Question about Panasonic Lands Phones
PNLC1001ZAB IS THE MODEL FOR MY TWO WIRELESS PHONES. PROBLEM IS AFTER TALKING FEW MINUTES LINE GOES DEAD. CAN I REPLACE THE AAA BATTERIES WITH NON-PANASONIC AAA BATTERIES? WOULD THAT BE THE PROBLEM?
SOURCE: we have had a panasonic
We have this model also, and have exerienced similar problems. Try disconnecting all of the phone lines for that ph number, for a minimum of 30 seconds. Reconnect and the line should be functioning again. It always works for me.
Posted on Sep 12, 2008
  • 736 Answers
SOURCE: I have a Lucent model 103H. I no longer get a dial
hmmm .. the lucent 103h is called a "partner 5 slot (carrier) chassis for partner internal phone systems .... used in business usually for multiple phones... unless you have a home phone by that same name .. if you do have a "partner" system then lucent repairs those for about $65 ... check the line before considering repair ... if you have a single standard phone that just happens to have the same name .. then you may have a damaged telephone line .. you can test that by unplugging this phone and temproarily plugging in another .. if it works then there is likely damage to your original phone .. usually its lightning surge protectors that fail (due to a nearby llightning hit) ...if a second phone doesnt work then there is usually a service jack near where the phone line comes into the house .. you can plug in there .. if the phone is bad there also then its an outside maintainence repair job .. thats free from the telephone company .. if the test phone works at that test jack then its often your responsibility to arrange inside line repair .. unless you have an inside line repair contract the telephone company may charge for inside repairs .... your phone company can talk you thru using the service jack .. you would first disconnect the rest of the house by removing a connector from the service jack then you would plug in a standard phone to that jack .. that makes sure the problem is either inside or outside .. if your phone happens to be chordless then there is more things to consider .. the handset and base have to develop a relationship in order to work properly ... that relationship can be lost in a power failure and must be reestablished .. usually thats done by removing power from the base for a minute then connecting it again .. so there are a lot of possibilities depending on what type phone you have ...
Posted on Aug 18, 2009
freetek
  • 5568 Answers
SOURCE: panasonic phones say
The base station may have gotten 'zapped' by a high voltage transient, they are not very well protected against transients arriving via the telephone line. Try removing the line from the base station to see if the display no longer gives you that 'line in use' message. If it does, the base station is toast. If it doesn't, dig around and find an non-electronic phone to plug into your phone jack to see if you have a dial tone. We keep at least one of the old style phones to use during power outages since cell phones are useless in our area.
Posted on Mar 08, 2010
  • 532 Answers
SOURCE: Phones won't charge
hi,
have tested the charger if it is working?
if you test the charger with another phone and is working perfectly then the charging port of your phone is bad.
the charging port is the port where you insert the charger.
try and get a new charging port and replace with the bad one, the phone will charge.
thanks for using fixya.
Posted on Jun 07, 2010
  • 1340 Answers
SOURCE: I have Panasonic phone model
Since it is affected in all 4 phones,batteries are not likely to be the problem.It is most likely a problem with the base unit.Does it have an antenna which you can raise?That would be a common cause for this situation.It is not raised.If it is raised,is it in a somewhat central location of your residence?Sometimes when the base is located on one side of the house,you are talking on the other side of the house,certain things can cause periodic breakup of the signal,such as cement walls.There may be a channel select button to change the operating frequency also possible by someone nearby having a DECT phone working on a nearby frequency which may be very close to yours.This is less likely though because of the wide range available,but stranger things have happened.If there is no button labeled channel (CHN) or something similar on either the base or the handset,you may have to access it through the handset.With the phone off(Not turned on to dial out),press the function(FNC) button to access the options within the handset.Since so many companies are built different,each one has their own way of doing things,but this is usually the basics of most phones.If you do not have the user's manual,here is a link for a free,downloadable one to assist you.I have preset the link to Panasonic p[roducts but you may want to go to their homepeage and bookmark it for future reference.It is an the best site I have found for these manuals.Good luck! Greg
Posted on Oct 28, 2010
Hisense TV, remote keeps using up my batteries, only last a week or two.
