Question about Nintendo DS Lite
My DS wi-fi says error code 52101 - Nintendo DS Lite
3 Suggested Answers
AcroneSF
  • 23 Answers
SOURCE: Why can't my DS find my wireless internet?
It is because your router doesnt support wifi connections..
Posted on Jan 07, 2009
SOURCE: my ds cant find my wi-fi adapter
dont worry ppl i fixed it, i found out that my internet connction that was going through the W-Fi adatper, wasnt accepting echo requests. but it works now.
Posted on Jun 13, 2009
Support nintendo
As of May 20, 2014, certain online functionality offered through Nintendo Wi-Fiicon1.png Connection is no longer accessible. The discontinued services include online play, matchmaking, and leaderboards for many Wii, Nintendo DS and Nintendo DSi games.
Aug 04, 2014 | Nintendo 3DS XL - Blue/Black
I dont know how to set up the nintendo wi-fi connection
  1. At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
  2. Tap "Connection 1 None."
    emptyconnections.jpg (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
  3. Click on "Search for an Access Point."
  4. The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
Once you have done this you may find next to your wi-fi, a lock this is what they mean:
unlocked_g.png No security - Your wireless network is unlocked.
  1. Tap on your network name to select it.
  1. Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test with your wireless router.
  • The connection test was successful - Your Nintendo DS is now connected online and you can enjoy the Nintendo Wi-Fi Connection features of the game!
  • The connection test was not successful - If the test was not successful, you will receive an error code.
    • Error Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
    • All other error codes: Try our error code lookup where we have detailed information on many common error codes.
wep_g.png WEP security - Your wireless network is secured with WEP and requires a security key.
  1. Enter your router's WEP key into the Nintendo DS Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands Enter your WEP keyOn the upper screen you will be informed that "A security key is needed to connect to this access point." Enter your security key by tapping the empty field, and select "OK" when finished.
wpa_g.png WPA security - Your wireless network is secured with WPA and requires a security key.
The Nintendo DS and Nintendo DS Lite are not compatible with WPA security. If you would still like to connect your Nintendo DS online, you will need to either change your router's security to WEP, or disable security entirely. Please note that any changes you make will affect other devices that connect wirelessly to your router.
Jul 05, 2011 | Nintendo Video Game Consoles & Games
Error Code :51100 Nintendo Wi-Fi Connection Setup
Error Code: 51100
The WEP key for the Access Point you are attempting to connect to has changed since you last connected.
What to do:
    • Errors ending in 0 = connection file 1
    • Errors ending in 1 = connection file 2
    • Errors ending in 2 = connection file 3
    • Errors ending in 3 = Nintendo Wi-Fi USB Connector
  • Verify the Access Point's WEP Key is entered correctly into the Nintendo DS. If your router has slots for more than one WEP key, the first (#1) must be the one selected on your router.
    If you have multiple connection files saved to your Nintendo DS, the error message you received can help determine which connection file may be experiencing a problem:
Jun 01, 2011 | Nintendo DS Lite
How do you get the wi-fi on the ds
To set up a Wi-Fi connection on your DS Lite you have to use a Wi-Fi enable DS game. Wi-Fi enable DS games have a Wi-Fi symbol on the front of the box it came in. Simply play the game and you should see options to set up a Wi-Fi connection.
Apr 21, 2011 | Nintendo DS Lite Console
Error Code 51099
Unfortunately, that error code means that your router is incompatible with the DS. I had this problem when I played DS, and we ended up buying the Nintendo Wi-fi USB connector, which acts as a bridge to let your DS connect through the PC it's plugged into.
You can find a USB connector at most electronic stores, but you just need to make sure it is the official Nintendo Wi-fi USB Connector, not a cheaper substitute, as those WILL NOT work.
The other option is getting a new router, which is the better but more expensive option. Chances are, your router is pretty old or low quality if you're getting that error anyways, and buying a new one will fix that problem right up.
Apr 06, 2011 | Nintendo DS Lite Console
Wi fi error code 51099
Error code 51099 implies that your DS cannot connect to the wireless signal. You should check the settings on your DS and the settings on your router.
Here's a detailed and interactive guide for how to do both.
Hope this helps fix your problem!
Mar 24, 2011 | Nintendo DS Lite Console
Error code 051110-1 How and where do you enter
Go onto the Ds game that your going to play wi fi
go to multiplayer
then Wi-fi
then go into settings and it should come up with 3 boxes of connections , click on and go from there :)
Mar 18, 2011 | Nintendo DS Lite Console
How do i connect the dsi to the wi-fi. wot does error code 51099 mean??
that error code indicates that the settings that have been entered are incorrect for your wi-fi or their is a compatibility issue with the security settings. Please read this official Nintendo guide.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51099&system=DS&locale=lang#wpa
Regards,
Omeil
Jan 30, 2011 | Nintendo Video Game Consoles & Games
I can't get my Mystery Gift on my Pokemon Platinum. I don't know what is a VIA NINTENDO WFC. I try it then it said ERROR CODE: 51099. I don't know why.
WFC: Wi-Fi Connection. Its your internet if its not Wi-Fi then you wont get the Mystery Gift Pokemons or Event. Ask your parents if your Internet is Wi-Fi
Oct 18, 2009 | Nintendo DS Console
Trying to connect to wifi usb connector and keep getting error code 52203
I'm assuming you are talking about the nintendo DS. Here is the info on that error code straight from nintendo:
Error Code: 52203
The Access Point you are attempting to connect from is not connected to the internet or a firewall is blocking traffic necessary for connecting to Nintendo Wi-Fi Connection. What to do will depend on where you are trying to connect from: What to do:
  • Verify that your router is connected to the internet when attempting to connect to the Nintendo Wi-Fi Connection. If you are not able to access the internet on your computer, then there is a problem with your internet connection. Contact your Internet Service Provider (ISP) for more information.
  • America Online (AOL) broadband users may experience difficulties when attempting to connect to the Nintendo Wi-Fi Connection. Please contact America Online for assistance.
  • If this error occurs regularly, while you are playing at home, it is likely a connection problem related to your firewall settings. For more information on firewalls and the Nintendo WFC, click here.
If the above information does not work, and you are using the Nintendo Wi-Fi USB Connector, click here for additional assistance.
If the above information does not work, and you are connecting at home with a wireless router, there could be settings on your router that need to be adjusted. Please click here for more information.
Connecting from a non-partnered Hotspot:
  • The access point at the Hotspot may not be experiencing problems. Ask the staff on site if their Wi-Fi network is up and running.
  • If the Hotspot's access point has a built-in firewall or other security that interferes with the necessary transmissions from the Nintendo DS, then the access point will not be compatible with the Nintendo DS.
  • Try another Hotspot. To search for known Hotspots in your area, click here.
Jul 16, 2008 | Nintendo Video Game Consoles & Games
Nintendo DS Lite Logo
300 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
