Question about Linksys BEFSX41 Router (DHBEFSX41)
Have Linksys BEFSX41 router. Firmware is ver. 1.5.18 April 30, 2004. Can I update this and use it to connect to the internet using Windows 7 Home premium?
  • mjzbornik May 19, 2011
    That didn't work. Lights on DSL modem come on and blink appropriately and lights on router do the same yet I can't connect to the internet. I'e tried my router address 192.168.1.1 and my ISP address 192.168.0.1 and without success. Router SN is CB9110EA06652. This is a ver.2 router. I am trying to connect with Windows 7 home premium 64 bit. Any other ideas?
    mjzbornik@aol.com
  • 797 Answers
Yes, the router itself has no software interaction with the computer. You should just need to plug in the WAN cable from your modem and connect the LAN side to your computer. There should not be any password required for the LAN connection.
If the router was previously set up on a different ISP and the previous or current ISP require a username and password for Internet connection, normally only for DSL, then you may have to reset the router to factory defaults and configure for the new ISP. When you connect to the router and Windows 7 says it found a new network, if this is your home, you want to make sure you select home so it properly configures the firewall for Internet access.
Jim
Posted on May 20, 2011
  • James Preston
    James Preston May 20, 2011
    Hi, have you tried using the router? Is it working?
    Jim
    Preston Comptuer Services
    www.prestoncomputerservice.com
  • James Preston
    Why are you using the Linksys router? What DSL modem do you have? Most of the modern DSL modems supplied by the ISP (telephone company) include a router and many of them include wireless too. Supply me with the modem model and I will let you know if the Linksys is required. If you want to use the Linksys instead of the ISP supplied router (still need the modem though) that may be possible but I will need to research you modem and the Linksys capabilities to be sure.
    So, post the modem model number and confirm you want to use both the modem and Linksys together even if there is a router built into the modem.
    Jim
  • 823 Answers
Yes you can use that router to connect to the internet using Windows 7. You really don't need to download and install drivers for the router unless there are specific settings that you wish to program and use. I connected mine without downloading or installing anything and it worked just fine.
All you have to do is plug in the router and connect your modem to it. Wait for it to warm up and all of the lights to come on and go steady (except the wireless & internet connection lights) then connect your pc to it via ethernet cable (with the pc turned off). Then start your pc and it should automatically recognize the connection.
Posted on May 19, 2011
I have a LinkSys WRT54G2, Vers 1.0 router with the latest firmware installed and basically default configuration. I usually have 3-4 PCs connected to the router. I frequently loose connection to the...
Sometimes, you might face a situation where your wireless icon shows that you are connected to the Internet but you just can't access any websites. What do you do when you face this problem?
This article will show you how you can repair Internet connection when wireless icon shows connected, but unable to go online.
To connect to your wireless network with Wireless Zero Configuration, please click here.
In checking if you're computer is properly connected to the Linksys Router, you will need to perform four steps:
i. Checking the Physical Connection to the Router
ii. Checking the LEDs
iii. Checking the IP Address of the PC
iv. Pinging the Router
NOTE: To check the computer's connection to the router using Mac, click here. If you are using Windows Vista, click here. For Windows 7 users, learn more here. For Windows 7 users, learn more here.
Make sure that the computer is connected to one of the four Ethernet ports of the router and the modem should be connected to the Internet port. For more instructions, click here.
Checking the LEDs
The Linksys router's LED lights will indicate the status of the connection. After connecting the broadband modem and the computer to the router, make sure that the LED lights are lit up. For more instructions, click here.
The IP address of the computer is another indication that the computer is properly connected to the router. For instructions, click here.
Pinging the Router
Ping test helps trace the communication between the computer and the router. The computer sends packets to the router and in return the router sends out replies to validate the connection. In this example, our router IP address is "192.168.1.1."
Dec 06, 2010 | Linksys WRT54G2 Wireless Router
We just replaced our T1 with Cox cable internet access. Now the internet is incredibly slow through the Linksys BEFSX41, but fast is directly plugged into the cable modem. What can I do to fix that?
HI Friend
You have to upgrade the firmware of your router. To do this please follow the steps
1. Open the website www.linksys.com/download
2. Enter the model number of your router and hit enter
3. Now click on Get downloads and drivers
4. Select the version number of your router and scroll down a little.
5. To your left you will see Downloads and under that you will see Firmware
6.Click firmware and save it to your desktop
7. Now again open internet explorer and in the address bar 192.168.1.1 and hit enter
8. If you have not changed the default password of the router then leave the user name blank and in password type admin and hit enter.
9.Now click Administration and under that click Upgrade firmware.
10. Select the file and that you have saved on your desktop and click upgrade.
11.After upgrade turn off the router for 30 seconds.
Enjoy
Regards
Chiranjeet
4.
Dec 16, 2009 | Linksys BEFSX41 Router (DHBEFSX41)
The Linksys conflicts with the game Aion and my isp shuts down. Once I routed the comp str8 thru to the modem, the game works. So, I need a firmware update it looks like. My model number is BEFSX41 version...
