unit is replaced with a new one. Is the the imaging unit an OEM unit or remanufactured? Whoever you got the unit from should replace it as defective free of charge. If it is OEM you might have to go through Xerox to get it replaced. I don't know if the Big Box stores will.
Dec 04, 2008 | Xerox Phaser 7300DN Laser Printer
Resetting
Check and see if the fuse has blown on the unit.  If it has, the machine probably needs the firmware flashed.
Oct 03, 2007 | Office Equipment & Supplies
Samsung CLX-3175FN Printer Logo
305 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