seen this battery issue reported online before with these remotes
depending on age and model of that TV
you can buy new original ones
dont buy universal types for a hisense
is it the original remote ?
what brand of batteries
lithium energizer?
info
rechargeable batteries never fully charge up
only two needed
size is AAA or AA
Oct 23, 2016 | Cars & Trucks
Our Uniden D1680 cordlesss phone has one n base and 3 others in different locations of our home; the main one is hooked up to an AT&T wireless home base; when talking on our landline, we hear beeping...
all of the cradles that hold the phones are chargers for the phones
batteries will last more than 1 hour in use and for more than 1 year in constant use and recharge after every use
I doubt that the phone is the problem but more of a service provider problem shutting down the line
there is a uniden technical division on their web page and I suggest calling the service provider and asking what is happening with the line
May 01, 2017 | Lands Phones
Problem with Uniden wireless phone cutting off
The batteries are no good, though it may be new to you the set may have been around for 1-2 years before it was sold to you, and the batteries could be even older depending on where the company got the from, the best thing to do is to take them back for replacement under the one year manufacture warranty at the store you bought them, also if you replace the batteries at cost they will roughly cost about 32.39 with tax. To buy new batteries or attempt to fulfill the manufacture warranty--Good Luck.
Jan 31, 2013 | Lands Phones
RCA ViSYS phone says "replace battery" but it doesn't have one
There is a battery box that holds 4 AAA batteries. It's down under. Not easy tospot but it's there. However, I added fresh batteries and it stil says replace battery. I'd like ot know how to turn off the message.
Feb 03, 2010 | RCA ViSYS 2-Line Speakerphone
Hello, I have put batteries in both phones and set them on the chargers However, as soon as I take it off the charger, it goes dead. Why is that?
Those batteries are not chargable. I think you need AAA NiMH rechargeable standard batteries. You can get them at Walmart, Radio Shack and many other stores. If you have the owners manual for the phones it will have information about the batteries.
Jan 01, 2010 | Doro 730r+1 Twin Cordless Phone
How do I change the AAA batteries in my GE Wireless Optical Mini Mouse
Grip the sides of the mouse with both hands and slide the battery cover
back with both thumbs. Then, replace the old batteries with two AAA batteries. Replace the battery cover. Hope that helps.
Jul 30, 2009 | GE Wireless Optical Mini Mouse 3087897985
Do I need an AAA battery to make it working?
The batteries go into the back just press the word sylvania while sliding the silver backing/sides away, but not too hard or far or you'll break the plastic tabs. Good luck
May 25, 2009 | Sylvania Fellowes 9893501 Microban...
RCA Phone model 252025 - displays Answer... on line 1
The Thomson folks said to reset the phone. Here's how: unplug power, then the phone line, then remove the batteries. Wait 10-15 minutes. Replace the batteries, then the phone line and finally, the power.
Note: We have 2 phones with these two lines and had to reset both of them to clear the "busy" on Line 1.
Sep 05, 2008 | RCA 25205RE1 Phone
Re: Tevion Sound Wireless Headphones - Model No 82010 I puarchased the above on the 31.7.08 I can recharge the 2 NMH AAA batteries rated 500mah (as supplied) on the transmitter o.k. I have however,...
CHARGE THE NEW AKUS IN ANOTHER CHARGER AND THEN USE THEM AS USUALY.
SEE THE CURENT SUPPORTED BY THE ORIGINAL GHARGER,
IF IT IS AT LEAST 100mA , IT SHOULD CHARGE YOUR NEW AKU ! BUT MAYBE THE CIRCUIT INSIDE TX DO NOT SUPPORT
AKUS BIGGER THAN 500mAh .
YOU SHOULD RESPECT THE SPECIFICATIONS GIVEN BY THE PRODUCER AND IT WILL BE OK !
Aug 05, 2008 | Audio Players & Recorders
TI-83 LCD Screen Problem
Try replacing both the AAA batteries and the back-up batteries. This should probably fix the problem.
Aug 14, 2007 | Texas Instruments TI-83 Plus Calculator
Lands Phones Logo
214 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
