Question about Plumbing
I have 2 bathrooms with a common wall. We hear a constant low tap of the pipes in the wall between the bathrooms. We have checked toilets, sinks, faucets, etc for leaks. Sounds as if there is pressure or something causing the noise.
  • 112 Answers
You have water hammer effect it is caused by a fast closing valve,it can be solved by installing a water hammer arestor in the plumbing line or maybe the water pressure is too high and a pressure reducing valve can be installed in the main water line.(the pipes in the wall are not secured properly that's why they vibrate)
Posted on Jun 14, 2011
Toilet bowl will not refill
It is possible that the vent pipe behind the toilet is clogged (or was not installed properly). Some bathrooms are set up with one shared vent pipe, and a clog in one of the lines leading to it can cause similar problems.
The vent pipe in each bathroom does 2 things:
1: it lets the sewer gas go past the bathroom and up out the roof so you don't get sewer gas in the house.
2: It breaks the siphon as water goes from fixtures down to the big sewer pipes in the house. If it isn't working for a sink, it's not much of a problem because air gets mixed in with the water as it does down the sink, and this breaks the siphon. But in a toilet, it jsut keeps pulling water down the pipe until the water level in the toilet gets low enough to let air into the pipe, breaking the siphon.
It's not an easy problem to fix and often involves removing walls to get at pipes.
A plumber can bring a snake tool and try clearing the pipes from below or from the roof, and might even be able to bring a steerable snake that lets him control how it goes through the pipe.
Apr 19, 2014 | Kohler Home
What are the most common venting problems for toilets?
What all that means is the sewage pipe going to the street is getting clogged so either snake it with 50 foot snake or go buy so Drain-O (60 ounce bottle costs about $9) and pour 1/5 in toilet and wait 10 minutes then pout 1/5 in Bathroom sink & wait 10 minutes. Keep do that until 60 ounce bottle is empty. Let this stay in pipes for couple hours and your toilet will double flush now its clean with no corrosion, hair, cooking oil, and other debris.
Apr 17, 2014 | Home
Air in water pipes
Check the toilet flapper, if the toilet is running it is because the flapper is not sealing properly. Change the flapper or entire flush valve.
Mar 10, 2014 | Plumbing
Toto neorest leaking & low pressure wand
Sounds like the washer in the shutoff at the wall has failed and is partially blocking the fill pipe. Some rubber from it may have gotten into the toilet valve internally. With the wall valve closed, try to remove the connection pipe to the toilet. If you can do it without water continuing to flow out of the wall shut off...then remove the pipe from the wall shut off. Flush the toilet. Now, apply air pressure to the rubber hose the goes into the overflow pipe. That may clear the valve in the tank and solve both problems. If you cannot stop the water at the wall shut off, close the water valve feeding the house. Remove static water pressure by opening the cold water a the kitchen sink faucet. Now you can open the wall shutoff valve and replace the washer and clean it out....
Mar 08, 2014 | Toto Neorest 600 1pc. Toilet MS99OCGR-01
Can you tie into a common dscharge pipe when plumbing a sanivite and saniplus?
I think it can be done , but it may be against the local code for your area. The obvious concern is back up of sewage in the sink, and washing machine.
Feb 01, 2013 | Home
Hi every now and again we are getting a sewer smell from our bathroom we have only recently moved in the house so not sure what to do, but it doesn't seem to happen all the time and everything flushes okay...
The smell may be coming from the sink trap if there is a problem with the vent pipe (that's in the wall from the sewer line to the roof). Do you ever hear gurgling in the sink drain when you flush? When you have the smell again, stick your head in the sink and see if that's where it's coming from. If you have a floor drain, the smell may be coming from there. In either case, a bit of water added to the drain will fill the trap and stop the smell. Please vote if you found this helpful. Good luck, Al K
Feb 16, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
Low pressure cold water tap in bathroom washbasin
It's a common and acceptable practice to have both on the same line, typically 1/2" copper or pvc. I wld start by checking to see if the valve under the lav is turned on all the way. Also, check the screen on the lav faucet. With a pair of pliers just grab it lightly and twist clockwise as ur looking down on it. Sometimes when the water is turned off for whatever reason and turned back on sediment will be jarred loose and get trapped in the screen. When the toilet is not being used the extra pressure will be enough to get a normal stream, but if the pressure drops a little u will see a noticeable reduction in water flow.
Jun 09, 2010 | Plumbing
I have two bathrooms directly under each other. The hinges on both cabinets (under the sink) are rusted and the pipes going from the wall to under the sink are also rusted. There are NO LEAKS ANYWHERE in...
You can't stop condensation or humidity in the house, especially in the bathrooms. A few choices: replace the hinges, or oil the hinges with WD-40. Install a vent fan (even though you have a window) and replace the pipes with PVC pipes. Metal drain pipes will always rust, because they drain water. Replace all under sink drain pipes with PVC
Mar 13, 2010 | Home
I hear running water behind my sink in the wall. how can I confirm its behind the wall and what can I do to fix it. I can't find no water on the ground in any room. meter reader says water is always...
If it is running constant, Check the toilet(s) flappers in the tank(s). If warer is leaking in the wall, You would know it, trust me.. To ck the house, Turn off the water to the house and then go ck the meter. Walk the yard and around the house looking for water perking out of the ground.Don't turn the water off at the meter. There should be a valve at the point the pipes enter the house or foudation.Good Luck_Ned_
Oct 21, 2009 | Belle Foret Bathroom Sink Faucet -...
Bathroom drain pipe has no threads
I 'am having a hard time visualizing this problem ? is your drain line a PVC pipe or is it the old style brass that was once used?
Jul 26, 2009 | Plumbing
Plumbing Logo
140 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
