Question about Cyberhome CH-LDV 700B Portable DVD Player
The white piece of plastic attached to the rail so it can move the eye ball reading back and ford is broken. I want to know where can i buy that part? thanks
  • 340 Answers
This is something you'd have to contact the manufacturer for,
Though in all honesty it would be cheaper to just buy another portable player.
Posted on May 19, 2011
If you move the shifting lever in my truck it doesn't move the gears. I took the lever out and it seems to be missing a piece. It goes in the middle in some google pics it seems to be black. Any help?
If you have a stick shift that goes directly into the top of the box, the problem could be a missing pivot pin in the ball at the bottom of the stick
under that ball and directly at the end if the stick is a smaller ball that should have a plastic cup attached
that cup fits neatly into the selector rail slots
if it is missing ( probably broke up and fallen to the bottom of the box) the shift will be very sloppy
if the pivot in the turret is missing ( probably fallen out on the raid) the lever has no leverage point to move the selector rails
Oct 19, 2015 | 1985 Ford Ranger
Drivers side window off track on 99 monte carlo
take off inside panel roll down window while you hold window with hand if you look on bottom rail you will see a plastic piece that holds window on bottom rail that broken part will let your window move off bottom rail that lifts window thus it will come off track its a cheap part that you can buy and fix your window
Feb 15, 2013 | 1999 Chevrolet Monte Carlo
I have an older FR350 nailer. The coil return spring broke. I have the replacement and want to fix it. Do I have to take the whole nail guid assembly off to replace this part!
The best way to replace the spring is to remove the rails entirely. Take closeup photos of the gun from all sides with your digital camera or camera phone to help you with placement of all screws. You will need small clamp, small vicegrips and paperclip or piece of soft wire with small hook bent on one end to temp hold spring in place. With rails in hand check if pusher will slide out front of rails (some rails have a small casting preventing pusher from coming out front ~ remove tailpiece and slide out back ). Locate small screw /nut holding spring in place (keep this side of rails facing you). With new spring in place slide pusher into rails until you can catch the eye of the spring with bent wire at front of rails. While holding wire with vicegrip pull back pusher a few inches and clamp in place with c-clamp. Pull or let in bent wire to align eye of spring to attachment hole and install screw (you can leave bent wire in eye and just break off later. With screw attached break off wire and install rails to gun. Check sliding action of pusher before installing bolts at rear of rails. The pusher on some porter cable guns have plastic sliders that easily break with normal use and should be replaced as needed. Good luck.
Feb 08, 2011 | Porter Cable Air Tools & Compressors
My pfaff 1222 SE has a broken switch. I don't
I foud the correct power switch for your model (I have the same machine). This is located under the dark brown plastic cover. You can buy it on ebay and the item # 360066934338.
Jul 15, 2009 | PfaFF Creative 7570
96 dodge grand caravan drivers side power window---i have broken the nylon slides that attach to the window itself= do i have to replace the whole window monitor or can i buy the two nylon plastic slides...
It sounds like the Regulator is broken and needs to be replaced. Below is a picture of how the glass attaches to the regulator. Note the gold colored clip in the back that holds the glass to the regulator. IF the plastic piece that broke is the WHITE piece in the picture (yours may be black) then it is part of the regulator.
(the black piece in the picture is part of the glass)
480308c.jpg here is a diagram of your door glass / regulator.
b6fdf08.jpg Hope this helps
Apr 16, 2009 | Dodge Grand Caravan Cars & Trucks
2003 Ford Explorer back door latch will not open
Mine just did the exact same thing. The latch may be moving freely because it is not hooked to the latching mechanism anymore. In my case, the handle had broken where the handle hooks to the rod that operates the mechanism. Go to the Ford dealer and buy a new handle. Here in S.C. it was $24. You can't get this at the parts houses. Start by removing the plastic "Ford" cover that is over the liscense plate lights. You then have to remove the aluminum rivets that hold the handle to the tailgate from the outside and remove the broken latch. Remove the pull handle loop on the interior side of the tailgate (2 screws), unsnap the inside plastic tailgate interior panel, and pull down the black plastic sheeting that is underneath the panel to make access to the mechanism inside of the tailgate. There is also a hard plastic cover that you will see that needs to be pulled loose to open another access hole. Install the new tailgate latch handle by sliding back into the mounting holes and attach with two 10-32 screws and nuts. The new handle will come with a new yellow rod attachment piece on the handle. You will see inside of the tailgate a small rod hanging down, most likeky it will have the same rod attachment piece as the one on the new handle. Note the position of the yellow piece on the rod, as you will connect the new piece in the same place. Once the rod is hooked up, relubricate the metal mechanism with a light machine oil, replace the black plastic cover, replace the black plastic sheeting, (secure with a small amount of duct tape), replace the tailgate interior panel, replace the pull handle loop, shut tailgate, replace "Ford" cover over lights, and you're done!
Mar 23, 2009 | 2003 Ford Explorer Sport
Floor shifter ont engage to park
YES THE PART THAT IS BROKEN IS MOST LIKELY A WHITE PLASTIC PIECE THAT SITS INSIDE THE SHIFTER HOUSING, REMOVE THE SHIFTER HANDLE REMOVE THE WHITE PLASTIC PIECE WITH ALL THE ROUND BALLS ON IT (I KNOW WHAT IT LOOKS LIKE YOU DONT HAVE TO SAY IT) AND LOOK DOWN THE HOUSING WITH A FLASHLIGHT IF YOU STILL SEE A PART OF THAT WHITE PLASTIC PIECE, THATS YOUR PROBLEM. YOU CAN EITHER REPL SHE SHIFTER LEVER P# 52078551AG OR SEARCH THE JUNK YARDS FOR THAT PART
Nov 29, 2008 | 2004 Jeep Wrangler
E03
Day after thanksgiving, (year 2008) about to film my girls putting the tree and same E03 as all of you with the camera chewing my tapes. All of my DV cassettes are brand JVC so I know that was not the issue. I read and read and finally decided to grab a flashlight and study how the mechanism move. Then I noticed something suspicious about the right "two little spikes" attached to a white plastic piece that, when close, it moves to the right side of the camera head (the round stainless wheel inside). The white plastic piece mentioned above, part of it came off the guiding tiny little rail. 1. So I opened the tape compartment with an EJECT command, 2. Close it back up with an inmediate unplug of the camera without battery so it will stay in a position where I can get my fingers and paper clip inside. 3. With the paper clip, stretch the guiding rail in such a way that it widens so the bottom of the white plastic thingy can get back in the guiding rail. 4. Put a cassette inside and FFWD, PLAY or RWD and problem fixed.
Email me if you have any questions. Happy filming!
Raf
Sep 05, 2008 | JVC GR-D20EK Camcorder
Cyberhome CH-LDV 700B Portable DVD Player Logo
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Henry  Thomas
Henry Thomas
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
