Question about KitchenAid KGYS850LT Gas Dryer
Gas dryer does not get real hot anymore, sometimes the heat comes on and sometimes not.
  • KitchenAid Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Aug 15, 2011
Kenmore dryer MOD# 110.61402310, Dryer heats up and is SUPER hot. Clothes are to hot to take out after. Seems like timer is messed up because it will run until you open the door. Only has one heat set
OVER HEATING HAPPENS ONLY IN ELECTRIC DRYERS NOT GAS DRYERS.... HERE IS A VIDEO FOR HELP ON THIS..
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Oct 28, 2014 | Dryers
My dryer is not getting hot anymore and the model number is dddc0580valwh and can you tell me if it is the thermostat or the heating element.asap.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Apr 16, 2011 | GE DDC4400S Electric Commercial Dryer
They dryer wont get hot. the drum still operates but will not heat up to dry. need information on part cost and how to fix.
You first need to know, is it electric or gas. If it is electric, you more than likely have an electric element burnt out. Most dryers have one element and can be accessed sometimes through a small door in the front of the dryer (depending how old). An "element" is a long coil looking wire that looks like a real long spring. It gets hot and air passes over the element into the dryer. If the element burns out, the dryer will come on, but no heat. You can visible look at the element and sometimes you can tell if its burnt in two. Be sure to unplug the dryer before inspecting.
Apr 08, 2011 | Dryers
My 57560 lavatherm dryer runs but it does not heat up anymore, hence the clothes come out wet. What is wrong?
heatman101
Dec 30, 2010 | AEG Dryers
No hot air coming into dryer-- Where is the heating element located PLEASE???
heatman101
Dec 30, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool wed9600tao will not get hot power will come on but no heat
heatman101
Dec 14, 2010 | Dryers
I have a Maytag Gas Dryer Model# MDG508DAWW. It comes on and tumbles but won't heat up. I bumped the back of it with my hand and it came on and got hot then a few minutes later it started getting cold...
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help Replacing the dryer coils
Oct 06, 2010 | Dryers
Whirlpool dryer: Running but hot air stops coming.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 13, 2010 | Whirlpool LER4634J Electric Dryer
My dryer does not get hot anymore. Does not dry
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 19, 2010 | Whirlpool LER5636P Electric Dryer
Dryer
Probably the heater element. You need to pull the back of teh machine off and check the heating element for continuity. If its open then its shot.
These are parts that normally go bad.
Check on ebay these can be had for less than 50.00
Oct 03, 2008 | Amana ALG331RAW Gas Dryer
KitchenAid KGYS850LT Gas Dryer Logo
89 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
