No audio output device installd - Computers & Internet
  • 340 Answers
You need to install the driver for your laptop's audio output device.
We'll need to know your laptop make and model before providing links to the correct driver
Posted on May 19, 2011
My pc says no audio output device installed,but in device manager it says its working properly and the drivers are up to date
Well it is possible that the audio driver installed is not the one compatible with you computer board. Try downloading the specific driver needed for your computer's official website. This should solve your problem.
Sep 06, 2011 | Computers & Internet
Audio output device
Hi.
The audio output device in your computer is the audio adapter board (or circuit). This is the device that produces sounds and send them to the speakers.
If you get a message telling you that there is no Audio Output Device detected, or that the Audio Device is not working, that usually means that there is a problem with the audio driver.
In that case the problem is often fixed downloading and reinstalling the drivers for your audio device. If there is a problem with the audio output device, go to the computer manufacturer website (e.g. Dell, HP, Sony etc.) and download the audio drivers for your specific model. When download is complete install the drivers and restart the computer.
Regards.
Ginko
Jul 20, 2011 | Microsoft Windows Vista Home Premium with...
My pc does not regonise my speakers anymore since i instalt wireless internet and or installd my camera i cant even open my audio in cofiguration screen ???
Good day. In response to your issue, you might need to reinstall the driver for your speakers this will correct any problem on your audio if it encounter any error and just restart the computer to finalize the installation.
Note: some software can cause conflicts with other software better check the compatability of every device or software that you plan on installing on your computer. You can check the guide or manual for this informations
Hope this help you a bit. Have a great day and thanks for choosing Fixya.
May 22, 2011 | Labtec LCS 1030 Computer Speakers
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
Audo sound problem
I think drivers are nede link but if you provide such little information about problem how can I learn what meens "problem" for you. If drivers are installd and ready you may need bios setup and FEATURES SETUP enable AUDIO DEVICE see manual in download page.
If not reach goal describe your problem briefly and will help.
Aug 01, 2009 | Mercury P4VM800M7 Motherboard
In my laptop sound driver is not working
Try by going in to controlpannel, unitenchanter and find it ther and loke at the highlighted area "it's the devices not installd area". and see if you can install it or update it ther..worked for me.
Don't Forgett to Rate my solution. Ty
Jan 10, 2009 | Computers & Internet
Acer TravelMate 2420 sound device not installed
What You need to do is going in to controlpannel find the audio card thats ar lokated in unitcontro. loke up if it's installd if not install it tru the update area... i hade thet problem as well few years ago.. hope it's working:) if not writ again Ty
do not forgett to rate what toy think of this solution Ty
Jan 09, 2009 | Acer Computers & Internet
NO AUDIO OUTPUT DEVICE IS INSTALLED
its a known issue --if you u upgrade vista home to vista ultimate.just u need to uninstall the audio driver and install it again
Dec 22, 2008 | Microsoft Windows Vista Home Premium with...
Sound driver problem packard bell moudle no.m5xxx
take a driver cd which will came with your system and try to install it agian after then you get it . it means that your sound driver is not installd properly
Jun 06, 2008 | Computers & Internet
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
