Question about GPS
Cannot get voice over to work - GPS
  • 24 Answers
Check your audio options on the GPS. Sometimes the volume can be muted or the voice can be disabled through the audio settings. To do this, you will probably need to power on the device, look for an options screen, and then search for the "audio" or "volume" settings. Once you reach this screen, check if the volume is set to 0 or mute. If so, turn the volume up to a comfortable level. If the volume is already set up high, check the settings to see if "voice" is enabled or disabled. If disabled, then switch to enabled and you should be good to go. Let me know if you need anything else.
Posted on May 19, 2011
Galaxy tab3 10-1. How do I make the voice input work?
try going to settings and switching siri on
that is the voice recognition program
Dec 16, 2015 | Google Cell Phones
HOW CAN I GET THE VOICE PROMPTS TO WORK ON MY NUVI
Normally on front of screen there is promp for voice to mute or un mute, but if you don't see that go to settings and look for voice controls. But like I said is normally on screen right side area looks like a circle kind of.
Jun 08, 2011 | Garmin Nuvi 265W GPS Receiver
Voice frequently not working. this problem intermittent. what do i need to do to ensure voice always works? Turning sound off and on again sometimes works. Turning on before using sometimes gets voice...
Are you using a synth voice, or a sampled voice? If the latter, one of the voice files might be damaged, and in that case, as soon as the Tomtom accesses it, the whole voice function will shut down.
Try changing the voice and see what happens. The synth voice does not access any sample files and should always work (or never at all).
To restore the functionality, download again the voice files, or try restoring from the PC backup. At least, this worked for me when I had the same problem (but MY file was damaged at the end, so I was able to notice that the last thing the Tomtom said was always "In sevent*". The damaged file was, I suppose, the one with the word "seventy".
May 29, 2010 | Tomtom GO 910 GPS Receiver
Incoming voice is clear but outgoing voice is not working
Check the voice settings.
Click on start and then choose control panel.
Double Click on sounds and audio devices and then use tag for voice or click on voice.
Now click on harware test and then speak and click on next and once again speak and then click on next and end to finish.
You audio harware visit will complete and your device will work properly now. You voice will work for input and ouput.
Good Luck
Dec 07, 2009 | IBM LENOVO VIDEO ADAPTER-G450 32MB 22P6640...
Text to speech arabic voice SalmaYoussef configuration in windows
did you install the latest version of the software try looking for a windows XP version of the Acapella Multimedia. Another thing is that maybe the the salma and youssef sounds only work with the software, to help protect their software.
Mar 12, 2009 | Microsoft Windows XP Professional
VOICE DIALING
You need to Add Voice to Contact first
for that find out the key which is works for Voice Commands.
By default if you hold Volume Up key or 1 or * keys any of these keys may work for Voice Commands.
Sort out then you will get an option enter voice command ..
let me know the result..
Regards,
Suraj.
Feb 19, 2009 | Motorola Mobility RAZR V3
Yahoo messanger voice service is not working
Dont use yahoo messenger for ACER ASPIRE ONE not compatible, I suggest use SKYPE messenger text chat, video and voice call as well work great.
Yahoo messenger work only video and text chat only but voice call not work.
Skype messenger works video and voice call works perfectly.
Nov 23, 2008 | Yahoo Messenger
I can't seem to enable to voice prompts
Taken from the Garmin website:
"This error is most likely caused because the voice files need to be reloaded onto the iQue. Insert the iQue setup disk and select 'Install Software'. Then select 'Change voice'. Then select the voice to be installed on the device. When the voice files are finished installing, perform a Hotsync. The voice guidance files will then be restored to the unit and the voice prompts should work correctly."
Feb 26, 2008 | Garmin iQue 3600 GPS Receiver
Voice Dial
I had a problem getting the voice dial to work on my K1 phone. The voice dial would not work if the contacts are stored on the sim, once they are copied to the phone memory all wored fine.
Dec 27, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
GPS Logo
42 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
