Question about Refrigerators
Ice is forming on the top back panel in my artic air reach in frig.
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 20, 2011
I see droplets of water in the refrigerator side on the fridge. The fridge also has a little bit of ice forming near the vent.. Its a side-by-side fridge. Any ideas?
i idea is you have a wet frig . caused by wet air .. which is caused by a poor or not a complete defrost. if you have cardboard containers in frig they feel wet not dry and the mosture on the walls shouldn't be there . no frost dryes the air and your's is wet . ck the drain in back of freezer and make sure no ice in back of freezer .. mm
Oct 24, 2010 | Maytag MSD2756G Side by Side Refrigerator
My freezer and refrig are not staying cold, the freezer is defrosting and ice is forming on the back of the freezer.
Many times a freezer and/or refrigerator
do not work right because of a dirty condenser coil...there are also many other
things that can go wrong.
Sep 08, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer not defrosting
Most likely there is a leak in your freezer seal allowing moisture to build up and form the ice blockage.
Jun 17, 2009 | Jenn-Air JCD2389G Side by Side...
Freezer works, frig does not. Also ice build up in freezer coil
I just worked on a FF801W which is supposed to be very similar. The defrost heater in mine was of the glass tube type and located under the evaporator. There was a bimetal thermostat clipped to the top of the evaporator and a thermal fuse (sealed in a clear plastic tube) nearby. The connections were behind a little plastic cover (2 screws) in the back wall just above the evaporator.
Mine was iced up like yours and I had to defrost it with a hair dryer. All the defrosting parts in the freezer compartment turned out to work so I now suspect the defrost timer (down by the compressor). I've marked it and I'm waiting to see if it's turning.
Mar 23, 2009 | Avanti FF1101W Top Freezer Refrigerator
Whirlpool Ice Maker is not freezing the water to make ice. The water is being pumped to the freezing tray, but no ice forms.
I assume your in an area where the temperature has been in the 70's? or more lately? In fact if your not freezing water in to Ice you have a freezer problem that's going to get worse before it gets better. I suspect that you have either a Air movement, defrost problem, Or a dirty condenser.
The quick check for air movement: main thing is make sure the controls are set in mid range, any extreme end of the controls may keep too much air from the refrigerator going into the freezer making it too warm.
Defrost elimination (Check the floor or back wall on a top or bottom freezer fridge or the back wall of a Side X Side look with a mirror if possible) A problem here will require more information as to how to proceed. What make is it do you have a volt ohm meeter...
Of these this one is more likely especially if you've had some warmer weather lately. Look under the frig and behind it under the panel that covers the compressor area. See anything that looks like dirt and lint covering a large portion of the coils under the box??? vacuum or blow it out with compressed air and replace the panel give it 24 hours and see if you have ice.
Mar 12, 2009 | Kitchen Appliances - Others
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Help frig not cooling model # FRT21LR7A
You have to replace the electrical components on the side of the compressor. The heat from the fan not running by the compressor more than likely has damaged them. These are a safety feature to save the compressor from damage when it overheats.
You can find the factory repair manual here. This will have all the part numbers and what you need to replace to take care of your refrigerator. The Top Freezer Refrigerator one will be about your machine. It covers all the FRT Models.
Thanks
Jan 08, 2009 | Refrigerators
Water leaking from ceiling of frig, no ice forming.
pat,this is tom.if your box temps are fine.then you have a blocked defrost drain.[if temps bad ,will condensate in fresh food because warm temps]couple ways one is to shut box down eight hours other is to remove the back frezer panel and clean out all that ice and clear drain.you can use blow dry to melt ice[watch water and electricty do mix at all,be carefil]once ice gone use weed eater line with nott in one end to push threw and come out ouher end and cleanin His name,tom
Jan 02, 2009 | Freezers
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
