Question about Jandy AQUALINK RS TELELINK KIT
We have an aqualink RS6. The spa is turning itself on by itself. When we manually push the spa button to turn it off, it will again come on a few seconds later by itself. Does this mean we need to replace the entire CPU?
    Top Expert:
  • Jandy Master
  • 4,292 Answers
Unplug spa side remote if it quits replace if it continues see if there are any programs delete them
Posted on Mar 05, 2016
PartsCenter
  • 125 Answers
SOURCE: aqualink rs6 program canceled and does not recognize chlorine gen
Trouble shooting guide
Posted on Feb 26, 2009
PartsCenter
  • 125 Answers
SOURCE: Operating instructions for Aqualink RS8 pool/spa combo panel?
AQUALINK GUIDE
PartsCenter
  • 125 Answers
SOURCE: Jandu Aqualink Pool/Spa Controller RS6
AQUALINK GUIDE BOOK
SOURCE: Why am I getting a 6700 REV C message on my AquaLink RS6 home spa
I had the same issue, but only after I pressed the reset button on the side of the panel. After a couple of days of troubleshooting, I found a small nick in the wiring from the outdoor unit to the indoor paneI. I turned off the breakers to the pool equipment, rerouted a new cat5 cable, but cat3 will work just as well, wired it up and all was good. A local pool guy wanted to charge me about $2000 to replace both units. I spent less than $5.
Good luck
Posted on May 28, 2009
  • 128 Answers
SOURCE: Jandy Aqualink RS
Disconnect the spa side remote.
Posted on Aug 23, 2009
I have a Aqualink RS6. When I push the "Spa" button to circulate water from the spa, to the heater, back to the spa, then the spa begins to empty! What do I fix or replace?
it sounds as if the actuator returning the water to the spa is not responding. when you hit spa, the 'draw' and 'return' valves must be in the right position. if the draw switches to spa but the return stays on pool, the spa will drain
Jul 19, 2014 | Jandy AquaLink RS2/6 All Button Dual...
I have Jandy/Zodiac LRZE legacy heater and Jandy RS6 controller. When hooked up to RS6 and there is a call for pool heat the heater ignites but shuts off in about 30 seconds. When I disable the TSAT...
check your dip switches on the inside panel of the aqualink if you still cannot get it to work i would use the pool to 1 wire of a new wire you will run to the heater then 2nd wire to com then on the on the PCB board going to pins 1 and 2 of the big plug then turn heater all the way up when heater button is pushed or activated it will turn heater on and off
Aug 05, 2013 | Jandy Legacy LRZ Heater
Aqualink RS6, 6700 rev c message
check to see if wires are cut or shorted if ok need new controller
Apr 30, 2012 | Jandy AquaLink RS OneTouch RS6 Pool or Spa...
I have an Aqualink RS6. light button pops GFCI
This is in your lights. Ether you have water in one of your lights or a short somewhere in the system. Were these new lights or just new bulbs?
Apr 28, 2010 | Jandy AquaLink RS2/6 All Button Dual...
When the filter pump comes on, the cleaner booster
check the programs or better cancel all the programs and restar from the begining if still after this the spa side switch need to be replace
Sep 11, 2009 | Jandy AquaLink RS2/6 All Button Dual...
Aqualink RS6 all lights on control panel lit and won't work
I' m having the exact same problem, where the panel lights up and is non-responsive. Did you ever find a solution?
May 21, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Auto shut down function not working (Jandy Aqualink RS6)
Jandy relays are known to stick. You can diagnose this yourself with a screwdriver. Remove the four screws on the outside panel. You will see a series of black rectangular relays and a lot of wires. Typically the pump relay is the one in the upper right. It will certainly be the one plugged into the left hand socket at the bottom of the circuit board.
Be sure to do all of this simply be looking. You can move the twisted red/black wires a bit to determine which relay is plugged into the first socket. Try to notice on the bottom of the relay a small black tab that is sticking out. When out, the relay is on. If the pump is running, this tab is out. If you then put the controller into service mode and the lights go out without the tab popping back in, you have a bad relay. If turning the pump off does not put the pump light out, you have a bad board.
In most cases, the relay is bad and it is a simple fix.
Nov 24, 2008 | Jandy AQUALINK RS TELELINK KIT
Jandy AQUALINK RS TELELINK KIT  Logo
106 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
