Question about GE Security Simon 3 Wireless Home Security System
I have a Ge Simon Xt Alarm and i want to hook up a external siren(part 13-950)I received a 4.7 resister with the siren and 50 ft of wire.How do you attach the resister between the red and black wire?Do i use wirer nuts for this connection
    Problem Solver:
  • 4 Answers
Wire nuts are ok if the siren is indoors. Gel filled connectors are better if you are mounting the siren outside because they keep the connection from corroding. The resistor needs to go between the two wires you are hooking up. The color of the wires you will are are generally red and black. If your siren has a yellow wire, you can use it instead of the red to get constant siren instead of the "whoop, whoop, whoop" sound that sirens usually make. Putting the resistor at the siren will make sure that it is supervised. That means that if someone cuts the wire going to the siren, it will alert you at the panel. If you put the resistor at the panel, nothing will happen if the wire is cut.
Posted on May 21, 2011
Hello. there seems to be a beeping noise coming from the control box itself and it says to check status, but i'm afraid to push anything. thank you
Troubleshooting a GE Simon XT: Clear Errors and Alerts ...
? 3:06
https://www.youtube.com/watch?v=AtOCuthlsTo
Oct 3, 2011 - Uploaded by LiveWatch Security
Troubleshooting a GE Simon XT: Clear Errors and Alerts -Wireless Home Security ... Many times the Simon XT panel willbeep to indicate there is something ... How do you turn off the warning beep when you turn on alarm? I find it very useless and annoying. Can't seem to find a way to turn that feature off.
My Simon XT is beeping every 4 hours. How can I stop it ...
help.livewatch.com/.../20399861-My-Simon-XT-is-beeping-every-4-ho...
Aug 28, 2011 - If your panel has been beeping throughout the day and you want to turn off ... Scroll down on the Simon XT until you see "System Programming".Missing: control ‎hello ‎control ‎box
Jan 11, 2016 | GE Security Simon Xt Wireless Control...
Hi there, i have a Simon XT alarm system and i want to delete a sensor or reinstall it - i took it off the window when replacing them and now th system keeps bleeping to tell me it's been tampered
Try these 2 sites:
http://search.aol.com/aol/search?&s_qt=sb&q=Ge+simon+xt+service+manual&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
Jan 15, 2013 | GE Simon XT Wireless Home Security System
Just bought a DSC SD 15w siren has six wires. Using a GE Simon XT panel for fire and burglar alarms. Siren Has 6 wires. two red two black and two yellow. Which do I hook up? Do I need some kind of...
hook up red and black wires. Red wires to HW1&2 DC Out Terminal. 1 Black wire to HW1 and 1 Black wire to HW2. Resistor 47 Ohm resistor not needed unless siren supervision is turned on as an option. If needed , should go at the speaker, across red and black wires.
May 11, 2011 | Siren Dsc Sd 15w Ulf Surface Mount Siren...
I have a GE Simon Security System with a GE Simon 3- X10 Line Carrier Transformer that powers a siren. Since the X10 transformer was installed, I constantly get sensor 'failures.' Although the panel...
X10 is a signal format transmitted over the power lines, there is no special X10 wiring in the house as such. The siren and your outside lights are X10 receivers which are sent a signal from the X10 transformer connected to the alarm panel. The alarm panel sends the codes which are transmitted as X10 to the X10 external devices. Most houses now days have at least two 120 volt feeds coming into the main power panel, this provides the 240 volt required for electric stoves and dryers. Because of the two separate feeds split at the panel, the 60 cycles is usually out of phase with each other. To get X10 to work and stay in phase on each side of the panel you need to have wired a passive coupler across both 120 volt inputs. This coupler keeps both 120 inputs in phase with each other and provides a clear X10 transmit across the house wiring.
Dec 19, 2010 | GE Security Simon 3 Wireless Home Security...
Hi! Just had ADT install security system and it is a Simon XT. Door units, motion sensors and control unit are in house. They also put a motion sensor in garage, which is detached. My understanding is...
My understanding is that GE does not produce a wireless interior siren any longer. So if yo want to get a siren in the garage a wire will have to be run from the Simon 3 to the location in the garage where you would like to place the siren. PS ADT will not run wires to a detached garage. GL
Nov 16, 2010 | GE Security Simon 3 Wireless Home Security...
How do I turn system beeps off for sirens
My problem started when the electricity went off so now everytime I open the door the siren goes off. I don't have a manual so how can I get this to turn off.
Jun 18, 2009 | GE Security Simon 3 Wireless Home Security...
How do I replace the battery in my Simon XT security system
Here is a very easy to follow video tutorial that may help you.
You can get a replacement battery from here
Simon XT GE Security Security Alarm Battery 6V 1 2AH
Mar 08, 2009 | GE Home Security
GE Simon XT Home Alarm
http://74.125.95.132/search?q=cache:MppF70E2ihQJ:stonealarm.com/images/SimonXTUsersManual.pdf+ge+simon+xt+users+installation+manual&cd=1&hl=en&ct=clnk&gl=us&client=firefox-a
john copy and past the likk for the installation and programing manual.
mj
Dec 30, 2008 | GE Security Simon 3 Wireless Home Security...
What resistor is required?
If the resistor is used on a detection circuit, any standard 1/4 watt resistor will work fine. The function of such resistors are to be placed at the end of the line (most distant part of the detection circuit) and the purpose is simply to prevent a undetected short path in the line from going undetected. Such a circuit allows for the detection circuit (also called a loop) to activate both on a short or open in the circuit.
BIll
Nov 15, 2008 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
749 people viewed this question
Top GE Home Security Experts
Michael Galve
Michael Galve
Are you a GE Home Security Expert? Answer questions, earn points and help others