This problem is solved, as you believed, with a firmware update. This is something to be done with an extreme sense of caution. One misstep and your router is useless.
STEP 1: Check your version (it is on the bottom of the router on the sticker, for mine it was version 2 so if you have version 1 proceed with caution.)
STEP 2: go here: http://www.linksysbycisco.com/US/en/home and scroll to the bottom and enter your model number (the number on the front of your router) Mine was BEFSX41.
STEP 3: click on the "GET DOWNLOADS" link
STEP 4: Select version 2 (ONLY IF YOU HAVE MY EXACT MODEL AND VERSION. MISTAKES HERE TURN YOUR ROUTER INTO A PAPERWEIGHT!)
STEP 5: Download the version 1.52.15 (dated 06/08/2007) file and save it to your computer somewhere you can readily find it again.
STEP 6: Log in as administrator to your router. If you are unsure as to how to do this, seek another help file or simply run ipconfig in the cmd (windows key + r, type cmd and hit enter) to get to the prompt and type ipconfig and determine your port. (local) Type that IP address into your web browser and a prompt for your admin login should pop up. If not, you have the wrong IP, try again or seek further help.
STEP 7: Select the "Administrator" tab and click the "Firmware Upgrade" sub-tab. Here browse to the file you downloaded and click "Upgrade". NOTE: This is where you can break things. Make sure no one is using the router to download/upload files or do anything intensive and make SURE the power is never lost to the router or it's a dead stick. Wait a couple minutes for the firmware to update.
STEP 8: If and I stress IF because you can make mistakes doing this that will ruin your router forever, no going back, it's broken, buy a new one kind of stuff, the update completes you should get a blank screen with a "Close" button. It should say the update was successful.
Now, load Aion and there should be no further connection problems.
NOTE: I had already forwarded the necessary ports before doing this firmware update. You can easily google the ports necessary for forwarding. If problems persist you are outside of my ability to help you, because you either fried the firmware (trashed your router) or you have other hardware conflicts. (check your network card, compatibility issues, etc.)
It fixed everything for me in one shot, but this is a touchy issue. BE VERY CAREFUL. Make sure power will never be lost to any device (no thunder storms, no rolling brown outs, etc.) And best of luck.
To reiterate, the reason I am stressing so much caution is because your router is shipped with the firmware flashed onto it. This is what makes it work, function, be able to be changed / tweeked / fixed. If you ruin your firmware somehow your hardware is destroyed. If you follow the steps exactly and don't do anything hastily you will be fine, but this is one of those "void the warranty" scenarios. DO NOT take ANY firmware files not on the official website for your router. DO NOT turn off your router or computer during updating. DO NOT touch anything while it is working. It took me about 5 minutes to finish the process, but to be honest I would walk away, go out to a bar, do something else for the evening before I ever canceled anything in this process because doing so ensures your need to purchase a new router. It is doable safely. I did it slightly drunk, it's a long explanation but that's because there are more than 3 things to click on and if you screw up you just spent $100 minimum. I just want you to be wary of advice from the internet. Just because I can do it does not mean anyone can do it. If you have ANY doubts, ask for help.
- Morph
Jul 03, 2009 | Linksys BEFSX41 Router (DHBEFSX41)
I am unable to connect Linksys BEFSX41 and Sonicwall 3060
Check out this post:
http://www.dslreports.com/forum/remark,5336853
This person seemed to have no problems with it and includes configurations.
I would also make sure both are the same version or same firmware, I have had trouble in the past with netgears having different firmware not allowing a vpn to be configured.
Jun 26, 2009 | Linksys BEFSX41 Router (DHBEFSX41)
Linksys befsx41 firmware
Hi dear go to this link http://www.linksysbycisco.com/US/en/support
From here you can download
Thank you
Imran
Pls rank as possible have nice day
Apr 20, 2009 | Linksys BEFSX41 Router (DHBEFSX41)
Frimware Upgrade
Apparently not, but I'm guessing you already knew that.
http://www.linksysbycisco.com/US/en/support/WRT54G/download
Look carefully at the label and the firmware installed in your router. The 1.02.5 is listed for 5 and 6 only and version 8 is for 8 only. There is no 7 listed, so it was either a special run or there is just no firmware upgrade for it yet. It must have been perfect :-)
Carl
Mar 24, 2009 | Linksys Wireless-G Broadband Router
3 PC's networked to BEFSX41 very slow accessing internet
sounds like your internet access is the slow down, not the router. You don't say if you have DSL or CABLE or what.  I'd check there. Make sure you are getting a strong signal.  Hook up one system directly, without the router and check the speed.
Oct 14, 2007 | Linksys BEFSX41 Router (DHBEFSX41)
How to Upgrade the Firmware on a Linksys Router
I have update the fireware of linksys router WRT54G ver.2.2 by wireless.. Wrong move.. Then it stop loading.. now I can not get in to the router even i reset the router.. what can i do to have it back..
Feb 16, 2006 | Linksys BEFSX41 Router (DHBEFSX41)
Linksys BEFSX41 Router (DHBEFSX41) Logo
54 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
